Question about Quantaray 7-Inch Digital Picture Frame - View your photos right from your memory car...
I have 5.6" digital photo framer from Quantaray....It is not working with 4gb sd card...it does work with 2gb card
Does not support sdhc
Posted on Dec 18, 2009
My Pentax N73 digital camera will not accept 4gb sd cards, what card should I be using
If I'm reading the specs right then the N73 works with SD cards. Your 4GB card is actually an SDHC card and will only work in devices specifically designed to work with SDHC cards. You'll need to use SD cards, 2GB or smaller.
Aug 05, 2013 | Pentax K1000 35mm SLR Camera
Hello, I have bought an adapter micro sd xd adapter for an old finepix f10 photo camera. I have tried more micro sd card 2GB, 4GB, 8GB with this new adapter, but is is not working in my finepix f10. It...
Your Finepix F10 does not support SDHC (High Capacity) memory cards.
You can only use standard SD cards with a maximum capacity of 2GB.
New technics are not always backwards compatible, sorry for that.
Jul 21, 2011 | Cameras
I have a 4GB SD memory card that I am trying to use. It says the memory card is empty or incorrect file format. I have only 4 jpegs that I compressed thinking this was the problem. How do I get it to...
The problem is that your NuVue 560 Digital Photo Player is only compatible with SD cards, not SDHC cards. You bought a larger card for your older Digital Photo Player, not noticing that it was SDHC (or not knowing that it mattered). The new card doesn't work, not because it or the Digital Photo Player is broken, but because it's not compatible.
Cards up to 2Gb are generally SD.
Cards of 4Gb are generally SDHC.
Cards over 8Gb have to be SDHC.
(There are exceptions. Sometimes, manufacturers make 4Gb SDHC cards but some have errors; they disable half of the chip and sell it as 2Gb, but it's still SDHC. 4Gb cards are almost always SDHC because they're cheaper, but 4Gb SD cards do exist. They are so rare that I've even seen a guru on this site claim they don't. I did own one once, but it was very expensive and turned out to be so unreliable that I had to return it. I don't recommend looking for one, because of the problems.)
Your solution is to go find a 2Gb card, and be extra sure that it doesn't say "SDHC" on it. Ask around your friends: someone who has a camera that can use SDHC cards might have an older 2Gb card that they'd be willing to swap ;-)
Mar 21, 2011 | Digital Spectrum NuVue 560 56Inch Digital...
I have a digital photo frame Coby DP-5588. I bought a sd card Kington 4GB when I insert the card in the photo frame appears a message "wrong Card" and it doesn't read the card content. What can I...
Your 4GB card is actually an SDHC card, not an SD card. While SDHC cards will fit into SD slots, they are electronically incompatible and will not work. You need to use an SD (or MMC or xD or MS), 2GB and smaller.
Dec 05, 2010 | Coby DP-5588 5.6-Inch (4:3) Clock &...
How can you format a SD 4gb card for the Kodak EasyShare Z612 Digi Camera
You can't. The Z612 uses SD cards. Your 4GB card is actually an SDHC (Secure Digital High Capacity) card and is incompatible with SD devices.
For SD cards (2GB and smaller), you'll find the Format operation in the Setup menu. Press the Menu button, then use up/down to select the wrench, then press OK.
May 13, 2010 | Kodak EasyShare Z612 Digital Camera
A540 says "memory card error" " card locked" but 4gb card is not locked - can access card on card reader - copy on and off. a540 works with 2gb sd card no problem. please help?
The A540 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work in this camera. You need to use SD cards, 2GB and smaller.
Jan 13, 2010 | Canon PowerShot A540 Digital Camera
My smaller memory cards work, but my 4gb card says media error in my brother printer/scanner when I put it into the usb port (photo capture). Tried it dozens of time, doesn't work, but I was able to read...
Many older system will only support standard SD cards up to 2GB and HD SD cards will go above 2GB. It is a limitation of the printer and not an error with the card.
Nov 21, 2009 | SanDisk 2GB microSD Memory Card
Will a HP 4GB SD memory card work in Kodak
No. The Z612 works with SD cards, which max out at 2GB. The Z612 will not work with 4GB SDHC cards.
Mar 17, 2009 | Kodak EasyShare Z612 Digital Camera
The camera wont work with a 4gb sd-card............why?
The S600 is designed to work with MMC and SD cards, which top out at 2GB. It is not designed to work with the newer high-capacity SDHC cards.
Mar 11, 2009 | Casio Exilim EX-S600 Digital Camera
Quantaray 7-Inch Digital Picture Frame  - View your photos right from your memory car...  Logo
211 people viewed this question
Top Quantaray Photography Experts
JP Services
JP Services
jd83854
R.A. Ellis
R.A. Ellis
Are you a Quantaray Photography Expert? Answer questions, earn points and help others
