Question about Pool & Spa
My pump will not come on only hums was working
  • 4 Answers
Especially at the beginning of the season, the pump might be a bit 'frozen'. Try tapping it with a rubber mallet or something similar to 'unfreeze' the mechanism. That's worked for me!
Posted on Jul 13, 2009
  • 10,865 Answers
Your pump will have to be either rebuilt or replaced. Look in your local yellow pages under pump repair.
Posted on Jun 19, 2009
Fisher&paykel ,smart drive excellence 7 .5 ,the washing machine stopped working during the pumping out of the water.no power on the top panel and a slight humming noise
What is it? No power to panel or slight humming sound which indicated there is power? Can't be both. I would suggest that the humming sound if you put it on spin, will be the drain pump trying to go. If pump is left humming like that it will get hot & shut the power off until it cools down again. Pump hums when it has a blockage & can'y spin. Clear the blockage.
Dec 29, 2016 | Fisher and Paykel Washing Machines
I have a Speck Pump, model E71, only a year old. It suddenly stopped working - it was fine at the start of the season. The problem is that it just hums when turned on.
Since it hums it has power. I believe there is a start capacitor on it, that or the start switch may have failed.
Speck Pumps Pool Pump Parts
usa speck pumps com
have Speck Pump model E71 only year old It suddenly stopped working it was...
Speck Pumps Pool Products Inc
Jul 02, 2016 | Speck Pumps Pool & Spa
Ive got power, hot and cold to my existing pump and shower, but the pump doesn't start, just makes a whirring noise.
Above Ground Pool Pump Won't Start or is Humming & How ...
? 6:16
https://www.youtube.com/watch?v=RH78q36liks
Apr 15, 2014 - Uploaded by Above Ground Pros
Above Ground Pool Pump Won't Start or is Humming & How to Fix It ... Pool Motor - Humming-Loud Noise ...
How to fix your pool pump from humming - YouTube
? 2:43
https://www.youtube.com/watch?v=3v2v6aDDq9A
Mar 25, 2013 - Uploaded by James Hayward
Do you have a pool pump not priming (pumping water) andmaking a humming noise ... not only give a ...
pool pump makes humming noise and does not pump - Trouble F
Dec 08, 2015 | Home
Car not getting gas in line
Brenda I believe that your fuel pump has gone to be with the car gods. You can check by disconnecting the fuel line AFTER the pump and having someone pump the accelerator if there is no fuel out then congrats - you found it!
Aug 28, 2015 | 2002 Cadillac Escalade Ext
My water pump is only humming not working
the humming means the power is getting to it, but for some reason it is not spinning, if it ran dry too long the impeller may have melted.
Dec 26, 2014 | Goulds Pumps Pump Centrifugal 1/2hp
We have a little pump to pump water from fruit cellar. It was working, but now just hums and doesn't pump? Any ideas?
try to spin the impeller with a screw driver if it is accessible. if not unplug it and take it apart and spin the impeller to free it up. clean all the gunk out while you are in there. put it back together and plug it in. don't let it hum with out pumping it will burn up.
Dec 09, 2014 | Cars & Trucks
What are the side effects over years of use
Ball Bearing needs to change.there is inside the pump a mechanic seal that with the time, leaks water and rust the ball bearing balls and making rusted the shaft .
The pump at this time gets Humming when works.
Pump humming or making noise is not a good working pump.
must be quiet without noise
Aug 19, 2014 | Pool & Spa
Motor wont crank and new fuel pump not humming. lights work.
HAVE THE BATTERY TESTED FIRST, NEVER IGNORE THE OBVIOUS.
Aug 31, 2012 | Cars & Trucks
Pump hums when switched on but does not work more than 20 seconds
hi i had the same problem with my booster pump motor it hum but did not turn. to make a long story short see if there is a metal cap on the back of your motor if there is pry it off and you should get to see the shaft turn the shaft with a screwdriver if it has a notch in it or if it don't turn the shaft anyway you can and make sure it turns easy. my shaft was tight as hell but i got it to turn and it started right up again and i had no problem. the hum means it is stuck and it shuts off because the breaker is tripping and after a few seconds it will click back on again, hope this helps
Jul 06, 2009 | Emerson Pool & Spa
I think that my fuel pump won't work because i can't start the engine anywaymy car is a dodge sprinter diesel 2007 (v6 , 3.0 l )
place key in ignition. turn to acc ,make sure radio is off listen for small hum it last about 15 to30 sec if you hear hum pump good . no hum check fuse if good more than likey bad pump. check if it has a glow plug
Mar 29, 2009 | 2007 Dodge Sprinter
Pool & Spa Logo
814 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
