Question about Epson Stylus Photo R260 InkJet Printer
Not getting good ptrins
Even when head cleaning has been done
Is their anyway to unclog the blk ink. Can it be done or do I need to get another printer.
It is impossible to clear blocked print heads. You can purchase a new print head, but they are expensive, sometimes it cost a little more to get a new and better printer.
Jan 23, 2011 | Brother MFC295CNAll-In-One InkJet Printer
THE DVD IS UNREADBLE
Possible that the optical head is faulty. Had the head cleaned manually or with a lends cleaner. If there is no response even with a good DVD then it is possible that the optical head unit is faulty and must be replaced.
Confirm the prices/estimation of a new head unit before the work can be done.
Jan 05, 2011 | Video Game Consoles & Games
Prints very lite even after new color and black cartridge ?
Hi Good day.. Maybe your printer head was not properly clean my solution for you is to clean it by using the head clean in the printer properties... please do the following:
1. 1. Click the Start button at the lower left corner of your screen.
2. Click on Control Panel. Next, choose Printers and Other Hardware, and then View Installed Printers or Fax Printers.
3. When the Printer page opens, right click on your printer's name, and choose Printing Preferences.
4. The Printing Preferences has five tabs across the top; choose Maintenance.
5. Click the Head cleaning, and then click clean again. to start the cleaning.
When the cleaning is done you can print a test page. and see if your print page is fine..
if it's not, you must clean it again... hope my solution will help you..
Regards
JR
Oct 06, 2010 | Office Equipment & Supplies
My homelite trimmer string keeps getting stuck and when i tap it to release more string it doesn't the spring in it doesn't spring at all. I constantly have to stop take it apart pull enough string to edge...
It's sticking pretty good. Try what I do: Pull the head off and clean it out pretty good. Also clean where the spool attaches to the trimmer. Before you reassemble it, give it a shot of powdered graphite (I get mine at the hardware store. It's for locks). Reassemble the spool onto the trimmer. Bump it on the ground several times to distribute the graphite within the head. Now, press the head in and pull on the trimmer line. It should dispense a little line and stop, just like when the machine is in operation. If it works, you're done! If it doesn't work, you will need to replace the spool. They are available at the major hardware stores. Even if you have to replace the spool, the graphite trick is a good one. It'll keep the head dispensing line smoothly. I add the graphite probably every 7th or 8th time I rewind the spool.
Best regards, --W/D--
Aug 09, 2009 | Homelite Garden
The CD player won't recognize CD's.
Most of those CDs they sell are just a gimmick, nothing can replace a good hand cleaning with a cue-tip done by taking the whole thing apart. Take it to the local technician to get it cleaned properly first and foremost, or do it yourself if you feel safe enough taking all this apart and cleaning a tiny fragile little lens with a cue-tip and windex yourself. If a good hand cleaning like that does not work, then it means the reader head itself is defective and need to be replaced. If this is the case, don't bother. A cheap head will go for around 200$ usually and sometimes more, and at the price you get a new complete system it will be better buying a whole new sound system.
Jul 07, 2009 | Aiwa Audio Players & Recorders
Since this morning my printer is not printing the red(megenta).
The problem is with the print head.
Firstly try cleaning cleaning and more cleaning because it means the nossles are blocked or the head is done for. If after doing a ridiculous amount of cleaning it still doesn't work then a last resort that has worked multiple times for me is to get a syringe without a needle. Remove the color in question and get a cup of boiling water fill the syringe and squirt it in the cradle where the ink gets fed to the head and wait 15 mins then repeat the process a few times. Wipe up any water around the contacts and put the cart back in, then go back to the cleaning. If the problem is not solved after this unfortunatly its time to bin the printer because the time to install and cost of the head is generally more than its worth (Not always but mostly the case)
Hope this fixsya
May 06, 2009 | Brother MFC-640CW All-In-One InkJet...
Photosmart 6180 won't print black
Been ther and done all of the stuff Have pulled the ****** apart... wont go into detalis try copy black only sheet of text 12x20 times then run head clean I was getting white sheets output if no black run 25x3 times black only on copy then do head clean For me Voila! BLACK Inkypete
Jan 10, 2009 | HP Photosmart C6180 All-In-One InkJet...
Cyan will not print
Try replacing the cartridge. Sometimes they do get clogged and won't clear no matter how many cleaning cycles you run.
....John
Mar 07, 2008 | Epson Stylus Photo R1800 InkJet Printer
Bad colors in print
perfrom a deep head clean 2 times this will clean the printer printer head out. make sure u have heaps of in in your ink tanks as it uses a bit of ink to clean the heads out. then try and do a print. also you may need to do a head alignment on the printer. this head alignment should be done after u replace ink tanks.
the only other item it could be is the print head on the printer.
Nov 20, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Problem with blue screen on my SharpVL-AX1 camcorder-video+playback does not work, but I can take still images with no problem
a simply cleaning of video head will solve the problem. if the head clean cassette is not working try doing manualy or get it done by some expert.
Jul 02, 2006 | Sharp VL-AX1 Mini DV Digital Camcorder
Epson Stylus Photo R260 InkJet Printer Logo
18 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
