Question about GE GSS25JFPCC / GSS25JFPWW Side by Side Refrigerator
We have a GE profile that we bought in 2007. We
We have a GE profile that we bought in 2007. We had a build up of ice in the lower left side of the refrigerator that leaks out of the bottom of the refrigerator. What is wrong with it. Thank you. Sandy
  • 111 Answers
Door gasket not sealing properly , detect were and with a blow dryer give some heat to the gasket and test a few days if doesnt work change gasket
Posted on Jun 19, 2009
  • 10,865 Answers
Hi Sandy, I can assist you.
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Frost buildup inside freezer door at ice dispenser
you are still not getting a seal on that flap. It sounds as if it may be warped. THe reason the frost and ice is building up is due to the flap not sealing there isn't any other reson for your problem. Good luck on your repairs
Dave
Oct 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE 24 Profile refrigerator: The freezer part
my refrigerator goes into auto defrost every 60hrs for 45 minutes or till the bi metal(defrost thermostat) says it had enough....recently i had ice built up on the coil because my defrost thermostat was stuck open...
ice builds up because the moisture that comes from opening the door or food condenses on the cold coil...tempurature of the coil is below 32 degrees which will ice up the condensed moisture...
defrost is timed to remove this build up
Oct 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE profile Artica side by side. I am getting a frost build up
Sounds like the dispensor flap is not closing completely , pulling outside air in . Using a flashlight on the outside of the flap , look inside to see if any light is visible . If so , then the ice flap plunger and solenoid will have to be replaced . Also , excessive crushed ice can also cause frosting .
Jul 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
I have a ge profile side by side refrigerator.
First thing...Take a good look at all the door seals. If they let air and a lot of moisture in, that can condense and freeze causing your problem.
Second...Manualy defrost your freezer and see if the problem re-occurs. It may be that someone left the door open once and caused the icing.
Jul 18, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
How do I reattache the DA61-03561 Guide Ice Full lever?
I have the same problem.
You will likely need a new one.
You can verify this as follows.
Remove the Ice catcher (using the lever on the right side).
There is a white Philips new the lower left front of the hollow area.
This screw holds down a long plastic cover.
After the screw is removed the cover can slide 1/2 inch towards the doors, then it can be removed.
Notice the little white hooks on the back that slide onto tabs (for when you replace this).
Reach to the back left of the hollow area - there is a cable that goes to the ice maker.
Free this cable.
On the top of the ice maker there is a little tab.
Press this tab and the ice maker can be slid forward 1/2 inch, then it can be lowered.
On the right side of the ice maker you will see a depression with a square depression in it, with a Philips screw in the center. This is where the Ice Full guide goes. You will likely notice it has broken off.
Jun 25, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water spout to ice maker frozen
defrost ice maker fill tube and replace duel water valve valve for i/m is sepping water
Dec 14, 2008 | GE Profile Arctica Stainless Steel Top...
Ice maker tube freezing up
  • change the water valve on the back of the machine.
  •  the water valve is slowly leaking water up to the icemaker where it freezes and builds up ice, blocking the water flow.
Jun 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE GSS25JFPCC / GSS25JFPWW Side by Side Refrigerator Logo
154 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
