Question about Garden
1980 ford 1500 farm tractor torque specs
20 hp shibaura diesel cylinder head torque and connecting rod bearing torque
  • 701 Answers
SOURCE: torque specs for toyota tercel
Hello vienotkelly: The correct Main bolt torque is 42 foot pounds. The connecting rods torque to 29 foot pounds. The torque sequence for the head bolts and the correct way to tighten the bolts are attached to this reply. Thak You for using6bd0ae1.jpg FixYa. Roger
Posted on Apr 15, 2009
inspectmycar
  • 233 Answers
SOURCE: 94 mazda B3000 3.0L cylinder head torque specs
Step 1 torque to 59 ft pounds
2. Loosen one full turn
3. 37 ft pounds
4. 68 ft pounds
Use torque sequence below
Posted on Sep 17, 2009
  • 122 Answers
SOURCE: need cylinder head gasket torque specs.
looks like there is special sequence to reassemble and tightening, a quick note replace any bolts that have two punch marks.tighten as follows: x x x x x 10 4 2 6 8 x x x x x 7 5 1 3 9 torque all down to 15 ft lbs torque to 30 ft lbs plus 90 degrees. Good luck!
Posted on Sep 18, 2009
  • 181 Answers
SOURCE: torque specs for cylinder head on a 200 ford focus
  1. CAUTION: Always install new cylinder head bolts. NOTE: Lubricate the cylinder head bolts with Super Premium 5W 30 SAE X0-5W 30-QSP or equivalent meeting Ford specification WSS-M2C153-G prior to installation. Install the cylinder head assembly and tighten the cylinder head bolts in the following sequence.
  1. Tighten all bolts in a single sequence to 50 Nm
  2. Back the bolts off 1/2 turn.
  3. Tighten the bolts in sequence shown to 50 Nm .
  4. Rotate all the bolts in a single sequence an additional 180 degrees in two steps of 90 degrees each.
9 3 1 5 7
8 6 2 4 10 sequence for head
Spec for rod 38Nm
Posted on May 07, 2010
drsinister69
  • 2317 Answers
SOURCE: What is the right Torque Specification of the
Cylinder heat bolt torque:
Torque sequence --------- front | 7 3 1 5 | | 8 4 2 6 | --------- Step 1: Torque all bolts in sequence to 14 Ft/Lbs Step 2: Torque all bolts in sequence to 29 Ft/Lbs Step 3: Torque all bolts in sequence to 36 Ft/Lbs Step 4: in the sequence, loosen the cylinder head bolts three turns. Step 5: Tighten short bolt to 15 - 32 Ft/Lbs Step 6: Tighten long bolt to 30 - 36 Ft/Lbs Step 7: Tighten all bolt to 175- 185 degree note: Do not loosen all of the cylinder head bolts at one time. Each cylinder head bolt must be loosened and the final tightening prior on the next bolt in the sequence.
Main bearing torque:
Torque sequence: Step 1: torque bolts to 91 Ft/Lbs with the exception of the rear main bearing cap Step 2: torque rear main bearing cap bolts to 88 Ft/Lbs Step 3: torque brace bolts to 40 Ft/Lbs
Connecting rod torque:
Torque sequence Step 1: Torque to 29 Ft/Lbs Step 2: Turn an additional 90 degrees
Posted on May 18, 2010
Cylinder head for ford compact 1700 tractor FO 1.3 lt Shibaura LE8
Japanese made ...1979 - 1982 Hundred Compact Series...
going to be very tough find that two cyl head
try this ford compact 1700 USA supplier
https://www.almatractor.com/parts/ford1700tractorparts.htm
any chance to a retro fit a different engine same series
Ford 1700 engine
TractorData com Ford 1700 tractor information
Oct 18, 2016 | Ford Cars & Trucks
Flywheel torque spec's for 1983 Ford F-100
Could it be a F-150 instead?
Ford Engine Bolt Torque Chart Bolt Torque Spec Chart for Ford Engines
These specs are for stock-type bolts with light engine oil applied to the threads and the underside of the bolt head. Moly and other lubes offer reduced friction and increased bolt tension, which will affect the torque figure. If you use after-market performance bolts like ARP's, you should follow the recommended torque specifications.
