Question about Canon P170-DH Calculator
Replace dim bulb in clock, calendar panel - Canon P170-DH Calculator
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
Nov 29, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Clock light is dim or out?
Sounds like you need a new clock. Parts and repairs cost more than new products.
Apr 11, 2015 | Tivoli Model Three Clock Radio
Does the clock on the 2002 nissan maxima have a fuse or a bulb
turn up the dimmer switch. sound like its down at low setting.
Jun 10, 2013 | 2002 Nissan Maxima
The clock light and timer light on my GE XL 44 stove has dimmed and cannot be seen. How do I get to the bulb to replace it?
I looked up your model number and had trouble finding the correct bulb. From what I can tell though, this is the one you need. BULB
If you need more help let me know I would be happy to assist you!
http://www.pricedrightparts.com/products/10-Watt-Appliance-Bulb-10C7DC.html
Jun 11, 2011 | Ovens
The image is very dim, even on maximum brightness. We are considering replacing the bulb, but bulbs for this projector are very expensive and we suspect that since there is some image, the bulb is not the...
Yes, as bulbs age they will begin losing brightness. Most projectors have a bulb life hour clock, that measures the number of hours a bulb has been used. Usually you can pull that up within the menu of the projector. Also that particular model has what is called "Eco-Mode" and when engaged dims the bulb by 25% to cut down on power consumption.
Typical life for a lamp in that projector is:
3000 hours on Normal mode
6000 hours on Eco mode
You can expect a brightness loss of 50% when you are approaching end of a lamps life.
Mar 07, 2011 | Hitachi Cpx2510 Projector Cpx2510 Xga...
My clock light on my 2004 Subaru Forester won't light anymore. The dome light works so I know its not a fuse.
Is this for a 1999 Forester or for a 2004 forester, the title lists both years. If it is a 1999 model then the problem most likely resides within the clock itself. Unfortunately, many clocks of this vintage go bad over time. I offer a reasonable repair service and many clock removal instruction sheets at www.autoclockrepair.com
I'd be happy to assist.
Feb 25, 2010 | 1999 Subaru Forester
1995 Ford Taurus digital dash clock out
If your clock is backlit from a bulb, you can replace the bulb. If it is LCD lit, you must replace the clock. I've seen several clock and instrument displays in the 90's fords that go dim, or go black. Usually, they must be replaced or factory repaired.
Jun 29, 2009 | 1995 Ford Taurus
Instrument panel lights
A dim or dead clock display is a typical symptom of a dead clock. I offer a repair service, check out www.autoclockrepair.com let me know if you have any questions. thanks
Feb 07, 2009 | 2003 Toyota 4Runner
Setting the Canon MP25DV clock and calendar
press clock/calendar once to set date
1) press equal numbers will flash then use number keys to current time then the X to set am and pm. press = again to set time
2)press clock/calendar until date flashes. use number keys to current date. Press = to set
Nov 02, 2008 | Canon MP-25DV Calculator
Front panel with the clock settings is dim.
The only way to brighten is to replace the ERC or computer
May 04, 2008 | GE JKP45 Electric Double Oven
Canon P170-DH Calculator Logo
23 people viewed this question
old marine
old marine
