Question about Serious Skincare The Egg Microcurrent Facial Toning System Plus
Current The current seems to start and stop very frequently. Is this normal or is my egg not working peoperly?
Saw will not start
tile saws frequently have issues with there motor brushes , this is a carbon item that carrries current to the moving armature of the motor , this is because they cut a lot of dusty ceramic's and as everyone knows ceramic is a insulator to electric current (so is the dust), sometimes just a good blast of compressed air is all they need to work again sometimes they need a set of new brushes (there not expensive) installed
Oct 20, 2015 | Saws
I have Mercury 2.1 white speaker.It works fine for half an hour but after that the woofer's sound stops-start frequently at highest bass but when I reduce the bass It works normally with no distortion.
If highest bass means you are boosting the bass for effect then it may be some form of speaker protection cutting in.
The most likely is a Polyswitch, which increases in resistance as it heats up when too much current is going to the speakers. The sound resumes when it has cooled down.
Feb 11, 2011 | Jasco GE 98903 2.1 Speakers
All intruments stop working,radio shuts off,windows do not work.....vehicle continues to run normally...ex: if crz control is active it continues to operate normally.....problem is intermittent but seems...
try shifting into neutral when this happens and see if everything works. if so it is probably the trans range sensor. it thinks it is in the start mode and cuts the things off
Jul 23, 2010 | 2006 Ford F-150
Motor takes high current and trips on over load
Maybe your are in low voltage thats why amphere is high.
May 11, 2010 | Ingersoll Rand Type 30 Fully Packaged Ir...
I want to know what cause the problem like
Does it not restart or does it start and then die as soon as you put it in gear?
Mar 11, 2009 | 1991 Pontiac Sunbird
Frequently failing TCO
The TCO comes with a plastic sheet to protect it from the hot moist air. Was that installed on the new TCO? Somehow moist air is getting into the console.
Feb 24, 2009 | Dishwashers
Back to Basics egg toaster
My egg cooker stopped working, so I took the unit apart. To answer your question, I did not see a fuse inside. One way to tell if it is a power problem to the mother board is to observe whether the LEDs light up or not after pressing the switches. If the LEDs don't light, there could be something wrong with either a power component or a power connection.
In my case, the toaster worked fine. Usually these problems are caused by loose connections. Sometimes it is not obvious where the loose connection is. All I did was loosen and re-connect the wires to the egg cooker and also to the board they came from. I also shined up the toast slide button copper connections with a nail file. This was just a precaution, since the toast slide button had to be working (i.e. it still toasted, just didn't cook an egg).
So far, it seems to be working, but time will tell. If the problem was due to something other than a loose connection, it will happen again.
Apr 14, 2008 | Kitchen Appliances - Others
Microwave appears to work fine but will not heat at all.
Sounds like the thermal protector on the mag tube quit. It may have gotten too hot and opened up. That is the lesser of all the evils that can happen to a Microwave.
Feb 04, 2008 | Thermador MBBS Microwave Oven
Serious Skincare The Egg Microcurrent Facial Toning System Plus Logo
63 people viewed this question
Top Serious Skincare Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Serious Skincare Health and Beauty Expert? Answer questions, earn points and help others
