Laptop physical memory crowded, computer keeps shutting down.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 131 Answers
The physical memori radiques in the hard drive change it and you trouble are solutioned please coment
Posted on Jun 06, 2014
4 Suggested Answers
ma_foes
  • 49 Answers
SOURCE: a problem has been detected an window has shut down to prevent damage to my computer
boot into safe mode by pressing f8 at windows boot time,
run a check disk by rightclicking the harddisk, properties, tools, check disk
check both options for file recovery and system file fix, click ok rebboot
see what happens and get back to me
or
use a bootable media like the windows system disk to enter the recovery console and run checkdisk from there
get back to me
Posted on Dec 15, 2007
  • 28 Answers
SOURCE: windows program shut down Laptop problem model-no-XPS M1530
sounds gooood
Posted on Jul 15, 2008
Sunnyrepairs
  • 808 Answers
SOURCE: registry file failure
If u can login to ur window then use reginout regcleaner it will fix ur problem
Posted on Aug 19, 2010
Physical memory dumping
once your computer take an BOD or blue screen of *****. it is an indicator that one of you perepherals was damage. in that case you only have to option the memory cards or the HDD. if some point you dont experience a hard time in booting it is not the HDD. maybe your memory cards was in defective state. sometimes good sometimes bad. try to chkdsk first or scan your HDD for posible bad cluster. and make a test also in your memory using some stress memory tester
Aug 21, 2017 | Intel Motherboard
I have a Creative Live ! Optia AF Webcam. If i put the USB of the Webcam in the USB-Slot (1 of 4 USB-Slots and all tested), i get a Bluescreen Error and my Computer shuts down. Is my Webcam destroyed? The...
A bluescreen error is rarely a good sign, but sometimes it's fixable. Have you tried plugging the webcam into a different USB port? Also have you tried unplugging some unnecessary USB devices and then using the webcam? You may be draining too much power from the PSU with USB devices and the PC shuts down to prevent damage. Have you been able to test on a different computer to see if the problems happens there as well?
Mar 24, 2011 | Creative Labs WebCam Live!
Notebook keeps shutting down
there are numerous cases why the computer keeps shutting down. One is the pc is slow to react, the other is when the pc is in idle mode, it did not respond accordingly to its idle time to come back to its original settings. These are just the samples.
To solve this problem, kindly turn off the computer and remove the battery and cables to it. Then using your forefinger, press & hold the power button in between 8-12 secs. Then reinsert the cables and battery to it. Turn on the pc and let your computer be idle in 30 mins. If in 30 mins your pc will shut down, that means there is trouble on your memory module inside your laptop. The RAM (Random Access Memory) keeps your computer in safe and running condition for it is avoiding the pc to automatically shutdown. That is the time to consult ASUS about this issue...
Sep 02, 2010 | ASUS Eee PC 1000H Laptop
I have just installed a new hard disc in my samsung x05 but keep getting an error message coming up saying windows (xp) has been shut down etc then kernel_data_inpage_error, followed by atapi.sys - address...
Well if it does that you should make sure all media is unplugged from the computer. If you have the Windows XP Original Release disk insert it and re-install Windows XP. If still says the same error "operating system not found" take it to a computer specialist near you or go on another computer and contact www.microsoft.com, thats all I can say.
Apr 07, 2010 | Samsung X05 Notebook
I HAVE HP 550 LAPTOP. WHEN I PLAY ANY GAME ON IT THEN LAPTOP AUTOMETICALLY SHUT DOWN BY GIVING ERROR " YOUR COMPUTER IS IN HARM DUMPING PHYSICAL MEMORY " . PLEASE GIVE SOLUTION ON MY E MAIL ADDRESS...
the error report is because of two cause 1) either your laptop do not suppoet the requirment of the game mainly the internal graphics or sound memory 2) or else the RAM of the laptop need complete defragmantation. for this you have to format you laptop
Jun 15, 2009 | HP 418446-001 - HP Special Edition L2000...
This is not the problem of drivers it is the problem with the memory when one or more programmes try to occupy the same ram space at the same time if you want to get rid of this problem i suggest you to format your pc once and reload the os.
May 30, 2009 | Computers & Internet
Windows program shut down Laptop problem model-no-XPS M1530
it sounds like the hard drive might be failing or it might be a software problem. Try starting in safe mode and running a full system scan to see if it's sometihngi n the software. If not go to the Bio's screen and run drive self test. you do this in bio's by scrolling with your arrow till you get to a tools menu and then it will say hard drive self test. Your computer then will do 3 tests to determine if you have a harddrive problem. If you do then you will have to have the hard drive replaced. If you have a warranty on the computer call them as they will cover this issue.
Apr 02, 2009 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
Error message: Physical memory dump
The error code is pretty general and could indicate a few problems. You can try the solutions posted here: http://www.updatexp.com/0xC0000005.html .
Mar 21, 2009 | Acer Extensa 4620 Notebook
As with any blue screen, this is an operating system error in which a driver or program has overstepped it's boundries by writing into an unauthorized section of the memroy, therefore causing the memory dump. You will need to run a system repiar or reload with your recovery disc or operating system disc in order to cure the problem. Start with the repair, if the rogue still persists, then you will need to wipe the hard drive and reload the operating system.
Jul 13, 2008 | Dell Inspiron 6000 Notebook
Laptop shutting off
There might be a setting in the BIOS that shuts down the computer when the processor gets too hot. so, getting better cooling or turning off the setting will stop it. but, if you disable the setting, the Processor could overheat and explode.
Jun 11, 2008 | Gateway 7320GZ Notebook
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
