If your Beko front loader washer dryer WDEX854044Q0G display keeps beeping and flashing through the wash settings, it could be due to a few possible causes. Here are some steps you can try to diagnose and fix the problem:
Check for Error Codes: Your washer dryer may be displaying an error code that can help diagnose the problem. Check the user manual for instructions on how to access the error codes and what they mean.
Check the Door: Make sure that the door is properly closed and latched, as this can cause the washer dryer to beep and flash. If the door is not closed correctly, the washer dryer may not operate.
Check the Water Supply: Make sure that the water supply is turned on and that there is adequate water pressure. Low water pressure can cause the washer dryer to beep and flash.
Check the Drain Hose: Make sure that the drain hose is not clogged or kinked, which can prevent the water from draining properly. Try removing any blockages or straightening any kinks in the hose.
Check the Filter: The filter may be clogged with debris, which can prevent the washer dryer from operating correctly. Locate the filter on the bottom of the washer dryer and remove it to check for any blockages. Clean it out and reattach it.
Check the Control Board: The control board is the brain of the washer dryer and controls all the functions. If it is faulty, it can cause the washer dryer to not operate correctly. Try resetting the control board or replacing it if it is faulty.
If none of the above steps work, it may be best to contact a professional technician for further diagnosis and repair. They can inspect the washer dryer thoroughly and ensure that it is working correctly and safely
Remove any kinks in the drain hose. Ensure that the washer is not sitting on the hose.
Inspect the household drain. Remove clogs, if possible. Call a plumber if you cannot remove the clogs.
Check the drain and make sure there is an air gap between the hose and drain. An air gap is necessary to prevent the drain hose from siphoning water.
Clean the pump filter. Open the pump access door. Turn the pump filter counter-clockwise and remove it. Remove dirt and debris. Replace the filter and close the pump access door.
Rearrange the clothing in the load. An unbalanced load can prevent the washer from spinning or draining.
Allow the washer to cool down for two hours. If the washer overheats, it will stop the motor and cool down before restarting.
Close the door completely. The washer will not operate if the door is not securely closed.
Hi If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Hope this helps... Daniel
The filter is located at the rear of the washer.
Remove rear panel, and remoive large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
take top off remove three srcews in back ..remove 4 screws hold control console ,,dont remove connection just flip console on top of drum,,make sure unit is unpluged..your looking at 4 screws across to panel remove them open door remove spring wire clip around the out sid bellows where almost there..now careful down in the filter acess panel remove the frist screw the filter cover comes off after the cover is out remove the pump filter housing screw..and last remove thebottom panel screw,,remov panel,,pump on left is drain pump..pump on right is recrulation pump
easy first unplug unit..take back remove phillips head screws...now the pump drain hose is the other side of the filter in front just take a pliers remove clamp,,replace hose..close unit plug back in
If the pump is not draining, either the drain filter screen is clogged with debris, the drain pump is jammed by foreign debris or the drain pump itself has failed. More than likely something is clogged in the filter screen or a sock is jammed up inside the drain bellows tube just before the filter. Pull the drain filter screen out and look up the hole to see if there is any material stuck inside. Usually that's the problem.
The drain pump is jammed or clogged up. Remove the filter cover and check for bobby pins, coins or bra wires. If clean, remove drum to pump hose from the pump and check for any foreign matter. Try to turn the pump impeller by hand. It should turn freely. If pump is not free, replace it.
