Question about Gigabyte Computers & Internet
How to install bios on window 7 64 bit - Gigabyte Computers & Internet
I have sony vaio laptop window 7,64 bit with 500 gb harddrive having only one partition = c i want to make 4 partitions how can i make it without losing my recovery data default from manufacturer
Type Computer Management into the search box above the start icon. Select Disc Management, select the drive name you wish to adjust and right click on it. Select Shrink Size and select whatever size you require. When complete format the new partition.
Dec 24, 2014 | Sony VAIO Computers & Internet
Logithec attack3 devices not detected
Disconnect the divice uninstall the driver restart the laptop and then reinstall the driver again restart the laptop then connect the device it works.
Apr 03, 2014 | Video Game Consoles & Games
How do I restore the BIOS settings on my Cyberpower Windows 8 64-Bit Gamer Ultra 2150. I installed a new graphics card and went into my BIOS to change the setting and after I saved new settings I have no...
You should remove the CMOS battery from motherboard for 10-15 second and than put it again. When you change the graphic card, you shouldn't go to BIOS, just install the Driver for your new grapic card. bed355b8-0e7a-4736-bf41-c4eb95ebe7a5.jpg
Jan 26, 2014 | CyberpowerPC Gamer Ultra 2150 Desktop PC...
Bios problems
if your computer is 5 yrs or older it might not support windows 7 also you will need a minimum of 1 GB of RAM for 32 bit or 2GB of RAM for 64 bit to install windows 7
hope this helps
http://windows.microsoft.com/en-AU/windows7/products/system-requirements
hope this helps
Aug 19, 2012 | Computers & Internet
Usb port on presario F500 quit working, they are seen by device manager but will not reconize a flashdrive when incerted, a mouse or any thing else. Using win 7,64 bit t3500 cpu.
This should be pretty easy to fix. I have seen this many times before. Here's what to do:
Go into device manager and expand 'universal serial bus controllers'.
Start at the very bottom, and start deleting the usb root hubs one by one. You will lose your touchpad control at some point, as the touchpad is actually a usb device. One of thwo things will happen.
1. The usb hubs will automatically be re-detected and re-installed.
2. You will just lose touchpad control after deleting one of the root hubs. If this happens, then shut down using the power button, and restart. Th usb hubs will be reinstalled once you log back into windows. Please let me know if this doesn't fix it.
Joe
Apr 07, 2012 | Compaq Computers & Internet
I have a DELL Inspiron 1720 with windos vista. I am trying to install windows 7 but it is showing me this message: OEM Name : DELL INC OEM model: Inspiron 1720 BIOS version: Phoenis ROM BIOS plus...
You need to check the specifications of your laptop it may not be able to run Windows 7.
You need these specs:
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
Sep 17, 2011 | Dell Inspiron 1720 PC Notebook
Will not install os windows xp , do i need a 64 bit operating system or both, 32/ 64 is the processor 32/64 bit loaded os on another hard drive and it comes up to the boot but will not allow me into the...
Check your system bios to ensure that ata is your chosen hard drive for installation. if you attempt to install on the mother boards default of ahci wich is windows vista or 7 default it will not work in order to install windows xp you must choose ata. as far as weather a 64 bit install is necessary, 32 bit will work on both but 64 bit windows must be installed on a 64 bit motherboard.
May 29, 2011 | Mercury KVM800M Motherboard
Open Questions:
Computers & Internet Logo
16 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
