Question about iRobot Roomba 530 Robotic Vacuum
Brushes dont turn
Brush moter replacemet
    Problem Solver:
  • 13 Answers
If you are referring to the two main brushes underneath the Roomba (not the side-sweeper) then there are a couple possibilites:
1. The gears need to be cleaned/regreased inside the brush unit. There are several videos/guides online that will show you haw to dissassemble the gears, clean out the gunk, and reassemble. Basically there are four screws that hold the unit in; once it is removed you will see several screws on the side of the unit that contain the gears for the brushes. Dirt/dust/hair makes it's way into the gear-case and gums up the works, which seizes the motor.
2. Another possibility is that the electric motor that drives the brushes needs tp be cleaned or replaced. My Roomba had lint/hair caught up in the electric motor...in fact the dirt was separating the brushes from contacting the rotor inside the motor, which means they weren't cunducting electricity. Once I cleaned out the motor itself, the brushed worked right away! There are a couple view holes on the sides of the motor...get a flashlight and look inside...there is probably lots of junk keeping the motor from working properly.
Posted on Dec 30, 2014
Where is belt located on Hoover wind tunnel vacum. And how to replace it. My brushes are not spinning.
Its usually located underneath the body of the unit, turn it upside down and you should see the beater brush. You need to open the bottom cover to get at the brush and drive belt.
Mar 25, 2015 | Hoover U8126-900 Wind Tunnel Dual V...
Hi i have a hoover F5853 when the brushes in contact with the carpet they quit spinning but it is on and lift the front up they start spinning but as soon and i put it back down they quit please help
Belt around brush roller is worn, it spins freely when there is no pressure on it. But put it on the floor, the belt won't turn the brushes. I suggest taking unit to vac repair shop for new belt installation
Dec 05, 2014 | Hoover Vacuums
Brushes not turning, 2 inch piec on one brush in place, the housing is spinning but not turning brushes
Hello there! It sounds like you may need to replace your brush block assembly. Try turning that drive shaft connected to the middle brush. All the brushes should be able to do a full turn simultaneously. If the brushes get stuck and cant make a full turn or if all of the brushes aren't spinning together then your brush block will need to be replaced. To purchase a replacement brush block simply follow the link below. Hope this was helpful!
Search Results
Sep 22, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steamvac 50 stopped spinning
Hi! The brushes can stop spinning if something is obstructing them such as carpet fibers, hair, dirt or debris. Remove the brushes from the cleaner by grasping the plastic outer housing and pulling firmly away from the cleaner. Remove any debris and run it under running water to clean. On the back of the brush-block assembly there's a plastic drive pin that rotates all the brushes when turned. Turn the drive pin and ensure that all brushes are making a complete 360° degree turn. If the brushes are getting stuck or if a brush falls out then the brush-block will need to be replaced. Follow the link here to order a replacement brush-block for the Steamvac Search Results. Below is a list of models this brush will fit.
F5912-900, F5914-900F5915-100, F5915-900, F5915-905, F5917-900, F5918-900, FH50041, FH50042, FH50043, FH50044, FH50045, FH50046, FH50047, FH50048CA
Hope this helps!
Jun 20, 2014 | Hoover Vacuums
No power to brushes no result when brush switch activated
If you hear the brush moter running then the belt driving the roller has probably broken. It can be easily replaced by removing the brush plate underneath and pulling the roller out. Replacement belts are available on-line or may be available in hardware stores.Fit the new belt over the steel motor spindle first, then place the belt over the roller and insert the roller.
The belt will break if the roller gets jammed, so buy 2 belts and keep one as a spare.
Mar 07, 2011 | Bissell 3750 Lift Off Bagless Upright...
Brushes dont spin
You will have a slipping or broken belt turn brush by hand have machine off check if belt is broken if it is replace with new. undo brush holder and brushes should come out there may be more screws to undo after the brush holder but very simple job. good luck
May 19, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Brushes Stopped Working Again, What causes this to happen?
