Question about Panasonic Panafax UF-885 Plain Paper Laser Fax
Panafax uf-895 faxes, won't print. Put a new toner in, gives message 021
  • 37 Answers
Error 021 relates to the Fuser unit (the bit that gets hot inside).
It is not related to the toner, which is a bit strange, but try switch off/on first.
Failing that you may need to clear the error in service mode. To access this:
Press "Function", "7", "Monitor" four times, then "*".
The machine should be saying "Service Mode"
Then press "7"
The machine should say "LBP Parameter Set"
(not 100% about the next bit but it should be reasonably straightforward to follow the display on the machine)
You are looking for "LBP Fuser Reset"..I think it is this:
Press "2" for "LBP Fuser Reset"
Press "Start"
The machine may reboot at this point.
If this is done correctly and the error still remains, the Fuser Unit will need replacing.
Sorry to be a bit vague on the instructions..not worked on these for a few years :)
Posted on Jun 19, 2009
BLACK LINES WHEN TRANSMITTING ON THE PANAFAX UF 895 AND WHEN PRINTING A COPY BUT NOT WHEN RECEIVEING A FAX NOT THE TONER CARTRIDGE
If the lines are thin, open the document feeder by pulling up on it and clean the small glass.
If they are 1/8 inch or wider, some elements are burned out in the LED scanner assembly.
Mar 27, 2010 | Panasonic Office Equipment & Supplies
ERROR CODE #021
Try a new toner cartridge. If that doesn't take care of the problem, it's the fuser.
Apr 08, 2009 | Panasonic Panafax UF-550 Plain Paper Laser...
Fax machine error code 021
If a new toner cartridge doesn't take care of it, replace the fuser.
Apr 07, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
UF 585 problems with changing the toner
You have to clear all memory jobs this is how is it done
This function will put you in service mode
Fuction
7
monitor key slowly 4 times
6
scroll down to ALL JOB CLEAR
set or start
Hope it works for you for more information you can visit Innovative Copy Products Support Panasonic
Nov 18, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Panasonic Panafax U-788 Error Code 021
You may have had a power failure. A technician must reset the fuser memory, or replace the fuser (bad lamp or thermister)
OR just a bad toner cartridge (no kidding) on the uf-788
Jun 03, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Code error 021 not in book inforation codes
1. Push the function button
2. Push 7 on the key pad
3. Push Monitor button 4 times (it will only beep at you - nothing will appear on the screen) - so count the beeps)
4. Push * on key pad
You should now see the service menu option
5. Push 7 on the key pad
6. Push "Set" button
7. Push down arrow button once
You should now see the fuser reset option
8. Push "Set" button
You will be prompted for 1 for Yes 2 for no
9. Push 1 on key pad.
You should receive confirmation that the reset is *COMPLETE*
10. Push Stop button until back to the main screen
11. Power down the fax
12. Wait 5-10 seconds.
13. Power on the fax (and cross fingers)
Jan 02, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Panafax UF880 shows message to check printer
This is a fuser problem (the hot rollers)it will require a service tech the machine has overheated and there is a service lockout to stop more damage from happening
Jul 25, 2007 | Panasonic Panafax UF-880 Plain Paper Laser...
Panafax UF-490 Fax
The fuser may be damaged or worn. A certified tech will need to replace it. Did you have a power outage? Ray
Jun 19, 2007 | Panasonic PanaFax UF-490 All-In-One Laser...
Panasonic Panafax UF-885 Plain Paper Laser Fax Logo
383 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