260, 289, 302 Torque Spec.
Fastener Type Torque Spec Main cap bolts 60-70 ft-lbs Outer main cap bolts 35-40 ft-lbs. Connecting rod bolts (40-45 ft-lbs. for 289 HP & Boss 302) Cylinder head bolts 65-72 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs Oil pump bolt 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolts 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351W Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 90-100 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs. Oil pump bolts 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351C, 351M Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (45-50 ft-lbs. For Boss 351C) Cylinder head bolts 105 ft-lbs. (125 ft-lbs. For Boss 351C) Rocker arms (non-adjustable) Rocker arms (non-adjustable) 5/16in. intake manifold bolts 21-25 ft-lbs. 3/8in. intake manifold bolts 28-23 ft-lbs Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 9-12 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs. 360, 390, 406, 427, 428FE Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Crossbolts for 406-427 40 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (53-58 ft-lbs. For 406 and 427) Cylinder head bolts 80-90 ft-lbs. (100-110 ft-lbs. For 1963-67 427) Rocker arm shaft bolts 40-45 ft-lbs. Intake manifold bolts 32-35 ft-lbs. Oil pump bolt 12-15 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 429-460 Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 140 ft-lbs. Rocker arms (non-adjustable) 18-22 ft-lbs. Intake manifold bolts 25-30 ft-lbs. Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs.
Dec 18, 2015 | Ford Cars & Trucks
Torque spec's for the fly wheel
Dec 18, 2015 | Cars & Trucks
On a 3.8L what is the aspec diagram and tourque for the racker arm
Hi Juan, I'm AL the owner of Big As Auto Repair
Below is the torque specs for the rocker arm as you requested.
SPECIFICATIONS - TORQUE
DESCRIPTION N·m Ft. Lbs. In. Lbs. Camshaft Sprocket-Bolt 54 40 - Camshaft Thrust Plate-Bolts 12 - 105 Forged Connecting Rod Cap-Nuts 54 +¼ turn 40 +¼ turn - Cracked Connecting Rod Cap-Bolts (Refer to 9 - ENGINE/ENGINE BLOCK/PISTON & CONNECTING ROD - INSTALLATION) Crankshaft Main Bearing Cap-Bolts 41 +¼ turn 30 +¼ turn - Crankshaft Main Bearing Cap Cross Bolts (3.8L) 61 45 - Crankshaft Oil Seal Retainer Rear-Bolts 12 - 105 Crankshaft Damper-Bolt 54 40 - Cylinder Block Drain Plugs 20 15 - Cylinder Head-Bolts (Refer to 9 - ENGINE/CYLINDER HEAD - INSTALLATION) Cylinder Head Cover-Bolts 12 - 105 Flex Plate to Crankshaft 88 65 - Engine Mounting (Refer to 9 - ENGINE/ENGINE MOUNTING) Powertrain Torque Strut 54 40 - Exhaust Manifold-Bolts 23 - 200 Exhaust Crossover Pipe-Bolts 54 40 - Intake Manifold - Lower-Bolts 23 - 200 Intake Manifold - Lower Gasket Retainer-Bolts 12 - 105 Intake Manifold Upper-Bolts 12 - 105 Lifter Yoke Retainer-Bolts 12 - 105 Oil Filter Attaching Fitting 54 40 - Oil Cooler Attaching Fitting 27 20 - Oil Filter 20 15 - Oil Filter Adapter-Bolts 28 - 250 Oil Gallery Plug 27 20 - Oil Pan-Bolts 12 - 105 Oil Pan Drain-Plug 27 20 - Oil Pressure Switch 23 - 200 Oil Pump Cover Plate-Screws 12 - 105 Oil Pump Pick-up Tube-Bolt 28 - 250 Oil Dipstick Housing-Bolts 48 35 - Rocker Arm Shaft-Bolts 23 - 200 Spark Plug 16 12 - Thermostat Housing 12 - 105 Timing Chain Case Cover -M8 Bolt 27 20 - -M10 Bolt 54 40 - Water Pump-Bolts 12 - 105 Water Pump Pulley-Bolts 28 - 250
