Question about Whirlpool Washing Machines
It fills with water, washes, then makes a buzzing sound.
After It washes there is a buzzing sound and it never goes to the next step. The water does not drain. Model: LSQ9500LQ0
  • 6,784 Answers
This is a failed timer mechanism. replacing this failed mech will fix your issue.
Posted on Jun 19, 2009
Washer buzzes and won't agitate or spin. Only will fill with water.
Almost certainly with that sound, the motor start capacitor has failed. It will be located either behind the control panel, or underneath next to the motor.
Dec 17, 2013 | Maytag Parts Washing Machines
Washer will not start. it makes a slight buzzing sound and then nothing.
OK buzzing sound, hmmm, need to know more than that, dos the water fill ??,,if not disconnect the water hoses at the machine and check the filter elements in the intake water side they might be plugged, if the unit fills with water then the starter capacitor at the motor might be defective. good luck
Jun 01, 2012 | Maytag Washing Machines
My GLTF 2940 makes a buzzing sound like a relay not pulling in all the way, during the rinse cycle. If you shut off the washer, and restart it on the rinse only cycle, it goes away.
its probably your cold water rinse only valves solenoid thats loose on the structure or the coil itself is loose,you may not hear it all the time especially during the initial wash start fill,try this, set the washer for cold water fill only on the washer,but turn off the water valves that supply water and start your machine to a wash cycle as normal,try this and see if it dry buzzes(without water),then try the same on the hot side,then with the water still off open up the machine and you can localize the buzzing noise
Mar 12, 2010 | Frigidaire GLTF2940ES Front Load Washer
Fills with waters starts making a buzzing sound
Check to see if there is something(sock) in the pump. If not, try spin washer with pump hanging down, but not with hoses off.
Jan 12, 2010 | Whirlpool Washing Machines
Me Estate washing machine, when started fills to specified water level then, it makes a buzzing noise then the buzz quits and nothing happens. Machine won't agitate or drain, just buzz then buzz quits.
sounds like you have a problem with your water supply to washer. the buzzing noise sounds like it's the valve opening to receive water but nothing going in. check supply hoses and water taps
Jul 14, 2009 | Washing Machines
Agitator does not move but activates high pitch buzz
genaral electric washing machine fills won,t spin but throws out water as if it did, goes to next cycle same thing, but sounds as if it is spinning but isn,t, hose not clocgged i checked, what else can be the problem,sounds ok but not spinning
Jan 26, 2009 | Roper RAS8445KQ Top Load Washer
Washing machine makes buzzing noise
Check the water pump for an obstruction in the chamber area, your pump may be sticking and that will cause the buzzing sound. The water pump runs during the fill portion of the cycle on several of the selected wash cycles to recirculate the water.
Nov 06, 2008 | Fisher Paykel EcoSmart GWL15
Washer fills, but won't start wash cycle....makes buzzing sound
Try replacing the timer switch..I had the same problem on my Simpson 175..
Dec 26, 2007 | Washing Machines
Washing machine buzzing
buy a new washing machine
Nov 03, 2007 | Washing Machines
Washing Machines Logo
Dan Webster
Dan Webster
Sal De GO PATS
