Question about Pentax Optio T20 Digital Camera
Camera wont turn on!! help!!
Ok i have a pentax optio T20 camera and the battery is fully charged but it still wont turn on. wut else is there to do?
    Novelist:
  • 133 Answers
Dear Texaslilly,
Although there is nothing much to do but you can still try the following.
  1. Try with different set of batteries
  2. Remove the memory card from the camera
  3. Cameras generally do have an option to plug-in external power supply..Try with external power supply .. if there is any.
  4. Now this might sound little crazy but no harm in trying .... Remove batteries... Press and hold the power button for few seconds... release the power button ... reinsert the batteries and try to power on without memory card.
Try the above and let me know if it works.
Regards,
Srinivas.
Posted on Jun 19, 2009
My Pentax Optio WP beeps 3 times, goes dim and turns off. The battery is charged up fully. Any suggestions?
Hi Jesslionbery,
Please try removing the memory card that has been installed in it , if any.
When you remove the memory card make sure it starts.
If the above trick does not work , try using NIMH battery instead of the ones that you have in and check if it works.
Also if you update the firmware of the camera , it may solve your problem, please find this link for more information , as the crashing problem has been resolved for many because of a firmware update.
http://www.pentaximaging.com/customer_care/show_firmware?firmId=6442215.
Hope this helps ..:)
Jun 28, 2011 | Pentax Optio T20, T10, A20, A10, W20, W10,...
Pentax Optio S10 cannot take photos in flash mode
HI there check the battery first. Red light blinking in working mode when the battery not having enough power for flashing. So i suggest you charged the battery fully or if its old then replaced it. Thnaks.
Apr 04, 2010 | Pentax Optio S10 Digital Camera
My camera pentax optio wp wont turn on. though is
If possible, check the charger output or the charge status of the batteries with a voltmeter. That will narrow the field for you. If the charger and batteries seem OK, your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your camera may have a problem that requires professional repair.
Oct 21, 2009 | Pentax Optio E40 Digital Camera
E10 and s45 same problem
the batteries needed for the cameras are quite high powered
though the batteries show that they are fuly charged most times they have lost their actual capacity of power storage in them so not being able to supply enough to start the camera best way to test this is to start the camera on preview mode if this works then you will need to buy a new set of rechargable batteries, i would suggest to take batteries in the range of 2000MAh to 2500MAh and
the normal batteries will not be able to sustain long even for normal lens open and retract functions, instead of normal batteries try LR6 varieties (eg: Duracell, Energizer, etc)
Jul 25, 2009 | Pentax Optio S45 Digital Camera
Switching off as if battery is depleted when the battery is newly charged
I called Pentax and they said it's a known problem and the lens needs to be re-synchronized. They said this is usually caused by dust in the lens.
I have to send the camera to : -
Pentax U.K. Limited
Pentax House
Heron Drive
Langley
Slough
SL3 8P
It's a free repair if you bought the camera less than a year ago o/w they will send you a quote for the repair.
Aug 22, 2008 | Cameras
Pentax Optio M20
Maybe.
But it does seem to be a lens problem. Possibly the lens is out of sync as mentioned in another post here.If there is a grinding, the lens is probably damaged by dirt or sand.
Make sure the batteries or battery is fully charged.
May 31, 2008 | Pentax Optio M20 Digital Camera
Pentax Optio 50L Lens Error
Found this post - I have the same issue..
Anyone know about this?
Apr 27, 2008 | Pentax Optio 50L Digital Camera
Pentax Optio M30 won't turn on!
MY CAMERA WONT TURN ON... I HAVE CHARGED THE BATTERY SO I KNOW IT IS CHARGED...ANYONE HAVE THIS PROBLEM.?
CHERI
Feb 25, 2008 | Pentax Optio M30 Digital Camera
Pentax Optio T20 Digital Camera Logo
224 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
