Question about Canon Pixma MG5220 InkJet Printer
How to get rid of the back paper tray for canon printer
jack_daniels
  • 304 Answers
SOURCE: Printer jam
If your paper is jammed inside, open the printer and gently pull the paper back out to fix the problem.
Posted on May 23, 2008
SOURCE: Printer won't pull paper into printer
Check the "Feed Switch" button on the control panel (below the ON/OFF button) to be sure the green light at the back of the picture is lit. If not, try pushing the button and then printing again. It worked for me and it was so simple!
Posted on Sep 07, 2008
leethedeuce
  • 4472 Answers
How long have you owned the printer. How long have you had this problem? Is the paper old? Sometimes storage of the paper causes humidity and can cause this problem. You might want to try newer paper or clean the rollers with some alcohol on a rag/cloth. If you need any other assistance let me know. If you have a moment to accept and rate my solution I would greatly appreciate it.
Thanks,
Lee
Posted on Sep 16, 2008
ohms
  • 1879 Answers
SOURCE: Canon Printer Pixma MX700
If turning the printer off and on doesn't help, high probability it's bound for service because pulling the jammed paper out by force might damage the paper sensor.
Posted on Oct 26, 2008
Techno-Paul
  • 251 Answers
SOURCE: I have a Canon MX860
Canon says:
  1. Power off the printer.
  2. Remove paper from the Rear Tray.
  3. Look in the Rear Tray area for an obstruction. If there is any foreign material (such as a piece of metal or pen) inside the printer, after turning the printer off and removing the power cord from the outlet, remove the foreign material by hand, or with tweezers.
Posted on Sep 24, 2010
Canon 3010 problem jam indecate
If the error indicator light is lit, then the Canon printer is jammed. To fix a paper jam you must remove the paper tray, disconnect the AC power adapter, wait 5 seconds, then plug the printer back in. If the jammed paper does not automatically eject, carefully remove the paper manually. To help prevent further jamming, fan the paper in the paper tray to prevent the paper sticking together.
Great people delivering a superior customer experience. Canon Printer offers a complete line of printers, scanners, all-in-one office machines and paper jammed problem. Facing the problem with Bother printer, Scanners, Call our technical expert and get quick help. Dial Canon Printer tech Support Phone Number (18777788969) and fix your problem. For more information visit us: http://printertechnicalhelp.com/Canon-printer-technicalhelp.html
Sep 02, 2016 | Canon Office Equipment & Supplies
What does close the feeder tray mean
The Canon PIXMA iP4000 InkJet Printer has two paper sources for printing. Likely the top feeder tray is not completely closed (it is possible you do not have the printer set up to feed from both which may cause the error).
See the Quick Start Guide and the Picture Below:
Mar 06, 2013 | Canon PIXMA iP4000 InkJet Photo Printer
How to use the back paper tray for Canon Pixma MG5220 Printer
To use the Rear Tray for your current print job (this should last until you close Word) :
Use Ctrl+P to open the printer window. Click on the Properties button. On the Quick Setup tab find the Paper Source drop-down and select Rear Tray. Click the OK button.
To permanently set the Rear Tray as the default:
Click the Windows Start button, then click Control Panel and select Printer. In the popup window right click on your printer icon and select Properties. On the General tab, click the Printing Preferences button. On the Quick Setup tab find the Paper Source drop-down and select Rear Tray. Click the Apply button, then the OK button.
Apr 01, 2012 | Canon Pixma MG5220 InkJet Printer
My canon MP560 thinks that there is no paper loaded when I have the tray full. How do I get it to believe that there is paper?
Theres a cassette underneath and a sheet feed from the back. Make sure you have paper in the cassette tray, when it says cassette tray empty.
Nov 05, 2010 | Canon MP560 All-In-One InkJet Printer
I have a Canon MX860 wireless printer. There is a paper jam. The paper is all the way to the back of where the paper tray goes and I can't reach it. I do not see anywhere on the back of the printer...
Canon says:
Sep 24, 2010 | Canon Office Equipment & Supplies
I had a paper jam. Got the paper out, but now
Some printers won't reset the jam condition until you open a specific door or cover -- even if you've gotten the jam out, they think it's still there until you open that cover. Try opening and closing all of the machines doors and access points, and even pull out the paper tray and push it back in.
If the jam condition still isn't cleared, turn the machine off and back on with the main power switch.
Jul 05, 2010 | Canon PC-940 Black and White Copier
Canon ip4300 printer says paper output tray is closed. wont prin
Its a defective printer you have that cant get out of paper output tray is close or that the paper output tray is not properly placed into the printer.
Try to reseat the output tray and let me know. If it does not work, you may need to send printer to repairs.
Mar 19, 2010 | Canon PIXMA™ iP4300 InkJet Photo Printer
Supply rec paper tray - what does this mean when the tray is loaded?
OK, I was having a similar problem: Tray full of paper and tray adjusted properly.
Whatever I tried, the printer kept saying load paper.
I went to print menu>properties button (windows XP this is next to the printer name)>paper source tab.
It tuned out that the paper source had been changed from cassette to multi-purpose tray.
Change it back to cassette and you should be golden.
Jun 03, 2009 | Canon MF8180C Color Laser MFC Printer
Won't Accept Paper
sometimes you will have to clear the printer memory to get rid of this error.
Definintely make sure paper isn't stuck in the tray or rollers or any where else
1) make sure the print job queue is empty.
2) UNPLUG (don't just power off) the printer.
3) leave the printer unplugged for about 3 minutes
4) plug printer back in and try to print again.
Please let me know how this works for you.
May 31, 2009 | Canon PIXMA iP1600 Printer
Paper Jam Problem in Canon LBP 2900
I have a same problem .... somebody help us. :(
May 23, 2008 | Canon LASER SHOT LBP-2900 Printer
Canon Pixma MG5220 InkJet Printer Logo
13 people viewed this question
old marine
old marine
