Question about Morningstar ProStar Charge Controller, 30A, 12/24 VDC, w/ LCD Monitor, PS-30M
Red light flashing
My Prostar has red light flashing ,& led screen says 7 .9 volts. Self test indicates errors7,9 & 13. My volt meter says I have 14.2v at batt. terminals & at the lugs of the controller. All wire connections are good. Can you help with diagnosis Panama Terry
Westinghouse EW40T4FW will not turn on (no LED light indicator when plugged in either), how do I test what part of the power supply is bad?
.5 volts isn't right for any voltage, you need about 6 volts on the standby voltage on your set, see if you have that, if not try a new power board and see what happens.
Feb 04, 2018 | Westinghouse Televison & Video
Why did the red flashing alarm light stop flashing? Alarm and remote working fine
Most likely the 12 volt led light burned out.. all bulbs LED too don't last.. Find the 2 wires usually Black and red and check for 12 volts with the alarm set and if you have 12 volts,. you need to go to radio shack and see if they still have 1. 2 volt led bulbs.. Good luck.
Oct 23, 2016 | Toyota Cars & Trucks
COLEMAN INVERTER PMP1200 JUST BEEPS WHEN TURNED ON
It is most likely the low voltage alarm. Suggest connecting when the car is running with no load (110 volts not connected). If the alarm continues turn the unit off and on to reset.
Hope this helps?
Inverter Protection Features
• Short Circuit Protection. The inverter will automatically shut down until short is removed.
• Low Voltage Alarm. An alarm will sound when the voltage from the battery discharges to 10.5 +/- 0.5 volts DC. This is an indication that the battery needs to be recharged.
• Over Voltage Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the input exceeds 16.5 +/- 1 volt DC.
• Under Voltage Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the input is less than 10.0 +/- 0.5 volts DC.
• Overload Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the continuous draw of the equipment being operated exceeds 1200 watts or the surge draw of the equipment exceeds 2400 watts.
• Thermal Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the circuit temperature exceeds 150° F
Sep 13, 2016 | Electronics - Others
While I was charging the power chair all the indicater lights came on and with a block lights went from all green to 2 red flashing lights, w/ 2 red lights flashing I stopped and shut it off 4 five se
Two red lights blinking means the electronics on the chair think the batteries are low. Test the voltage on the holes marked 1 and 3. Hole 1 is positive and hole 3 is negative. Your meter must be set on DC volts and the meter leads must be in Common and Volts. If your meter has to have the voltage range set, put it on 200vdc. The red lights will blink if the voltage is approximately 22.5vdc or less. The green lights turn on about 24.5vdc or higher.
Sep 18, 2014 | Invacare Pronto M51 Power Wheelchair
How do I know it's charging
if you can get your hands on a volt meter attach the meter to the charger clamps, red to red and black to black, turn the volt meter to DC volts (20V scale on most) and turn on the charger. You should be reading at least 12V.
Dec 05, 2013 | JUMP START SYSTEM
The battery backup beeps and the service light is on. The battery tests good with a volt meter
This is battery related. On top of your unit is a battery pack with three colored led lights. You can tell what is going on by looking at these. This information is in your manual or here it is.
GREEN LED: All systems are normal. A solid LED light indicates the batteries are fully charged. A flashing LED indicates the batteries are being charged. NOTE: Batteries do not have to be fully charged to operate the motor unit. YELLOW LED: The motor unit has lost power and is operating off of the BBU. A solid LED with beep, sounding approximately every 2 seconds, indicates the motor unit is activating the door and is operating off of the BBU. A flashing LED with beep, sounding every 30 seconds, indicates batteries are low. Once the power is restored the BBU will recharge. This is indicated by a flashing green LED. RED LED: An error has been detected and the BBU will automatically shut off. The BBU will attempt to restart by reconnecting to the batteries. If the error is still present it will shut itself off again. This process will repeat every 5 minutes or until the error has been resolved. This is used to prevent further draining of the batteries. If a red LED remains on when the power is restored, and is accompanied by a beep sounding every 30 seconds, please call for service.
Dec 30, 2010 | Sears Craftsman LiftMaster Chamberlain...
12v 1.5amp fully auto, alwyas worked, hook up to battery 12v 8.5amph, alwys red light flashed, went solid while charging, then off, or flashed, and off cause was already fully charged. now red light just...
I really don't have any idea as to what you're talking about here other than a battery and maybe a charger. Seems as if you're saying that you have a 12 volt 1.5 amp automatic battery charger connected to a 12 volt, 8.5amph battery but the red light on your charger is blinking. The blinking red light indicates that the charger is not seeing a proper connection such as crossed polarity connection or simply a poor connection. You say that the battery voltage has dropped from 12.5 volts to 9.1 volts with the charger connected. If this is the case, the battery is badly discharged and the charger is not charging the battery for some reason. The charger may be bad but check the connections to make certain they are correct and good. If they are, I'd replace the charger.
Good luck
Steve
Aug 10, 2010 | Harley Davidson FXR Super Glide...
I have been charging my 2 million candle power spot light for last 2 days but full battery charge indicator (red light) does not flash yet. the led white light is working but the main lamp doesn't work....
It should take 10-12 hours, any longer the battery is no good, you can test the battery using a Volt Meter, the battery should be reading 12 volts, any less and the battery will need to be replaced. You can order a new one from Black and Decker, they purchased Vector in 2006, here is the link;
http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
Feb 13, 2010 | Vector 20 Million Power Series Spotlight
Upon power up, 3 red LEDs flashing rapidly continously, no power.
The control systems on power mobility equipment have a "prevent" circuit that immobilizes the equipment while it is plugged into a charger, so folks won't take off with it plugged into the wall outlet. When you turn it on when plugged into a charger, the display will flash constantly, or sweep constantly, depending on the manufacturer. This is normal. Your off-board charger should have a red light to indicate power to the charger, and another light for the charge status. Yellowish means it is charging, when it turns green, you are fully charged. If the status light is green all the time, that is an indication that the charger is not functioning properly, or that the batteries are below a chargeable state. Check charger output, which should be 26-28 volts dc, and each battery should show at least a 12 volt reading, but around 13.5 volts with a full charge. If one or both of the batteries drops below 12 volts after a short period of time, it's time for a fresh pair. Fully charge new ones before using the chair.
May 31, 2009 | Pride New Jazzy 600 Power Wheelchair by...
Charger red lite flashing. Camera comes on for one second and shuts off
Here's a copy from the owners manual:
■ Charging LED
Red LED is on = Being charged
Red LED is blinking = Charging error
Green LED is on = Carging is complete
● If the charge indicator blinks as red, it indicates a battery charging error.
- The battery is not properly inserted
- The terminals of battery are dirty or damaged
If the battery is inserted properly and the charge indicator continues to blink, contact the
nearest Samsung Camera Service Center.
Another charging error is when the batteries are so depleted, they won't charge up to 100% anymore = red light doesn't go out and remains on for too long, means get a new battery.
Jun 10, 2008 | Samsung Digimax i5 Digital Camera
Morningstar ProStar Charge Controller, 30A, 12/24 VDC, w/ LCD Monitor, PS-30M Logo
87 people viewed this question
Top Morningstar Electronics - Others Experts
Are you a Morningstar Electronics - Other Expert? Answer questions, earn points and help others