Should you need extra help visit my website here: http://www.bigasautorepair.com/
Apr 15, 2015 | 2005 Chrysler Pacifica
What the torque specs. For a 2002chevys10 4.3vortex mains and rod bearing
Torque Specs Database
Type: Dim: Length: Head: Nut Grade: 20 Ft-Lbs 240 In-Lbs 27.12 N-m Connects: Connecting Rod To Engine Block Years: All Vote Record: Vote Note: Vortec - Rod Cap Nuts - 2 Steps: 20 FtLbs; +70degs
http://ww2.justanswer.com/uploads/ZZdaryl/2009-06-14_153454_torque.pdf
Main Bearing Cap Bolt 4.3L Step 1 15 ft lbs (20) Step 2 Additional 73 Degrees
i don't know if that's correct for main bearing caps since another link states it's much higher
4 3 Vortec Piston Specs eHow
hopefully a GM guy will chime in to confirm the main bearing torque
the rod bearing torques are the same on all the other links
Mar 25, 2015 | 2002 Chevrolet S-10
Need torque settings for mazda xa 3.0l diesel 4 cyl
con rod bolt tension is 55-60ft/lbs
crank shaft main bearings is 80-85 ft/lbs
fly wheel bolts95-100 ft/lbs
crank shaft pulley nut 94-123 ft/lb
head studs tension 80-95 ft/lbs working in a spiral direction from no 1 stud directly in the centre of the head. Pull down in 10ft/lb increment starting at 20 ft/lbs
valve clearance is .010" both valves cold but after warming engine and re-tensioning the head studs re set valves to .012 both valves
injector retaining nuts tension12-17 ft/lbs
Dec 25, 2013 | Saab 9 Cars & Trucks
..torque specs. rod bearings. f-350 2008 diesel 6.4
6.4L Power Stroke Diesel V-8 ... 350 hp @ 3,000 rpm. Torque. 365 lb-ft @ 3,750 rpm. 457 lb-ft @ 3,250 rpm ...
Feb 24, 2013 | 2008 Ford F-350 Super Duty
I need torque specs. for rod bearings and main bearings for 3.8L GM engine 1979 to 1981
FOR 1979 ROD BEARINGS TORQUE IS 40 FT LBS MAIN BEARINGS 100 FT LBS. FOR 1981 MODELS. ROD BEARINGS TORQUE IS 40 FT LBS. AND MAIN BEARINGS 100 FT LBS. CYLINDER HEAD BOLTS 80 FT LBS. CRANKSHAFT PULLEY BOLT 225 FT LBS. FAN PULLEY TO BALANCER 20 FT LBS.
Jun 02, 2011 | Buick Century Cars & Trucks
I need torque specifications for a 93 Saab 9000 engine: Head bolts and also for the connecting rods Thank You JLM
YOU NEED TO MAKE 3 PASS FIRST PAST TORQUE CYLINDER BOLTS 44 FT LBS. SECOND PASS TORQUE CYLINDER BOLTS 59 FT LBS. IF YOU HAVE 17MM HEAD BOLTS TORQUE TO 70 FT LBS.THE THIRD PASS TIGHTEN ALL CYLINDER BOLTS ADDITIONAL 90 DEGREES. ROD BEARING BOLT TORQUE TO 35 FT LBS.
May 10, 2011 | Saab 9000 Cars & Trucks
How to torque engine heads,rod bearings and main bearing by foot pound?
cylinder head bolt torque for a DOHC Turbo 3.0L V6
92 ft lbs.
cylinder head bolt torque for a Non-Turbo
76-83 ft lbs.
main bearing caps
mark on head of bolt "9" 59 ft lbs.
mark on head of bolt "10" 70 ft lbs.
connecting rod nut 38 ft lbs.
Sep 07, 2010 | 1992 Mitsubishi 3000GT
Garden Logo
63 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
