Question about Systium ST-350PFC Power Supply Replacement
Dead power supply - Systium ST-350PFC Power Supply Replacement
Acer aspire 4317z does not power
It's either your motherboard is dead or the power supply is dead.
If it's the power supply chances are your motherboard is dead as well now, if it's the motherboard then chances are your power supply is still good and it was just the power supply, but sometimes the power supply will take your motherboard with it as well.
It's hard to completely test these things without having correct equipment.
You should take it into a shop.
Feb 26, 2013 | Acer Computers & Internet
Intel desktop d845epi in the motherboard is not powering on.plz send a solve procedure.urgent
computer not power on can be caused by 2 thing, first is your power supply was dead, and the second is your motherboard was broken
try to connect another power supply, if your motherboard can power on it mean your power supply was dead if still not power on it mean your motherboard was dead, change the motherboard with new one
Mar 18, 2011 | Intel Desktop Board D845EPI Motherboard
I have an old Alienware Hivemind PC circa 03. Power supply is dead. I called the new Alienware A.k.a Dell and they said They didn't sell a replacement part since it is 7 years old. My question what power...
Take your desktop computer (and the dead power-supply) to any computer-store. They can sell you a "generic" power-supply that will be compatible with your original power-supply.
Hint: the smaller the computer-store that you go to, namely a "mom-and-pop" company, the more-likely that they will install it for free, if you buy the new power-supply from them.
Oct 04, 2010 | Alienware PC Systems Alienware True 480...
My Samsung 40" LCD makes a clicking sound and takes a couple of minutes to come on. What could be causing this?
Power supply board have dead componnent parts call capacitors,the board where the power a/c cord plug into it.That the power supply board.U know basic electronic's,have tools and soldering iron,desoldering pump or solder wick and solders?Searches all the power supply board for those dead capacitors.replaced it.These dead leakages capacitors alway bulges up on it tops or puff up on it tops.Replaced these dead leakages capacitors.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacemrnt.
Jun 19, 2010 | Samsung LN-S4051D 40 in. LCD Television
No display even after the system boots
You either have a dead CPU or a dead motherboard or a partially-dead power-supply -- the power-supply should supply different voltages to different computers, i.e., one voltage to spin fans, and a different voltage to power the RAM, and a different voltage to power the motherboard. So, it can be "partially" dead.
Borrow a power-supply, and try that first.
If all else fails, take the computer to a qualified technician.
May 31, 2010 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Dead TV
U know basic electronic's,and u know how to do soldering?Have soldering iron,tools and solders?The power supply board,the board that the power a/c power cord plug into it.That the power supply board have these parts call capacitors are dead.These capacitors alway bulges up on it top or puff on it top.Check all around the power supply board and it supporting boards.Replaced these dead leakage bulges up on it top or puff up on it top.Or tries websites like Shopjimmy.com,Ebay.com to buy and replaced the whole refurbish power supply board.
May 28, 2010 | Hitachi 32PD5200 32 in. HD-Ready Plasma...
Dimension 4400 Power Supply ** FREE ** (DE4400300WB) Power Supply: My Dell Dimension 4400 is dead with none of the 4 ...
It seems like it that you have a faulty power supply. Also the motherboard may be damged aswell, But most probably you can fix your PC by changing the power supply.
May 16, 2010 | Dell Dimension 4400 Power Supply ** FREE...
81865gvmx mother board when ipress the power switch cpu fan does not start and the set remains in dead condition.
its most likely either your power button or power supply having an issue ensure the power buttons wires are all connected correctly as per the key for the motherboard and if its still not starting try using a different power supply if its still not working than its most likely a dead motherboard
Mar 30, 2010 | Intel Motherboard
No power what so ever!!
power supply could be dead in which case buy a new power supply, unless the motherboard is dead.
Mar 23, 2009 | E-Machines W3050 PC Desktop
Compaq dead after power company shutdown period
Sounds like a blown fuse in the psu, replace the unit and you should be good to go.
Nov 30, 2008 | HP ATX-250-12Z, ATX-250-12Z Rev. H1, HP...
Systium ST-350PFC Power Supply Replacement Logo
19 people viewed this question
Top Systium Computers & Internet Experts
David Payne
David Payne
Are you a Systium Computer and Internet Expert? Answer questions, earn points and help others
