Question about Toshiba E-Studio Office Equipment & Supplies
Admin password need the admin password to access scanned documents
2 Suggested Answers
jaylex
  • 417 Answers
SOURCE: How to enter authentication details for the Document Server ?
Hi there if you type in the internet explorer the ip address there you will have the machine information. Then login usually the login is
User name = Admin
Password = password or just enter leave blank
Once you are in there you will be able to change the details you need.
Cheers J
Posted on Jan 02, 2008
Reset Admin password NorStar T7316E Corded phone?
You NEED to get SYSTEM documents (Hard Copy or CD)
for NORTEL NORSTAR CICS before TAMPERING ...URL posted below...
Found on page 24:
Default Password Code is "admin" on your phone dial... Done by pressing 23646 on your phone dial...
Time feature is accessed by inputting **8463 = (**TIME)
Hope this helps...
(CAUTION: read & understand BEFORE programming)
http://phone.manualsonline.com/manuals/mfg/nortel_networks/compact_ics_61_system_coordinator.html?p=24
Feb 03, 2016 | NorStar T7316E Corded Phone
How do I reset the Admin password?
The default ID and password are "11111" and "x-admin" respectively. When accessing the administrator menus on the copier the code 11111 is used. I couldn't find a way to reset specifically.
I believe you should be able to access the Admin Menu by pressing the System button on the operator panel. A password is required to enter Admin Menu when Panel Lock Set is set to Enable. To Disable the Panel Lock you will need a password. The factory default panel password is 0000. Hopefully you haven't changed that. This procedure is described in the manual on pages 315 ff. I believe from there you can go in and assign a new Admin password if required.
http://www.fujixeroxprinters.com.hk/downloads/uploaded/CM215_UserGuide_Sec_c3b3.pdf
Jul 25, 2014 | Fuji Xerox® DocuPrint C3055DX Laser...
Wireless installation
Most routers may be accessed through an internal IP address. Open a browser and type 192.168.1.1 to see if you are prompted for a login to your router. If so, you'll need to find out the user name and password.
Some routers by default have a username/password of:
admin / <no password>
admin / password
If these do not work, the default username and password should be documented in the manual for your router. Or, you should be able to find it online in various forums.
Once you're successfully logged in to the router's console, you should be able to set a password to access it. This feature should be under a setting/tab called security.
Good luck.
Jan 05, 2014 | Computers & Internet
I just installed my new netgear router and i have the hardtime to get a username and password..what is the best way to fix this problem
Default settings will be as mentioned below....
IP address:
//192.168.1.1
Username: admin
Passsword: password
Thanks,
Satheesh
Jan 27, 2011 | Computers & Internet
I don't have the documentation of my Zyxel Prestige 600 modem and when I go to 192.168.1.1 I don't know which username and password I should use. Could you help me? Thanks
Please try the following combination to access your router page
username: admin
password: admin
username: administrator
password: administrator
username: admin
password: password
password: password
Dec 25, 2010 | Zyxel Prestige 600WH Wireless Router...
Documents' Libraries Will Not Open? When I try to
click Start-->All Programs-->click Accessories-->right-click Command Prompt-->and then click Run as administrator. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
2) Type the following command, and then press ENTER:
sfc /scannow
The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
You can read more here http://support.microsoft.com/kb/929833
Oct 02, 2010 | Toshiba Computers & Internet
Printer shows offline/Scanner has no destination list
You must program the email addresses in the machine address book, so that you will have a destination list to scan to email.
You can also try to scan by pressing the Scanner button to access the scanner function and input the email address manually by selecting manual, and then press the Start button to scan the document.
Joe
Dec 18, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
Scanning to C352 server connect error
Check you smtp server settings in admin settings. Verify there correct. If your smtp server needs your email address and password to send, that should be populated as well under them smtp authentication settings.
Oct 20, 2008 | Konica Minolta bizhub C250 All-In-One...
Ricoh 2045
Yes.
Go to your desktop. Create a folder named "scans" on the desktop, and share it. Give the "everyone" group full access, or give users permission to modify files. Depending in how its set up.
On the copier, since you already have Email setup, your dns servers will be entered. Go to:
user tools, system settings, admin tools, address book management. Either select a user, or new program. Fill in user name ect. Select folder. It will ask for a path. Enter the path using the following template"
\\computername\scans. You should be able to test it out. If it is successful, then it will prompt you to login. This is your local login for the computer with the scans folder, The password is its password. Press ok to save.
Select scanner, scan document to the user that you set up. If the memory goes from 100%, to 99%, to 100% quickly, it worked.
You can use variations of this on a server too. If its a domain server, assigned to a group, the user name and password are what the user uses to access the active directory.
Mar 28, 2008 | Ricoh Aficio 450 Copier
User name = Admin
Cheers J
Dec 26, 2007 | Ricoh Aficio 3025 All-In-One Laser Printer
16 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
