Question about Avaya Partner 34D Telephone PN: 7515H04-003
Lcd change brughtness
Nokia6230 whait lcd
(There are different types of problem that display white screen)
Example 1. LCD (try by changing a new LCD)
2. Patta (try by changing a new Patta)
3. Software (Flashing)
The best way is refer to the nearest mobile service centre for your problem.
Thanks for using FixYa
All the Best!
May 24, 2012 | Nokia 6230i Cellular Phone
How/ where to find the adjustment for the brughtness - SharpLLT15G4
Normally the brightness can be controlled by one of the little buttons either on the bottom or on the right side of the monitor.
There will be an icon that looks like the sun to indicate which button will control brightness.
It could also be adjusted by pushing the button that brings up the menu. To scroll through the menu, you'd use the up or down (or left and right) buttons that should be located next to the menu button.
Dec 06, 2011 | Sharp LL-T15G4 (Black) 15" LCD Monitor
Brught a Kaweasaki HE130A edger. Seller told me that it was two stroke. Looking at it appears to be 4 stroke. Tank filler cap says gasoline only. Is it 2 or 4 Stroke? Regards Kevin
Gasoline only usually means 4 stroke.
2 stroke requires a mixture of gasoline and 2 stroke oil'
Look for an oil filler cap on the equipment, no oil filler cap means 2 stroke.
If you have an oil filler cap there will be a dipstick therefore your kit will be 4 stroke.
Hope this helps'
Chris.
May 11, 2011 | Garden
The LCD not light fine ,ave a smoll under light...I dont know how the LCD ave failure. ....what i'm doing?
its not a lcd complaint, its a complaint from lcd light
so you need to change the lcd light ic
contact any service center to change the ic
May 13, 2010 | Nokia e65 Cellular Phone
I have just brught an unlocked blackberry peael 8100 and i do not know the bluetooth unlooking code could you please help IHave just brought a unlocked blackberry pearl but i do not know the bluetooth...
Hello
This unlock code provider generate full LEGAL unlock code direct from Blackberry server which wont void your warranty, & generate code based on your IMEI, means individual code for every blackberry set.
After unlocking from this provider's code your blackberry not only work with single network, you can use your Blackberry in any part of world with any network including your browser & MMS picture messaging to work, yes with just one time entering code from your keypad.
They unlock from network who locked your blackberry
This site will help you a lot & good email & 24/7 phone support
http://blackberryimeiunlockcodes.com
Apr 04, 2010 | RIM BlackBerry Pearl 8100
Starting trouble
If the odd substance was at the bottom of the float bowl it was water. If it were oil it would have mixed with the gas and you would not have seen it. Drain the carb into a cup to remove any additional water from the carb and petrol tank. When no more water comes from the tank you should be okay to start the bike. Clean air filter? Water gets into the tank via condensation in the tank.
Dec 31, 2009 | 2001 Honda NSR 125 R
It said there was a error in the setup and I don't know how to fix it . I brught the mircosoft office home and student but it will not install all the way is there a way you can fix it?
hELLO THERE:
YOU FIRST NEED TO ENSURE THAT YOU SYSTEM MEETS THE MINIMUM REQUIREMENTS FOR THE SOFTWARE YOU ARE TRYING TO LOAD. IF YOU DO MEET THESE REQUIREMENTS YOU CAN TRY TO REINSTALL THE SOFTWARE TO SEE IF IT WILL FULLY INSTALL AND IF NOT THERE SHOULD BE A TROUBLESHOOTING SECTION IN YOUR USERS MANANUAL YOU CAN USE WITH PHONE NUMBERS TO ASSIST YOU OK?
BEST REGARDS MIKE
Aug 02, 2009 | Computers & Internet
Changing time on screen
  • Press 'Prog' on the LCD screen
  • Enter ** (Star, Star)
  • Enter password (usually 1234)
  • Press 'Next' on the LCD screen until you see 'Date & Time Set'
  • Press Enter
  • You should now be able to change date and time
  • The arrow icon on the LCD screen allows you to move forward and back (press 'Shift' on the LCD screen to change the direction of the arrow)
  • Press SEL+ to change things like month and use the number buttons to change year, day, hour and minutes.
  • Press Enter and then pick up the handset and hang up to complete procedure
Dec 01, 2008 | Panasonic KX-T7630 Corded Phone
SPHM800ZKS SAMSUNG M800 INSTINCT PHONE SPRINT
just brught a SGH-A887 but having trouble with the registration for some reason it keeps coming up invalid. by the way this is a Samsung by at&t.
Aug 11, 2008 | Cell Phones
Motrolla Razr V3 LCD no Light
changing the LCD will not help that.....that problem is coming from your board so you need to have the mainboard replaced.
Sep 05, 2007 | Motorola Mobility RAZR V3
Avaya Partner 34D Telephone PN: 7515H04-003 Logo
20 people viewed this question
Top Avaya Lands Phones Experts
Oloyede Monsuru
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
