Question about Canon PowerShot G10 Digital Camera
Black Monitor
The monitor is just black in all modes except C1 or C2.
My camarea monitor is black. what shoudl I do?
Posted on Aug 10, 2009
    Sergeant:
  • 321 Answers
Change the sencor circuit
Posted on Jun 19, 2009
I have a Chevrolet Cavalier year 2000, 2.2 OHV engine. I have to splice 38 broken wires that run to the PCM. I have found two purple wires and I do not know which ones I have to join. I need to have t
Hey Hugo, found this info. purple wire. I hope you don't need help with all 38 wires? autozone.com has free wiring diagrams, just register your vehicle and click on vehicle repair guides, find the link for wiring.
C1 is blue connector, c2 is black connector
c1-35 goes to brake switch
c2-61 goes to vss, vehicle speed sensor
c1-59 goes to datalink connector
c2-22 goes to pre converter 02 sensor
Jan 14, 2015 | Chevrolet Cars & Trucks
Black screen
The problem could be in the Monitor, Computer or Cable. Did you try to connect another monitor or can you try to connect another computer (maybe a laptop) to that monitor?
It's important to understand where to start.
Thanks
Nov 09, 2007 | ViewSonic E70fb (Black) 17 in.CRT...
What is going on with my camera screen ?
Have you tried it without a memory card in it? Or with a new memory card? Have you tried it while plugged into your computer? Is it possible that the Settings knob on top of your camera has been bumped hard enough to have possibly damaged an internal contact point below it?
Jul 15, 2014 | Canon PowerShot SX50 HS Digital Camera -...
Asus crosshair socket am2 motherboard not booting
Sounds like your monitor is bad. Try another monitor because if the video card was bad and the monitor is working you would get a No Signal message on the screen. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok, then your original monitor is bad. If the Borrowed monitor does the same as your original monitor and does not display anything, then there is an issue with your video card.
May 13, 2012 | Computers & Internet
When opened, the HP TFT7600 displays "PC entering power saving mode" and the screen goes blank.
disconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .
also check you warrenty its usually 3 years
Apr 08, 2010 | HP TFT7600 (Black) LCD Monitor
Lost instructions. How do you change value of tax
The c1, c2, & c3 are for exchange rates. To set the c2 exchange rate press AC. Press the MODE M/EX button till EXCH appears in the display. Press and hold the SET/% button for a few seconds until SET EXCH appears in the screen. Press c2, C2 SET EXCH RATE should be displayed. Enter the desired echange rate. For instance, today, Thai Baht is 32.8677. Once you enter your desired exchange rate, press the SET/% button.
To convert 100 dollars using the exchange rate you set on c2, make sure that EXCH is in the display by toggling the MODE M/EX button. Press AC, enter 100, press c1 then c2. Using 32.8677 as the exchange rate 100 dollars would be 3286.77 THB.
To convert 100 THB to dollars you would enter 100, then press c2 and then c1 yeilding 3.04 dollars.
You can also program a different exchange rate into the C3 button. To convert to that currency, you press c1 then c3. To convert from that currency, you press c3 then c1.
Hope that helps
Dec 23, 2009 | Casio MS-80TV Scientific Calculator
Does samsung monitor save power in sleep mode?Or will it just displays black all over the monitor?
yes, all monitors work directly with the cpu, the cpu sends message to the monitor, so if the system is in sleep mode, automatically the monitor stops work excepts the cpu comes up again then the monitor wakes, in a nutshell, a monitor is connected to power while in sleep mode but has no signal to function
Jul 16, 2009 | Smart Modular SV3170A
How do you use the Exch rate mode? I think I know
From CASIO FAQ:
How do change the currency rate?
When you press the [M/EX] key, it toggles between conversion mode and memory mode. You will see "EXCH" on the display when in conversion mode.
C1, C2, and C3 are three conversion rates. C1 is your home country currency, and so it is always set to 1. C2 and C3 are rates for two other countries, which you can change.
For example, if you want to set a conversion rate of $1 to 0.95 euros, here is what you would do (using C1 for US dollars and C2 for euros):
1. Press [AC]
2. Hold [SET/%] for about two seconds until "SET" appears
3. Press [C2] to select currency 2
4. Input the conversion rate (0.95) and then press [SET/%] to store it in memory
You can check the currently set rate at any time by pressing [AC] and then [C2].
How do I perform a currency conversion?
If you want to convert 100 euros to US dollars, you would do the following (assuming you are using C1 for US dollars and C2 for euros):
1. Press [AC]
2. Enter 100 and then press [C2]
3. Press [C1] to convert to dollars
4. To convert back to euros again, press [C2]
You can also perform a currency conversion within a calculation. How much in US dollars would five items selling at 100 euros cost?
1. Press [AC]
2. Enter 5 [×] 100 and then press [C2]
3. Press [C1] [=]
Jun 22, 2009 | Casio MS-80TE Calculator
Monitor Message = "No Signal"
see i use Compaq too
they don't generally except other modes
did u try that monitor with other pc where it worked
u should install proper monitor software ... u will found it from the cd given wit Ur monitor
Apr 24, 2008 | Mag Innovision lt456s 14" Flat Panel LCD...
Canon PowerShot G10 Digital Camera Logo
96 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
