My screen is bowing can someone tell me the part #for a covergence power supply or were its located in my tv so i can find part and were are the fuses
SOURCE: Help with RCA projection TV P46812BL (chasis ptk195AA)
your tv requires STK730-020 quantity 02 and you can replace it yourself if you know soldering well.
If you wanna replace complete convergence board, its available Part Store and price is $119
Regards,
SOURCE: RCA big Screen
Convegence problems are so common on these sets. The bowing picture indicates to me that you have lost complete convergence. Now the first question that i always ask is do you have the convergence option under setup in the customer menu. If you do not then i say congratulations this is a simple inexpensive repair if you can solder a component. this is known as the fl231 problem and i have a article relating to the problem under my profile in tips and tricks section. that goes into detail on how to repair this problem.. If you do have the convergence option then we wil have to go further into troubleshooting. there are three possible cuircits that effect this.. if you do have convergence. try autoconvergence option and see how far it gets. let me know how it goess.
SOURCE: i have a rca model#d56w20 and the screen is bowing
You probly have a covergence power supply issue. The board is not available the last time I
tried to get one. If it has a stkXXX_XXX type regulator IC it is easily repaiable. I would suggest
a professional tech to repair it though
