Question about GE JGBS23 Gas Kitchen Range
Oven woofing periodically and smell gas after replacing igniter
5 Suggested Answers
  • 3422 Answers
SOURCE: GE XL44 gas oven
Please CLICK HERE for the instructions.
Goodluck,
Please don't forget to rate the solution.
Posted on Apr 21, 2008
jumptrout51
  • 3361 Answers
SOURCE: oven won't work
Yes. The ignitor must register 2.9 amps or more to operate correctly and ignite the gas. Replace the ignitor.
Posted on Aug 02, 2009
heatman101
  • 43501 Answers
SOURCE: My GE Profile self cleaning gas Oven JGB908SEK4SS
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
or... The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Posted on May 04, 2010
dvrjang
SOURCE: replace igniter on hotpoint gas oven
REMEMBER TO UNPLUG YOU UNIT> The oven igniter is located under a metal plate. Remove the oven door so that you can slide out the flat cover to expose this plate. There are four screws holding down the plate. Once you remove this plate the igniter will be exposed. Hint: The screws holding the igniter in place are difficult to loosen if you dont have the correct socket for it. Once you do remove the two screws holding the igniter, pull the igniter until the connector plug comes out and replace it.
The Broiler igniter is easier to access. Remove one screw from the plate covering the gas manifold. Then loosen the one towards the front. Pivot this metal cover ccw to get it out of the way and using a socket, remove the two screws holding down the igniter and pull it out until the connector is exposed. Install in reverse order.
Posted on Apr 07, 2013
Oven will not ignite underneath, no gas seems to be flowing and if left on long enough it smells like gas, stove top works
The reason your eventually are smelling gas yet the oven will not light is because of a extremly weak igniter for the oven,its not drawing enough power to open the gas valve. By replacing the igniter it will quickly open and no gas smell.
GENE
Oct 16, 2011 | Kitchen Ranges
Hello, I have a GE profile range JGBP86WEB5WW. The oven is taking an unusually long time to heat up. There is a strange sound coming from the oven also. It sounds like a burner is trying to fire but...
Oven Problems Replacing the Igniter
heatman101
Nov 25, 2010 | GE Profile Spectra JGBP86 Gas Kitchen...
Oven not heating to desired temperature
You will have to place a amp meter over one ignitor wire and turn the oven on to bake.
If the amp draw is 3.3 amps or less,replace the ignitor.
Jul 11, 2010 | Amana ARGS7650SS Gas Kitchen Range
Our oven doesn't heat and smells like gas
This sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Feb 02, 2010 | Maytag Ovens
Oven is slow ot light and has a gas smell when
Hi, this sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, if it does light the burner, there may be delayed ignition (pop), does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Jan 21, 2010 | Kenmore Ovens
Gas smell, oven not heating up
You gas oven uses a glowbar to both regulate and ignite the gas entering the oven. If this glowbar is faulty, it might let some gas into the oven but it is not hot enough to ignite the gas. That is why you are smelling gas. I would suggest to start by replacing the glowbar (and if this is not the solution, simply return the part for a refund). The part you are looking for can be found online here: http://www.partselect.com/PartDetail.aspx?Inventory=470129&SourceCode=1
It is quite easy to replace. Simply remove the free-standing pan on the bottom of the oven, unscrew the existing glowbar, remove the back cover from the stove and trace the two wires that belong to the glowbar and unplug them. Thread the two wires from the new glowbar through the opening and reconnect to the plugs at the back of the stove. Screw in the new glowbar and test. Most oven ignition problems are caused by faulty glowbard. Good luck.
Jun 27, 2009 | Tappan TGF657 Gas Kitchen Range
Explosion potential
Absolutely do not use it until the problem is taken care of. You do indeed have an explosion hazzard.
95% chance all it needs is a thourouch cleaning of the ignition assembly.
When burner orifices and lighting tracks get contaminated and partially clogged with rust, dirt, and other sediment it starts to block the gas flow.
The gas starts to build up unburnt untill it eventually encounters the flame or ignitor, and then all the built up gas ignites at once.
It would eventuallty get worse.
Clean or replace the ignition assembly and burners.
A brass wire brush works wonders.
Jan 11, 2009 | Jenn-Air JGR8775QD Gas Kitchen Range
Oven does not heat up, can smell gas.
You probably need an oven igniter, it's weak. Remove oven bottom and find caged unit attached to burner. Replace this oven igniter. The 2 wires can go either way.
Nov 22, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
GE JGBS23 Gas Kitchen Range Logo
24 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
