Question about AO Smith Pool Pump Motor Hayward Swimming Pool Pump Full Rated Motor / Cen
New pool pump motor governor keeps tripping under load
New AO Smith motor for pool pump runs correctly with impeller attached on the bench. When installed, it also runs fine until priming is completed and then it keeps sporadically tripping out every second and restarting from the governor switch. I checked rotation, wire leads, and the correct 230 volt setting. Getting frustrated.
  • AO Smith Master
  • 1,363 Answers
READ ALL .. sounds like your power is 120 v, check with meter on L1-L2 . if it says 230-240v the switch might be lose or there is just way too much back pressure OR the impeller is too big for the motor OR the shaft seal is installed wrong, when spinning the impeller by hand "snap of the wrist " it should almost make a full turn.
remember to vote or reply... Jay the pool pump repair guy in longwood Fl
Posted on May 08, 2014
    Renaissance:
    An user who is expert in 3 categories / brands.
  • AO Smith Master
  • 1,448 Answers
Try priming in service mode or backwash mode then change over to automode
Posted on Jun 08, 2014
    New Friend:
  • 77 Answers
It sounds like you have 120v available to motor instead of 220v.. Double check your supply voltage to the motor. This arrangement would cause the motor to appear to work on the bench but would not work under a load. hope this helps.
Posted on May 10, 2014
3 Suggested Answers
john224
  • 1378 Answers
SOURCE: My pool originally had a
Is it going to run on 230V then? If so you would normally use red and black. The white wire should be a neutral and the ground wire is obviously ground.
Do you have a meter you can use to confirm the voltage between the wires? If you do you'll want to start with red and white since you seem to think black was not being used before. If the voltage reads 230 and the motor is set up for 230 then attach one wire to L1 and the other to L2...it will not matter which is connected where as long as one is on each terminal. Insulate the black and ground the ground lead to the motor ground screw.
If the voltage is not 230 between those two check between red and black. If that is the 230 then insulate white and put red and black to L1 and L2.
John
Posted on May 24, 2011
MOTORWIZJ
  • 1363 Answers
SOURCE: Pool Pump Motor (AO Smith 2HP 56Y CX) won't turn over when switched on. Makes slight humming sound. Removed the motor from pump housing. When I spin the impeller when powered on, the motor starts up
3 THINGS QUICK.. RUN CAPACITOR THIS IS LOCATED ON TOP OF MOTOR HAVE IT CHECKED. OR START SWITCH DIRTY OR STAR CAPACITOR BAD.. SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING.. WARNING THESE CAPACITORS HOLD HIGH VOLTAGE AND WILL NEED TO BE SHORTED ! USE A DRY RAG AND COVER CAPACITOR THEN SHORT WITH SCREWDRIVER
Posted on Dec 28, 2011
New ao smith pool pump motor keeps tripping out under load
check the breaker might be weak possibly from previous pump motor also if it was hooked up incorrectly at first might have done damage to motor windings
Apr 17, 2014 | AO Smith Pool Pump Motor Hayward Swimming...
Switched to new AO Smith B230SE motor for pool pump. Old motor had left-hand screw that held impeller to shaft. New motor does not have an opening for screw. Will impeller be fine without screw?
Did you try the Century A.O. Smith B230SE motor without the center screw? I'm having the same problem and I'm asking the reseller for advice. It would be great to know if I need the center screw is required? The impeller screws on the shaft, but is the center screw required?
Sep 17, 2013 | A.O. Smith SQ1102 Pool Pump Motor
How to remove impeller
i think they screw on and the screw only locks it in place
Mar 22, 2012 | AO Smith SQ1152 Pool Pump Motor
Dec 26, 2011 | AO Smith Pool & Spa
I just had an ao smith pool motor installed, USQ1152, and it is running at 12.5 amps when its max is 9.5 amps. We checked it at the motor power connections and it read 242 volts drawing 12.5 amps. We...
You should be able to see on the tag "RLA" which is running load amps. It should not exceed this amperage. Could the motor be going the wrong direction? If its going the wrong way, that exactly how it would react.
Jul 15, 2011 | A.O. Smith SQ1102 Pool Pump Motor
Where I can buy the A.O Smith 3/4 HP pool pump impeller?
You'll need information from the pump that the AOSmith electric motor is attached to in order to get an impeller or any other pump parts. If there is no nameplate for the pump are there numbers on the impeller you need?
John
Mar 03, 2011 | AO Smith A O Smith Motors A O Smith 3/4hp...
Need ao smith replacement motor for anthony pool pump not sure what motor fits that pump
a rebuilt motor is the cheap way $85 ,new around 200, the impeller will need to be ID to get the right size motor. search for your local pool pump repair guy with free motor testing, use your zip code in the search. you might get your old motor rebuilt and thats even cheaper .. CLEAN POOL IS A SAFER POOL .. VOTE COMMENT .. thanks jay
Aug 16, 2010 | AO Smith Pool Pump Motor 1HP Square Flange...
1 HP electric motor hums but not turning.
check for a re-set button somewhere on the motor housing.
May 02, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
My new AO Smith 2HP pool pump won't pump water, just hums
I'm guessing that you replaced the motor that goes to the pump, not the pump itself. You know the motor works just fine. Is the motor rotating in the correct manner(clockwise or counterclockwise) in relation to the rotation of the pump? Have you checked the pump to see if the impeller is working/rotating? Is the motor hooked up to the pump correctly, so that the motor is turning the impeller? Are all connections to the pump tight, so there are no suction leaks? Have you primed the pump and purged it of any air locks?
Aug 11, 2009 | AO Smith 2 HP 115/230V 56C Replacement...
AO Smith Pool Pump Motor Hayward Swimming Pool Pump Full Rated Motor  / Cen Logo
80 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Larry Maranto
john h
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
