Question about Frigidaire Freezers
Frs6r5esb4 freezer not cold - Frigidaire Freezers
How cold should the outside of the door be on an upright freezer
not that cold perhaps you have a bad gasket of too much in the door of the freezer and it isn't closing properly .
Aug 05, 2015 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Freezer is not cold enough, even though the control panel says that the temperature is where it should be.
pull the panels inside and check the fan usually in a fridge freezer the fan cacks out or is full of ice clean it out and clean the overflow tube if fridge is cold enough then it is the freezer fan
Jun 07, 2015 | Samsung RF323TEDBSR 31.6 Cu. Ft. French...
I have a Kenmore Elite 51374. The refrigerator is not getting cold enough but freezer is too cold. Technician said that it was an electrical problem to call a electrician that I needed a new outlet. I...
That is the dumbest answer I've ever heard from a technician.
The cold control on most boxes controls the freezer temperature. You want the freezer temp to be around zero degrees.
Somewhere (usually in the refrigerator section) there's another control that actually sets a damper, letting some cold air from the freezer into the refrigerator. Higher numbers equal lower temperature. Find that second control knob and turn it up by 1 or 2 numbers, let an hour or so pass and check your refrigerator temp. You want about 40 degrees in the fridge.
Aug 02, 2017 | Kenmore 23.3 cu. ft. Side-by-Side...
Old Kelvinator Cyclic 340. Freezer is Ice cold
Read the below :-
http://www.fixya.com/support/r3886637-refrigerator_not_cooling_enough_or_not
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 16, 2010 | Kelvinator 12 cu. ft. / 340 liter Chest...
Fridge freezer is not workink,light is on freezer but no sound,freezer is in a cold room is it possible the room is to cold and problem with thermostate?
It could be a compressor problem, or the cold control. If your room is above freezing, the freezer should still run.
Jan 07, 2010 | Freezers
Side by side freezer not cold not cold.
The cold air circulating fan motor was burnt out. Replaced, all fine.
Aug 24, 2009 | Frigidaire Freezers
Alarm goes off and freezer not cold
The light indicates the need for a new battery (9V)
Jul 21, 2009 | Kenmore 20.6 cu. ft. Upright Freezer 24092
The outside of the freezer door is cold, and the surrounding floor is cold - even in the hallway outside the room the freezer is in. Can't find any obvious leaks around the door seal. The sides of the...
the # should be inside, the temp in side the freezer needs to be checked. does the thing ever shut off, if not it may need a cold control
Jun 28, 2009 | Freezers
Operation of freezer
no! tap cold control to see if it starts. if the compressor is running and still not cold you either have a system leak or a bad comp.
Dec 18, 2007 | Frigidaire 13 cu. ft. / 368 liter Chest...
Freezers Logo
78 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
