SOURCE: rear derailleur will not stay in new gear. keeps
What kind of gear switcher do you have?
It sounds like the problem might be there...
That should be the part that keeps your chain in the proper gear..
Does the Switch stay in place or does it go back?
if it does....
Is the cable properly tightened to the raer derailleur?
If so is the cable crimped to loose so that there is to much **** in the cable?
SOURCE: what is the adjustment procedure on a shimano deor
Try this first:
Shift into the small ring and release the cable. Pull it tight (with pliers) and re-tighten the cable. It should shift now. If it doesn't, the solution is a little time consuming, so i apologize in advance.
First,
flip your bike onto the bars and saddle. Now shift into the small
chainring and your lowest cassette cog (the largest in number of
teeth). Release the cable from the front derailleur and set the
adjustment knob for the front derailleur to its center point. You
should find it on your shifter. Now adjust the "L" setting on the
derailleur while turning the crank so that its stop sets it in a
position where it just skims the chain but does not touch it. Now pull
the cable taut and re-clamp the cable. Shift into the middle ring and
shift the rear derailleur to its highest and lowest gears, making sure
the chain does not rub the front derailleur. If it does rub (it will be
in either the lowest or highest cog on the cassette), adjust the front
derailleur by way of the adjustment knob to clear the rub. Then shift
into the big ring and you should have no problem. Set the "H" stop if
necessary.
SOURCE: Shimano 105 10 speed rear derailleur doesn't shift
Try this:
Set your shifter to the highest gear while turning the crank. If you have to, manually set the derailleur to the highest gear.
Release the derailleur cable by loosening its screw.
Pull the cable taut and re-tighten the screw that clamps the derailleur cable.
You should be all set.
The cable stretches over time. This can be avoided by "pre-stretching" new cables. To do this, simply shift into first gear and pull the derailleur cable away from the frame (where you are able to do so) fairly hard, several times. Then you just release and re-tighten the cable like mentioned in the steps above.
Happy riding!
matt
[email protected]
SOURCE: my front derailleur won't shift into the lowest
check the cable first ,take out the cable in the housing to see if the cable is good,then put it back ,then check the adjuster screw (there is a 2 screw in the front derailleur adjust it.
