Question about Dell Dimension 4600 PC Desktop
I have an older dell tower and when the computer is on it has a blinking yellow light where the power is supposed to be green.
    President:
  • 2,653 Answers
Is this a repeat question?
Posted on Jun 19, 2009
I have a Dell Dimension E521. When I cut the power on everything comes on including the monitor, but the monitor will stay black. It does say something about power save hit any button but the screen
A solid green light means the computer is operating normally.
A solid yellow light indicates the power supply is operating normally but the computer is not processing data.
This could mean there is a problem with the CPu or another component on the motherboard.
((A blinking yellow light indicates the power supply is receiving power from the wall, but not functioning properly.
This generally means the power supply itself is bad and should be tested or replaced.))
A blinking green light means the computer is in standby mode.
You should consider visiting Dell Support and downloading the manual for your
your Dell computer. So use the LED power light codes if your Dell computer has them.
hope this helps
Sep 10, 2012 | Dell Dimension E521 PC Desktop
I got dell optiplex 755 desktop computer in the power supply unit at the back there is a small button and a green light what are these for??
It help diagnose problems with your computer
A solid yellow:- the power is operating fine but your computer not processing data. This could mean there is a problem with the CPU or another component on the motherboard.
A blinking yellow light: power supply is receiving power from the wall, but not functioning properly. This generally means the power supply itself is bad and should be tested or replaced.
Jan 29, 2012 | Dell Optiplex 755 Desktop Desktop Computer...
My Dell Optiplex 330 does not turn on,there is a yellow led light blinking
If the power light is blinking amber, the computer is receiving electrical power, but an internal power problem might occur.
Ensure that the voltage selection switch is set to match the AC power at your location, if applicable.
Ensure that the processor power cable is securely connected to the system board.
You an use the following link to know how to open the computer tower
User manual
Thanks for using Fixya
Proton
Oct 13, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
There is a green blinking LED on my motherboard, and my computer is not turning on. What is wrong? Someone told me to ... Hi, i have a dell Optiplex 780 running windows xp, the computer button is just...
If you are referring to the green light on the system tower and is blinking the problem could be the system is in stand by mode.
Turn off the computer by pressing on the power button on the system tower for 10 seconds.
Disconnect the black power cord at the back of the system tower and then again press the power button on the tower for 10 seconds. There would be no activity on the tower when you do this.
Reconnect the power cord and then power on the computer to see if the issue is resolved.
Proton
Aug 30, 2010 | Dell XPS 200 PC Desktop
I powered off my Dell Optiplex 745 as normal one night before bed. The next morning I went to turn it on and it just displayed a yellow flashing light where it normally displays a green light. The fan did...
This model has been having problems with the motherboard that can cause that exact problem, Not powering up, Flashing yellow light or locking up right after booting up. The first thing to check is parts called capacitors on the motherboard. We have an article posted on our web site at: http://www.ccl-la.com/blog/index.php/dell-optiplex-745-repair/ that has detailed pictures and information about this issue. The pictures are of the tower case Optilpex 745 but the board is the same for your unit. Check it out and see if your board has this issue. If you can solder then you should be able to fix it yourself for less than $15.00 If your board does not have the bad capacitors then the blinking yellow light is a failure in the power supply unit.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Aug 28, 2010 | Dell OPTIPLEX 745 PC Desktop
When I power up my dell optiplex 360 the power light should be green but is staying yellow help
if you light is blinking yellow then you might have two problems
or one , your power supply is defective even though its powering on. that is a dell defect, or *********** board is bad..
my best guess is your power-supply..
Aug 16, 2010 | Dell OptiPlex 360 Desktop Computer
Dell dimension e310 desk top will not power on
If the POWER Button on the TOWER is blinking AMBER (Yellow) then the most likely failure point is the POWER SUPPLY in the Tower.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817226001
Dec 21, 2009 | Dell Dimension E310 PC Desktop
Dell computer won't come on...only get yellow light, no blue
If the Tower has a blue light, then it appears to be working, I'd check the cable connection to the video port on the tower and the INPUT Select Button of the Monitor (I've seen people change the input select to DVI when connected analog for example)
Sep 14, 2009 | Dell E176FP 17" LCD Monitor
Computer will not turn on
  • Blinking Amber/yellow: Initial state of LED at power up.
    Indicates system has power, but the POWER_GOOD signal is not yet active.
    If the hard drive LED is off, it is probable that the power supply needs to be replaced.
    If the hard drive LED is on, it is probable that an onboard regulator or VRM has failed.
Apr 28, 2009 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 PC Desktop Logo
148 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
