Question about KitchenAid KEBC107 Electric Single Oven
Screws loose on oven door handle - KitchenAid KEBC107 Electric Single Oven
2 Suggested Answers
paul4265
  • 592 Answers
SOURCE: The handle is loose on my kitchenaide superba oven
The glass portion of the oven dorr is not only attached by the screws, but there is a procedure to remove the door from the stove as well.
1: Open the door all the way.
2: On the hinges is a flip latch, flip them both up.
3: Close the oven door as far as it will shut, leaving the latches flipped up.
4: Lift up on the oven door evenly and squarely, lifting up and off hinges.
{note}...DOOR WILL BE AWKWARD AND HEAVY!
5: Place on flat surface, and under the bottom of door should be retaining screws for the door skin, so as to allow for removal of it as well. This should give you access to the handle so that you may tighten it.
Then go in reverse order to put door back on, making sure to flip hinge latches back down after re-insertion of door onto hinge pins, as the door will not shut without them being flipped down.
Posted on Jan 20, 2011
Oven door handle one side not attached to door other side loose
look around the outer edge of the door a few screws hold the 2 halves together caution do it on a flat surface as the glass can fall out .
Sep 01, 2016 | Neff Ovens
How can I fix the loose handle of the oven door ?
Open the door and lock it down, or remove it from the oven. Remove the screws holding the inner panel to the door. Remove inner panel, then remove the screws holding in the handle. Reverse to re-install.
Feb 15, 2015 | Ovens
Hotpoint BD42 oven glass door is loose from bottom fixing points. How and with what can it be re-attached?
Pull handle off door two screws inside the oven door remove handle reset face plate
Mar 27, 2013 | Ovens
Door Handle coming loose
Hello,it would depend on the brand of appliance,its model number and how it was designed.In many cases the door may have to disassembled to access screws or nuts holding the handle ends.If the end caps which the screws or nut fasten to are stripped,the handle may need to be replaced.
Thanks
May 27, 2010 | Ovens
The door handle of my oven whirlpool gold model no GGP84803 is loose I try to get it off by prying it from the top with no luck seem to be jam or locked I am not sure how to proceed.
I had same problem, fixed by removing screws under door and removing side panels . Then remove front glass ( 4 screws under glass ) and remove other screws behind glass to remove handle and then tighten 4 screws on handle. Works great.
Dec 29, 2009 | GE Ovens
Oven door handle is loose
Remove the screws holding the door together to access the handle screws
Oct 02, 2009 | Whirlpool Ovens
Neff Oven handle loose
The door can be seperated by screw on the side of the door, Put lock washers to insure futer tightness.
Mar 12, 2009 | Ovens
Loose oven door handle
I had the same problem. We took the door off completely & turned it upside down. There are screws on the bottom of the door, take them out, take off bottom trim piece that holds the outside glass panel in place, remove glass panel and you can access the door handle screws and clean the inside of the glass while you are at it.
Jan 05, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Loose oven door handle on kitchenaid gas range
youl have to take apart the door.the screws are on the other side of the glass/framing
Dec 31, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Loose Oven door handle
You may have to get some loctite brand paste in a tube for applying to the threads of the bolts that hold it on.
This will prevent the screws from loosening.
Another way would be to get some spring washers or star washers at your local hardware store such as menards.
Jul 02, 2008 | Smeg SE399X/5 Stainless Steel Electric...
KitchenAid KEBC107 Electric Single Oven Logo
22 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
