Question about Independent Kitchen Ranges
Need exhaust fan knob
Need a replacement
3 Suggested Answers
emissionwiz
  • 76846 Answers
SOURCE: fan control knob has only two speeds,
there is no computer control unit, what u need to replace is the fan speed control resistor module.
Posted on Mar 22, 2009
crouchdash
  • 83 Answers
SOURCE: Plastic knobs (off/on and fan speed) are broken. Need replacement
Only accredited service contractors carry them. You need to contact them for price and availability.
I hope this helps.
Posted on Jul 06, 2009
Whirlpool SC8720EDB cooktop stove independent vent switch is not starting downdraft exhaust fan, but the exhaust fan works fine when left side burners were turned on
Can you get to the switch terminals and try jumping them out with a piece of insulated wire? That would tell you if the switch is defective (my suspicion). Please be careful not to touch any live terminals - only the wire insulation you use for the jumper.
Aug 02, 2017 | Whirlpool Cooktops
Need replacement motor for bath exhaust fan.
Best place usually is grangers if you just need a motor. Take in motor and they can match up the exactone for you.
Jun 09, 2015 | Patton Dryers
LIGHT, turntable, and fan don't come on
follow this test and fix it. God bless you
  1. Exhaust fan motor If your exhaust fan motor is not running, there are a couple of things that you can check involving the motor to locate the problem. After removing the fan motor, you can manually attempt to turn the fan blades with your hand. If the fan motor is working properly, the blades should spin effortlessly. If this does not occur and the blades are taught, the motor will need to be replaced. Secondly, the fan motor itself can burn out due to time and usage. Using an ohm meter, the exhaust fan motor should read open for continuity. If it does not, then the fan motor has expired and will need to be replaced.
  2. Thermostat Another part that could cause the microwave exhaust fan to not work is a faulty thermostat. A thermostat gauges the air temperature, which activates the exhaust fan when required. If this part becomes flawed, the exhaust fan will not energize and the thermostat will need to be replaced.
  3. Main control board If your exhaust fan is still not working and the microwave fan motor, wiring, and thermostat are operating accurately, the root cause could be with the main control board. Replace the main control board.
Dec 09, 2013 | GE CVM2072SMSS Microwave Oven
Fan running when door open
measure this test and use the multimeter for fix it. GOD BLESS YOU
  1. Exhaust fan motorIf your exhaust fan motor is not running, there are a couple of things that you can check involving the motor to locate the problem. After removing the fan motor, you can manually attempt to turn the fan blades with your hand. If the fan motor is working properly, the blades should spin effortlessly. If this does not occur and the blades are taught, the motor will need to be replaced. Secondly, the fan motor itself can burn out due to time and usage. Using an ohm meter, the exhaust fan motor should read open for continuity. If it does not, then the fan motor has expired and will need to be replaced.
  2. ThermostatAnother part that could cause the microwave exhaust fan to not work is a faulty thermostat. A thermostat gauges the air temperature, which activates the exhaust fan when required. If this part becomes flawed, the exhaust fan will not energize and the thermostat will need to be replaced.
  3. Main control boardIf your exhaust fan is still not working and the microwave fan motor, wiring, and thermostat are operating accurately, the root cause could be with the main control board. Replace the main control board.
Nov 08, 2013 | GE JVM2070 Microwave Oven
Fan starts when i open door
follow this test and use the multimeter and fix it. God bless you
When Exhaust button pressed, vent fans not working, but microwave running for 30 seconds.
test the components and fix it. God bless you
Oct 24, 2013 | Frigidaire Microwave Ovens
The vent fan is not working but micro is. Replaced charcoal filter & reset still not working.
follow this steps and fix it. God bless you
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#12#ixzz2gURd1VtM
Sep 30, 2013 | Whirlpool WMH2175XVB Microwave Oven
We changed the charcoal filter & reset it. The vent fan still does not run. I cannot turn the vent on by pressing the vent button but the micro still heats up. What happened to the fan?
follow this steps and fix iT. God bless you
I need a replacement motor for a NuTone Model LS-80SE exhaust fan but can't find one.
Home depot usually has a good selection of replacement fans. They usually are a fan on a mounting plate, not just the fan motor itself. Sometimes you have to purchase the entire fan unit just to get the fan motor plate inside for a replacement part.
Feb 23, 2011 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
Fan control knob has only two speeds, ''Off'' and ''high.'' Can knob be replaced or do I need replace complete control unit.
Mar 22, 2009 | 2001 Dodge Dakota
Kitchen Ranges Logo
67 people viewed this question
Top Independent Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you an Independent Kitchen Range Expert? Answer questions, earn points and help others
