Question about Microsoft Computers & Internet
32gb sahara flash drive only showing on device manager not on my computer
Driver is loaded, it pings on start up but is not seen. was used with same machine for back up files
    Novelist:
  • 187 Answers
Some USB ports fail to recognize certain flash drives. i have a dell that does not show certain flash drives when inserted. but some are 2.0, some are 3.0 usb ports so you have to realize that some OS versions may recognize some USB's depending on versions.
Posted on Dec 27, 2015
  • 10 Answers
SOURCE: device manager shows error in sm bus controler
goto to system devices look for the question mark, right click, and try reinstall the drivers again, this should normally work and reboot your machine and the drivers should be there.
may be the bus driver you are trying to install may not be compatable for your machine, check with the user manual to see what bus derivers you can install
Posted on Nov 18, 2007
SOURCE: pen drive not showing in window explorer
Thanks Rado.Your solution Works for me
Soura
Posted on Jan 02, 2008
Joash
  • 31 Answers
SOURCE: I can not play audio files
In the windows media player go to > now playing - more options - devices - speakers then changed the audio device to use your soundcard.
Also, uninstall any other players, they usually interfere with each other.
Posted on Mar 28, 2008
SOURCE: audio
i can`t lisen any thing from my speaker
Posted on Oct 05, 2008
keshy
  • 77 Answers
SOURCE: Some USB-connected devices don't show up as drives
Hey Kunal,
This is not unusual windows will only recognize the standard memory cards not any custom ones or inbuilt ones. For example if your device is using a SD memory stick it will show up in explorer however if you are using a device that has a copyright or custom it wont. I am surprised the digital camera is doing the same thing as thy use mmc cards which are standard and should show up.
With these devices when you connect it to a pc you would get an option on the lcd on the device that would need you to confirm connection. may be thats what you were looking for. If you have a memory card reader you can try using that as well.
Please rate if this fixed it or was helpful.
If i missed something let me know.
Posted on Feb 11, 2009
"USB device not recognized" error message MacBook Air
The drivers must be up to date and written for your device. If there are no drivers, it will not communicate and thus it may look like it is working and in place, but the linkage is not there.
Mar 17, 2014 | Kingston DTU30G2/32GB 32GB DataTraveler...
Kingston DT 3.0 32gb not recognized by computer
if u use Windows -> right clik on my computer -> manage-> and then disk managment-> find the disk and activate it, probably offline, do not click on format if there is data on it !
Nov 28, 2013 | Kingston DataTraveler R3.0 32 GB USB 3.0...
Can't format kingston datatraveler G3 *GB
click start click on my computer you should see your usb drive
right click then select format
another way is to control panel administrive tools computer management disk management right click on your drive select format
hope this helps
Jun 20, 2012 | Kingston DTIG3/32GB 32GB DataTraveler G3...
Kingston DT101 32GB Not showing/detecting the device in system windows7?
click start right click on computer select properties then on device manager scroll to universal serial bus controllers you might see a yellow question exclamation mark ? ! or a red X
this will mean the driver needs to be updated
right click to update driver
if your computer came with a motherboard disk the drivers could be on it
hope it helps
Mar 03, 2012 | Kingston Computers & Internet
I purchased kingston 32GB data traveler 101, but its not showing the device in system, where as other pen drive showing.
strange if one is showing and the other is not
are you using the same usb port
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver
hope it helps
Mar 03, 2012 | Computers & Internet
Kingston 32GB Data Traveler 101 Removable Disk is not available Disk Formate the 32GB Disk
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
ports(com&lpt)right click update driver if this fails to fix the problem
click start click on my computer you should see your drive
hope this helps
Jun 12, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
32GB Removable Disk is not available Disk Formate the 32GB Disk
hope this helps ya
My 32 gb flash drive only show 8mb
Hi
Plug ur pen drive. Rt click my computer and select manage. Under storage select disk management. check state of drive here.
Delete the partition an perform fresh format. ie deleting will term the space un-allocated, if OS does not detect 32GB here then the drive if faulty. Check on at least 2 PC before coming to this conclusion.
Also plug the device on the mobo USB and not on extended connector and see if it works.
May 28, 2011 | Computers & Internet
My Sandisk Ultra Backup Flash Drive will not load on Wondows 7 64 with a Rampage III motherboard.
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
hope this helps
May 20, 2011 | SanDisk 32GB Ultra Backup USB 2.0 Flash...
32gb data traveller not showing on pc
Open up Device Manager (Windows key, Pause Break or right click on computer and go to properties. Then on the left go to the device manager.
Attempt to find your Flash drive, it might have a (!) next to it. Right click it and click uninstall. After that, Click on the top Icon that says scan for hardware changes (computer with magnify glass) and it should see it. If not restart.
If you cannot see your flash drive in device manager then it something wrong with the drive :/
May 19, 2011 | Computers & Internet
Computers & Internet Logo
50 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
