Question about Canon CanoScan LiDE 600F Flatbed Scanner
Window come up and says the scanner is locked
When i go to toolbox and select pdf.....the scanner keeps making the scanning noise then a box appears saying something needs to be unlocked......How do i unlock it ?
  • Canon Master
  • 365 Answers
Turn over the scanner and look at the bottom.You should see a slide latch with a lock and unlock symbol.
Posted on Jun 20, 2009
CODE 162,0,0 ON CANON D1350
This happens across the range of Canon Printers. The fix is to push the right button! Yeh I have a differing model, but the answer is the same. Go to the printer and select remote scan. Then invoke computer program. Some one has to be boss either the printer or the computer for scanning.
I can make the scanner printer the boss and issue a TIFF scan to the computer. Just push scan on the printer and select computer (it does a push data)
I can make the computer the boss by selecting the steps below:
Please choose what option you require. Ignore the model number.
The error codes 162,0,0, or 255,0,0, usually indicate that you have not selected a scan type at the machine. Please follow the steps below to perform a scan from the image I-SENSYS MF8230Cn:
Verify that MF Toolbox is closed on the computer and press the [SCAN] button on the printer.
Highlight [Remote Scanner] and press [OK]. The screen will show, "Remote Scanner. Waiting online...".
On the computer, open the MF Toolbox and select [PDF].
Click the green [START] button on the [PDF] window. The machine will start processing the scan.
If you receive any errors or need further assistance with the I-SENSYS MF8230Cn, we recommend that you contact us at 1-800-OK-CANON (1-800-652-2666).
Sep 29, 2014 | Canon imageCLASS D1350
How to get Canon MF toolbox to work with Win7 64bit.
I got mine to work. Just set the compatibility mode for the .exe file to Windows XP (Service Pack 2).
Jun 24, 2010 | Canon imageCLASS MF3240 All-In-One Laser...
Connot make a pdf scan. get a reply thet there not enough space. installed latest drivers. working with xp
Issue: ERROR: Insufficient space on target disk
Solution: Change where temporary files are saved (Toolbox)
Change where temporary files are saved (Toolbox) For an unknown reason, the computer is not allowing temporary data to be written to the general folder chosen by Toolbox at the time of install.
  1. From the CanoScan Toolbox, click the Settings button.
  2. At the bottom you will see a section that states, "Select Folder Where Temporary Files are Saved:".
    Click the Browse button.
  3. Browse to a folder, such as C:\Temp, and then click OK.
  4. Click OK again to exit the Settings window.
  5. Try scanning again.
Sep 13, 2009 | Canon CanoScan LiDE 600F Flatbed Scanner
Canoscan Lide 30 - want to use on laptop running XP Pro
Did you restart your computer after you downloaded your drivers and software? Did you select the correct operating system? Make sure the USB cable is plugged into the computer and the scanner...Open the toolbox and click scan or save and check to see if the scanner makes any noise or lights up...If you are using Windows XP then make sure you have downloaded the "TWAIN" driver and the "WIA" driver (two seperate downloads)
Jun 30, 2009 | Canon CanoScan LiDE 30 Flatbed Scanner
Scanning Multiple pages into one pdf
Scanning a multi-page document as a .pdf file reverts the settings for rotation, selected area, etc. to default for any pages after the first page. This applies to Mac OSX 10.3, 10.4, & 10.5. A simple, but tedious work-around is to scan each page as a separate file and easily recombine them using OSX Preview. Just open the first page, view the Sidebar, and drag-drop the additional page files into the sidebar. Save and it's all one multi-page .pdf.
Jun 26, 2009 | HP Photosmart C5280 Printer
Canoscan 20
I had the same problem..the way to get around this is to open the toolbox and click "Save" instead of "Scan" After you do this you just create a file name and save it into a folder..also make sure you change the "save as type" to JPEG
Dec 18, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Won't copy
try this...
start, programs, canon scangear toolbox,
A little box like this should appear
press on the cog icon
Select the copy tab and ensure that the "link to" is set to DRIVER, and press the SET button and select the printer you want to copy to from the dropdown, then OK, OK
post back results and if required I will give more ideas to try
Jul 05, 2008 | Canon CanoScan LiDE 30 Flatbed Scanner
Canon CanoScan LIDE 25
Use the PDF function of the CanoScan Toolbox. On the options screen for a pdf, click the drop down box next to “Save as Type:”. Select “PDF (Multiple Pages)”. This option causes CanoScan to stop after each page is scanned and ask if there is a next page or if you are finished.
May 04, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
I'm using a CanoScan LiDE 60 and I have no idea even how to begin. I need to scan in 5 different documents with numerous pages and I was hoping to create a pdf for each. Can you help me get started?
Use the CanoScan Toolbox that shipped with the scanner. If you don't have it, then download it from the Canon Website. http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=11446
If you don't have the scanner driver, then download that too.
Once you have Toolbox installed and you open it, there will be a PDF button. The scan to PDF window will open. If you're planning to do a multiple page pdf, then click the dropdown menu next to 'Save as Type:' and select PDF (Multiple Pages). You're now ready to begin, insert your first page into and then click 'Scan'.
Nov 20, 2007 | Canon CanoScan LiDE 25 Flatbed Scanner
Canon 4200f - Mac OS-X compatability
This solution does not work. On MAc there is no way to use this scanner. Canon sucks!!! There was no info about supported os on the box. It is just unfair to sell products without providing drivers for users.
Oct 24, 2007 | Canon CanoScan 4200F Flatbed Scanner
Canon CanoScan  LiDE 600F Flatbed Scanner Logo
134 people viewed this question
old marine
old marine
