Question about JVC GR-D770 Camcorder
Need to repair
I have a board for the Camera ,I need a repair manual to know where two mparts go that fell out when I took it apart
Lg-vn270
the phone needs professional help
Jul 14, 2014 | LG Cell Phones
Remote for appollo 1996 fell apart need to know how to reassemble
Replace it, they don't provide repair instructions for this type of device.
Nov 05, 2012 | Cars & Trucks
Hi my tv fell off the wall last night about three feet to the carpet now it won't turn on the amber vizio light won't even come on when I plug it in. I took it apart and nothing appears to be...
After a fall like this (even on carpet) it probably has a cracked circuit board or a loose connector, first (since you took it apart any way) look for all connectors, than unplug them and re-plug them to make sure all plugs and boards are seated correctly, if you still don't have luck, than take out all the circuit boards and check them for cracks under a good lamp and magnifying lens, than repair the cracked traces with a good soldering gun by scratching off the varnish coating and applying solder. (if the crack is to wide you can solder a peace of coper wire to the trace on the board)
Have fun!
Jun 25, 2011 | Vizio L32 32 in. LCD HDTV
Canon powershot G9 will not turn on. Took it to Best buy. Its not the battery or the battery charger. Any suggestions? I took 4 pics yesterday, turned it off, then went to turn it back on to take another...
The Canon G9 has a problem where two screws in the top of the camera work themselves loose over time, then fall out and short out the fuse on what's called the DC/DC board.
This board needs to be replaced, both screws need to be found within the camera (if both fell out), and they need to be put back in place and held in with 'Locktite' so they don't fall out again.
If you do a Google search for "g9 no power repair" you will see in the #3 position Darntoothysam com, where you can have this repair performed for $85 total! This includes the part, installation, and return shipping of the camera.
If you want to do the repair yourself (no instructions included, sorry) you may purchase the part you need for $48 including shipping.
Hope this helps!
Thomas Drayton
Owner, Darntoothysam com
Nov 08, 2010 | Canon PowerShot G9 Digital Camera
Usb port fell out of hp pavilion ze2000. can i
this yould need to be resoldered to the board and requires some soldering skill. Only attempt if you know what you are doing
Jan 19, 2010 | HP Pavilion ze2000 Notebook
Need schematic for electrical on am780 emglo
I would suggest contacting Master Tool Repair, great web site to get information on these little machines, I know you can get owner manuals from them that may contain wiring diagrams with them.
Dec 13, 2009 | Dewalt d55151 factory reconditioned emglo...
Sony HDR-HC3 Problem
humm, interesting.... You need proper service manual to open n repair this expensive camera. Service manual is available on charge basis.
Jul 24, 2008 | Sony Handycam HDR-HC3 HDV Digital...
X73 found loose spring
I was having a similar problem. After finding the service manual (4402_X73.pdf) and taking the thing apart, an ink-covered broken spring fell from the inside. I checked around the 'Maintenance Station' and found the other half still hanging. Apparently -because I haven't got a replacement yet to confirm- the spring goes across the bottom of the 'Maintenance Station' to a lever on the other side. If someone can tell me where to post a picture of the thing, I'll gladly do it.
Jun 21, 2008 | Lexmark X73 All-In-One InkJet Printer
JVC GR-D770 Camcorder Logo
21 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