There are several things that can cause the brushes to stop spinning on a Hoover SteamVac. Usually when we see this problem come in, the brushes are usually just stuck to do carpet fibers, or pet hairs that get stuck inside of the brush block. A very easy way to clean these brushes is to take them out of the SteamVac (see the link below that is a full diagnosis of brushes not spinning on a Hoover SteamVac), and use a garden hose that has a spray nozzle on the end, and just spray each and every brush. If you start at the top of each brush, and spray water around the entire brush, each brush should spin pretty quickly from just the power of the water hose.
A lot of the times it's just stuff that got caught inside the brush block that stops them from spinning, I would say 7 out of 10 times this will fix the problem.
It also could be that the brush block is broken, or even the turbine inside of the SteamVac that drivers the brushes could be broken as well.
Here's a link to a Fixya repair solution that I did which will help you diagnosis what is exactly causing the brushes to not spin. If you examine the pole on the block, as well as the square shaped female receptacle, and that receptacle is spinning, then your brushes are just clogged up with debris.
If you need to purchase a new brush block, and you have the model that you listed this repair under, Hoover F7220900, here's a direct link to the brush block on our site:
Hoover SteamVac Brush Block, Part # 48437029.
Here's the diagnosis of the brushes:
First, what you'll need to do is take the brush block out of the machine. To do this there are 4 clips on the brush block. You will need to turn the machine upside down, and pull down on the brush block to where it won't pull out any farther. There are 4 clips, 2 on top, and 2 on the rear of the brushes. (See picture I have circled one of the clips in red) Simply press these clips at the same time, and pull the brush block out of the machine. I'd say that 70% of the time that I see this problem, the main issue is that the brushes just need to be cleaned. If you have pets in the home, a lot of the time the pet hair will just be lodged inside the brushes, will prevent them from spinning. Use a pressurized water hose with spray nozzle is ideal) and spray each brush with water to dislodge any pet hair. You should be able to get these brushes spinning when you spray them. Spray each brush until the brushes are spinning pretty fast. Re-insert the brushes into the machine, and test to see if the cleaning has fixed your problem. If the cleaning still fails to fix the problem, take the brushes back out of the machine.
One you have the brushes out of the machine, the first thing you should look at the brush stem that goes into the turbine inside the machine. This is the green pole pictured in middle of the brush block. Examine this pole to determine if the top of it has broken off. It should exactly how the picture shows it. Make sure that the plastic has not broken.
If the pole has broken, you will simply need to replace the brush block. If the pole is not damaged, the next thing to try is to turn the machine on while you have the brushes out. Look inside the machine, where the pole goes into the turbine (also important, make sure the switch for the brushes is turned to "Rotating Brush Speed Hi), this female receptacle should spin when the machine is turned on. It is important the try this when the foot pedal is released, and the handle down, and not in the upright position, as there is an internal switch that shuts the brushes off when the machine is in the upright position.
If you notice that the female receptacle where the brush pole is inserted is spinning, then your turbine is fine. If this part is not spinning, then most likely you will need to replace your turbine.
I hope this helps you with your problem. If not, please feel free to request a repair clarification and I'd be happy to walk you through the diagnosing. I also can provide you with a blown up parts schematic to your machine, please just get the model number off the back of the machine and provide, and provide me with the full model number. I would be happy to provide any technical support you need, just request a clarification on the repair.
Chris Jones
Apr 07, 2010 | Hoover F7220900 SteamVac V2 Upright Vacuum
6 rotating brushes
When you turn on the Vac with the brush strip NOT installed does the part that engages the brush strip turn at all? If so, when you install the brush strip see if the will turn when no pressure is applied to the brushes (tilt the Vac back). If none of this works, then the switch that engages the brushes when the unit is not fully upright may be broken. If the part that engages the brushes turns but won't turn when the brush strip is engaged then one of the parts that mate up it most likely stripped. Let us know what you discover!
Aug 23, 2008 | Hoover F6020-900 SteamVac Upright Vacuum
Bissell proheat 9200
The brush roll motor is most likely bad (part #2036757). You will have to take it aprt and check it.
Oct 08, 2007 | Vacuums
iRobot Roomba 530 Robotic Vacuum Logo
110 people viewed this question
Top iRobot Vacuums Experts
Shehu Pro
Shehu Pro
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
