Question about Baby Lock Espire
Espire baby lock won't make buttonhole
Will not make the buttonhole, thread bunches up
  • 323 Answers
SOURCE: ESPIRE SEWING MACHINE - MODEL ESp baby lock
Take it back to where you had it repaired and ask the dealer to make it work under his warranty. Maybe he can tell you exactly what's wrong with your machine. Usually it is a pressure problem or the feed dogs are filled with lint or they don't rise high enough above the needle plate to work. Take off the needle plate and check them.
sewman7
Posted on Jul 18, 2008
SOURCE: Instructions for threading Baby lock eclipse BLE1LX for 2 thread sergering
I have just learned this :)
Either needle thread may be engaged for 2-thread serging.
1. Open the front cover and cutting blade cover, cut the upper looper thread just above the threading guide ( this is plate that has two holes for the threads) Raise the presser foot and pull out the clipped thread from under the foot. Remove upper thread from the machine (or you can leave the cone thread on, it doesn't matter).
2. Rotate the handwheel to bring the upper looper to its lowest position.
3. Rotate the subsidiary looper up and to the left, then slip the end into the upper looper thread eye from backside.(this sounds complicated, yes? but it is very simple : the looper has a counter part that is spring-locked to move from left to right and right to left. This is the little claw-looking part of the looper that when in the postion to serg with four threads is to the right side of the looper. It looks like a scorpion's tale. If you can't figure which part it is, use your finger to probe the looper and you'll feel it give a little. This part needs to be moved to the left - it will not slide over, but swing up and over and down, like an arch. Then, where the thread comes out of the looper is where you want the little claw-like part to hook into.)
4. Close the covers. Decrease the needel tension - this depends on what the stitch length is. Stitch length: 2-3, stitch width: 3.0 = L needle n/a, R needle 1; upper looper n/a, lower looper 5
stitch length: 2-3, stitch width: 5.0 = L needle 0, R needle n/a, upper looper n/a, lower looper 3.5
Those are for a flatlock stitch - for a 2-thread rolled edge :
Stitch length: 0.5, stitch width: M = L needle n/a, R needle 4.5, upper looper n/a, lower looper 3.5
Stitch lenght: 1.0, stitch width: M = L needle n/a, R needle 4, upper lopper n/a, lower looper 3.0
If you have any questions, e-mail me at knowgodnofear@bex.net
Posted on Oct 28, 2008
  • 4 Answers
SOURCE: Baby Lock Evolve wire Looper threading tool
You have to get the replacement wires from a Babylock dealer, I did too then after sticker shock at the price of that wire I learned to make a thread cradle and use that to thread difficult threads no. Take about 24 inches of regular sewing thread and fold it in half, put the open ends (together, same legnth) into the jet air port and hold onto the loop end, press the jet air threader and it will thread the machine, insert the thread you want to use into the loop you have in your hand and pull it thru the machine using the ends of the thread you put thru the machine, sounds harder than it is and works all the time. No more spending $8 on replacement wires. You can use this method for all the jet air sergers.
Posted on Dec 07, 2008
Mongo32
  • 111 Answers
SOURCE: bottom thread bunching up, baby lock denim pro
bottom thread bunching up is actually the needle thread having no tension. Most likely the upper threading is wrong...
Posted on Jun 11, 2009
SOURCE: Thread tension on a Baby Lock BL90
I suggest changing both needles
and rethreading the machine
use a can of air that is used for computer keyboards on the inside
here's a link for parts to the machine and also has a manual
the manual should have information about the thread tension
http://www.sewingpartsonline.com/babylock-BL90-serger-machine-parts.aspx
Posted on Nov 02, 2012
Trouble shoot message. Thread is tangled. Needle is bent.
  1. Upper thread or lint is caught around the check spring.
  2. UNPLUG machine before you take off side cover!
If you don't know how to open side cover take it into your repair tech.
Jul 29, 2015 | Baby Lock Espire
Fo1 main motor speed error on my espire sewing machine
Kim,
Potentially bad news with this error - could need a new motor. On the positive side, if it hasn't been serviced for a fair while, or has been in storage it may be that the oil has dried out and the shafts are "dragging", slowing the machine. Thread tangles in the takeup leaver area can also cause this in some machines. I'd suggest take it into your local sewing centre for a service.
Feb 02, 2015 | Baby Lock Espire
Bobbin thread not catching
RETHREAD & TRY A NEW NEEDLE
Sep 29, 2014 | Baby Lock Espire
Babylock espire thread cutter stopped working
Your cutting blade is dull. It needs to be replaced by a experienced technician.
Cheers,
K
Feb 27, 2014 | Baby Lock Espire
Thread is bunching up on bottom. I have cleaned the machine, am using Madiera thread, new needle. I have a quilters choice, and have never had a problem before. I am working with lace and batiste.
My thread is bunching up on bottom of fabric and loose on the top, not sure when I am embroidering on my Baby Lock Essante machine, it just started, why?
Feb 04, 2011 | Baby Lock Sewing Machines
I lost the power cord to my baby lock espire when I moved. How do I get another one?
Contact a local dealer and they can order you one. If you don't have one in your yellow pages, I believe you can find one at Babylock.com
Aug 11, 2010 | Baby Lock Espire
Bottom thread bunching up, baby lock denim pro
Jun 10, 2009 | Baby Lock BL1556
Sewing Machines Logo
16 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
