Question about Minka Aire Ceiling Fan
Fan direction We have two Minka-Aire fans on same remote. Fans are going in different directions. How do we change one to get them in sync?
SOURCE: Minka Aire remote controlled ceiling fan
I have a newer Minka w/ wall controller. The books says to make sure both the wall control and the receiver(up in the fan) are both programmed the same. My receiver has no little switches but has a sticker stating that you need to hold the 'fan off' button down for 3 seconds after turning on the power so the receiver can memorize the program in the wall switch. You have 60 sec to do this after power is turned on. Good luck !
Posted on Feb 25, 2009
  • 6 Answers
SOURCE: minka aire f602
There are tiny dip switches on the remote as well as on the receiver. Make sure they are set to the same sequence. The receiver is the black box that all the wires connect to in the ceiling.
Posted on Jun 11, 2009
  • 10865 Answers
SOURCE: Como Fan MInka Aire light bulb burned out
remove the cover and unscrew the bulb. get a replacement especially designed for a ceiling fan.
Posted on Sep 07, 2009
luvsdaheat
  • 7 Answers
SOURCE: Noise from one of the fans on gyro fan
Please see my Solution to the post about the "HOT" motor, with blades that don't turn.
The Minka Aire Gyro fan heads do NOT have any exposed screws that can be tightened. Checking the rear (wood color) pointy trim piece -- first loosen, turn fan blades a bit, then it. tighten back up.
If your fan was just fine before, and now it's cranky, the problem could be the motor head's "tweaked" out of balance: EITHER from the rear trim piece (see above), or from the twin support arms. OR, the fan head has somehow gotten off-kilter and is whirling out of balance.
FIRST, gently rock each fan blade - they are PVC plastic, not wood, and should not Warp. Do they all look the same? Do they feel snug or loose in the fan head? IF that's all good...
1) With the fan OFF, swing that motor head thru it's up and down range a few times, make sure it's moving like the good one.
2) do the above-mentioned pointy trim piece thing, and the "swing thru" thing; rec-check BY HAND to see if it's corrected.
3) If not, check for fan head wobble by slowly turning the blade (fan head) and see if it's running parallel to the motor head. IF NOT, use a thin plastic (spatula) and gently wedge the kiltered side back to parallel - recheck afte each "nudge". It should spin nice and flat with no wobble, and not feel loose, either!
BY HAND: Spin the blades fast - does it bang? NO? great!
Yes? Double check that the grill hasn't gotten banged, and pushing into the blade's path. Re-try the "adjustment" of the fan head - if it still does not remove the problem, then the internal motor shaft supports may be loose, or broken.
Hope this Helps!
Posted on Jul 25, 2010
  • 377 Answers
SOURCE: 3 concept II fans
According to the URL at: http://minkagroup.net/Admin/UploadFiles/F518-English.pdf there are dip switches on the fan. They are on the receiver that is most likely tucked away in the bell housing at the ceiling level. Pull the bell housing down and you will find a box of sorts that has the switches on it. This is the receiver.
If this solution is helpful to you, I would appreciate a Thumbs Up rating. Thank you, Paul
Posted on Oct 14, 2010
Hardwired ceiling fan turned off by itself and stopped responding to remote control, but the light turns on/off.
I've had problems with Minka Aire also. You might need a new receiver. Call Minka @ 1-800-307-3267 and talk to someone in tech dept.. Should be a one year warranty on the receiver.
Aug 17, 2015 | Minka Lavery Minka Aire F888-BNW...
I have a Minka Aire Concept 1 which has been programmed to operate from a different frequency than nearby fans with remotes. The light goes on and off by itself at will and goes off each and every tim
Does your neighbor have a remote fan? Check wattage of bulbs to make sure they're the correct wattage. Still not working correctly, call 1-800-307-3267 (Minka Aire)
Sep 20, 2014 | Minka Aire Ceiling Fan
Ho do I change fan rotation direction?
Probably have to do it manually on fan. Look on switchcup or top of fan.
Sep 01, 2014 | Minka Concept II Flush 44 Ceiling Fan by...
Minka Aire Ceiling Fan light wont come on
Probably needs a new remote receiver.Contact Minka Aire @ 1-800-307-3267
Apr 30, 2013 | Minka Aire Ceiling Fan
Minka Air Concpet II Fan with wireless remote will not switch direction. Currently only turning counter clockwise. Wil stop and start and the light will turn on and off but it will not reverse
what you actually need to do is have the fan on ie. spinning (albeit in the wrong direction) then press and hold the change direction button. after about 10 seconds or so the fan will slow down and then start to spin in the opposite direction.
it's silly they don't make this clear in any of the instruction manuals.
Feb 16, 2010 | Minka -Aire Brushed Nickel Remote Control...
How to reverse the fan direction
most to all fans have a switch on the side of it where the pull things are its a little switch that has two settings up or down this typically controlls the direction of the fan. (note: some fans are not designed to change directions and they wont) check you manual or instruction booklet
Aug 11, 2009 | Minka -Aire Brushed Nickel Remote Control...
Mika aire remote fan
Not sure if this addresses your problem or not, but with my Minka Aire ceiling fans, the fan has to be moving in order to change the fan direction. Turn the fan on (any speed works), then push the reverse button. The fan will speed up to max, then you'll hear the gears switching. The fan will slow to a stop, change directions and get back up to speed in the new direction.
Oct 03, 2008 | Fanimation Bon Aire White Remote Control -...
Minka Aire Remote control R211
You need to change the tiny DIP switch settings so each fan is set up differently. (Note that each pair of remote transmitters--the one in the fan body, held in a bracket above the light kit when you drop that down; plus the one on the wall switch or in a hand-held remote, must be set with the same combination.)
Our Minka Aire Churchill model has 4 DIP switches; I have seen Casablancas with 5.
Jun 01, 2008 | Minka RC120 Remote Control
Minka Aire Ceiling Fan Logo
21 people viewed this question
Top Minka Dryers Experts
Joseph Coppeto
Joseph Coppeto
Are you a Minka Dryer Expert? Answer questions, earn points and help others
