Question about Mitsubishi WD-62531 Projection Television
Has an overall green tint on a 62 inch hdtv - Mitsubishi WD-62531 Projection Television
  • 668 Answers
If you are using Coponet Cables from a Cable box or Satillite, make sure the blue connection is good and not backed off it's connector at both pieces of equipment. If it has a good connection at both pieces of eqipment I would
suspect the Optical block being faulty.
Let's pray for the loose cable connection.
Hope this helps,
Skyassoc
Posted on Jun 19, 2009
Hitachi 62vs69 has green tint, sky scenes and water look green
Sound Like the light engine has gone bad Model # is UX27716 link below, couldnt find many more searching this
http://salestores.com/hitachiux27704.html#.WwIhpUgvwXI
Apr 25, 2012 | Hitachi 62VS69 62" HDTV
Toshiba 62 inch dlp tv keeps flashing green and will not turn on
green flashing for .3 sec with solid red indicates lamp problem. and do you have the manual? If so, look in the appendix for a section 'LED indications'. that gives you the code for the indications.
Good luck..
Aug 29, 2011 | Toshiba 62HM195 62" HDTV
My Vizio 32 inch HDTV picture colors are all off. I have tried to adjust the tint/colors but the overall picture colors are all off. It is as if some of the primary colors are missing.
Maybe if you are using component input wires, one is not inserted fully. Set color to max and put tint in the center, then flip channels and look for known solid colors items of red, blue and green. You can see when one is missing, as a mixed color will just look odd, but a true r,b or g will just not be there so to speak. Hopefully is might just be a feed wire in, but be careful, as too much pressure on insertion can crack a solder joint inside the set.
Nov 26, 2010 | Vizio L32 32 in. LCD HDTV
Green Tint
bad optical block call sony they have a recall
Jun 01, 2009 | Sony KDSR50XBR1 50" Projection HDTV
Green Tint
Green tint is caused by a burned or distroyed filter in the optics. It must be removed and sent out to be
rebuilt or replaced.
Mar 21, 2009 | Sony KDSR50XBR1 50" Projection HDTV
Green shading appears around faces of people on the screen
Try adjusting your TINT control in the menu.
IF the problem seems to be in a surtan area of the screen, the light engine is bad. This is very expensive to fix. You might want to buy a new tv.
Jun 21, 2008 | Mitsubishi WD-62327 62" Rear Projection...
HDTV tube television - with green tint on right half of screen
i had the same prob on my 28 inch hd sanyo crt , i took it apart and reconnected a few plugs and havent had any trouble yet { be sure to unplug it and b quite careful even then} saved me a couple hundred $ !!!
Nov 19, 2007 | Televison & Video
Mitsubishi WD-62531 Projection Television Logo
266 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
