Question about Zebra Symbol MC3100
Mc3100 wont power on - Zebra Symbol MC3100
How to adjust brightness on display
If you go to Start>Settings>Backlight and select brightness. You can adjust up or down from there.
Tech Support Barcoding Technical Support
Feb 22, 2016 | Zebra Symbol MC3100 Wireless Mobile...
Cold boot rqd. i can't downgrade. message appear error update cold boot rqd.
Here is the cold boot instructions:
To perform a cold boot 28, 38 and 48-key keypad configurations:
1. Simultaneously press and then release the 1, 9 and Power keys. Do not hold down any other keys or buttons. As the mobile computer initializes, the Symbol splash window appears for about a minute.
2. Calibrate the touch screen.
To perform a cold boot on 20-key keypad configurations:
1. Simultaneously press and then release the 1 and 9, MENU and FUNC keys. Do not hold down any other keys or buttons. As the mobile computer initializes, the Symbol splash window, appears for about a minute.
You may also need to download some software from Motorolla (depending if the boot fixes the issue).
https://portal.motorolasolutions.com/Support/US-EN
Apr 09, 2014 | Zebra Symbol MC3100 Wireless Mobile...
Wireless fusion profile configuration not saved in NVRAM, when battery drains configuration resets
The Fusion profiles aren't technically saved in NVRAM. You must use the EXPORT function in the fusion config utility to save the settings/changes you have made. The utility should automatically save .reg files to the \application directory where they'll be processed on a warm boot.
Jan 22, 2014 | Zebra Symbol MC3100 Wireless Mobile...
Mc3100 find the wifi networks but can't enable the connection
Hello
I am working on the assumption that a laptop can correctly connect to the wireless network and only the MC3100 devices cannot connect.
FedEx and UPS had a similar issue as Windows CE wireless NIC's do not natively support higher level wireless encryption settings that modern wireless routers and Access Points can be configured with. This would result in an similar issue that you have described - the device can "see" the network as it is being broadcasted. When the authentication tries to occur, the two devices cannot "agree" and the device fails to connect.
If this is possible in your wireless environment, change the encryption settings on your wireless router or Access Point down from WPA2 or higher down to WEP remove encryption all together (for testing only).
It is very likely the MC3100 will be able to connect to a non-encrypted wireless network and a WEP enabled wireless network.
Once you get the device connected, try increasing the wireless encryption levels on the wireless network and see how high you can go and still have the MC3100 connect.
Hope this helps!
Nov 09, 2013 | Zebra Symbol MC3100 Wireless Mobile...
Will not sync to pc
I think you have to log in as admin
Nov 05, 2013 | Zebra Symbol MC3100 Wireless Mobile...
Reset boot
http://www.ptshome.com/MC3100/mc31xx_manual.pdf 31xx, xx means that any numbers go. Download the file and you`re in business to find out...
Aug 17, 2013 | Zebra Symbol MC3190G Handheld Mobile...
How can I get mc3100 wm 6.0 firmware download update
The support.symbol.com is down today you can try tomorrow.
Jul 09, 2013 | Computers & Internet
How can I active wirelless on Motorola MC3100 and connect to wireless with it?
you should find fusion applications on your device, one of this programs allow you to turn on your wifi the other one - configure wifi options and profiles, on my devices that option named "enable radio". as far as i know fusion apps installed by default, and in my case exe files was in \windows\programs\fusion\.
Feb 08, 2013 | Zebra Symbol MC3100 Wireless Mobile...
Symbol mc3100 Adapter unavailable
WHAT TYPE OF ADAPTER DO YOU REQUIRE?
Oct 17, 2011 | Symbol MC3090
Zebra Symbol MC3100 Logo
Top Zebra Computers & Internet Experts
Mike
 steve
steve
justwinwin
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
