GE WJRE5550HWW won't spin. Sounds like motor is turning. I opened the bottom, belt ok, nothing obvious. Machine was bought 1 yr & 2 days ago, replaced a 12 yo machine. No extended service, why, it should last at least 1/2 dozen years. 2 days over warranty. Any suggestions?? Mike
  • 111 Answers
Normaly is the spin board thats instaled at the bottom of the unit
Posted on Jun 19, 2009
We bought an ABM3500 bread machine at a yard sale & the motor won't turn to knead the bread even though you can hear it running.
Your drive belt is probably broken or has slipped off. Unplug your machine and turn it on its side (remove the pan and paddle first) and remove the bottom panel with a screwdriver. Most bread machines have a removable panel. Hopefully yours is one of those. You will then be able to see if the belt is broken or has slipped off. You can reach me at breadmachineshelp.com for reinstall or replacement of your belt. If your belt has a number code on it I will need that. It will look something like this: STS 60 S3M471 If it has no code on it I still may be able to figure out the belt you need. Again, reach me at my website: breadmachineshelp.com
Mar 18, 2013 | Kitchen Appliances - Others
Frigidaire GLW51439FSO top load
have you had the back of the machine off if you know how to do this take back off and then try washing machine have a look to see if the belt is slipping on the drum could be that either the drum bearing has gone or that the motor has been overloaded and needs replacing also could just be the belt first of all i would take the back off and then try machine look where the belt goes from motor to the drum check if it is slipping if not slipping open the front door and try turning the drum by hand to see how much resistance there is on the motor shouldnt be to much after you have done this let me know the outcome and i will assist you further ok ill do all i can for you but remember i cant see what your seing so you need to explain in as much detail also other experts will see what you are saying and will also offer assistance but we need as much input from you as poss ok let me know
Nov 26, 2007 | Frigidaire GLTR1670A Front Load Washer
Le code drum only turns one way
LE indicates a fault with the motor on the appliance.
LG suggest you switch off, wait for a minute, unplug the appliance.
Wait 15 minutes then plug it back in again.
Try the machine again.
If it's still faulty, you can try changing the Hall Sensor in the motor, this can sometimes cure the problem.
Unplug the machine and remove the rear cover. There are 4 Philips head screws. Take them out and remove the rear cover.
You should now see the rear of the motor, which is mounted to the back of the drum.
In the middle is a large bolt which holds the stator cover.
You'll need a 17mm socket and a ratchet to remove this bolt.
Remove the stator cover and place aside.
Toward the bottom-left, you will see a couple of wire bunches held to the motor by three screws. One holds a metal bracket, one actually holds a ground wire, and the last is through a plastic bracket toward the bottom. Remove these three screws and don't lose them.
Through the motor there are 6 bolts holding it onto the back of the drum assembly.
You'll need a 10mm socket and ratchet to remove them.
You will now have the motor off the back of the drum.
Disconnect the two wire harnesses from the motor.
Looking at the surface of this motor that was facing the DRUM (not the outside), you'll see two small pieces clipped onto it, toward the bottom.
The sensor you are looking to replace is the one that looks like a kitchen magnet.
It is attached by small clips. You'll see how it goes on. It's easy to remove.
Go to google and search for part number 6501KW2002A.
This will bring up an LG sensor assembly.
Double check with the supplier that this is the sensor for your appliance.
When you receive the sensor, simply reverse steps 1 through 5.
Once re assembled, try the machine again.
If still the same after this you'll need to replace the motor and/or control board.
Is this a new installation?
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Has the washer been overloaded?
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
NOTE: Make sure the drum is not overloaded
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Thanks for using FixYa*&^%
Feb 04, 2011 | LG WM2277H Front Load Washer
I have an older-model GE washing machine. About 2 weeks ago I went down to put clothes in the dryer & the washing machine was still full of water but the dial was in the "off" position. I...
Sounds like your timer is going out. Turn it to the spin cycle and see if it'll spin. If not jiggle the timer handle and see if that does it. If it works after jiggling the handle then you need a new timer which can be expensive. Or on the cheaper side it could also be a lid switch but sound more like a timer. Check the lid switch also.
Dec 28, 2010 | Washing Machines
Wont spin
Yes you will find a belt under the bottom of the machine. Check out first that it did not just over balance and cut out while spinning if so you will need to hit the reset buttonand check out spin cycle. Hope this helps
May 25, 2010 | GE WDSR2080D Top Load Washer
I have a GE washer model wksr2100t8ww. It works fine but made a rattling nose during agitation. I opened the front to discover what looks like a piece of weed whacker string stuck and wrapped around the...
1) You r right it is NOT good! 2)Need Color and size to andswer that question 3)See if ur belts are missing a piece 4)Don't replace the belt unless you have done 1-2 and 3. Oil is normal. Like u tought oil in the bottom of the washer is cause of that object.
Oct 26, 2009 | Washing Machines
Washer wont spin
Check belt. If belt is ok then unplug machine for 2 minutes. Plug back in and open and close lid 7 times slowly. This will reset the electronic motor.
Jun 11, 2009 | GE Washing Machines
G E space saver washing machine doesn't spin
Call GE answer center 1-800-626-2000 ask for tech help, Have Model # off your data plate ready,
May 09, 2009 | Washing Machines
WHDSR209D Washer
if you have a rubber smell that means that the belt is burning through. Several problems can be the case.
1 bearing of the drum ( check if it turns freely if so the bearing is ok)\
2 the belt is worn and need to be replaced.
3 carbon brushes in motor are worn
4 bearing in motor is gone
open the backside of the machine and check belt.
think that is your problem
Apr 30, 2008 | GE WBSE2090A Top Load Washer
GE washing machine, wont spin
Same problem (but without any smell). You should try to reset the two computer boards in the washer. You do this by 1) unplugging machine and wait for 30 secs; 2) plug in machine; and 3) open and fully close the lid at least 5 times. This resets computer boards, which can get messed up by power surges, etc.
Mar 24, 2008 | Washing Machines
Washing Machines Logo
275 people viewed this question
Top Washing Machines Experts
