Question about Toshiba REGZA Televison & Video
How to connect Toshiba RDXV60 to TV and Virgin box
Not showing HDMI source on the virgin box or the TV
  • 13 Answers
SOURCE: No sound when plugging a Virgin Media V+ box through HDMI
have you tried a hd cable this could be the answer if not get back on to virgin as they supplied the box etc they should sort this for you
Posted on Sep 03, 2009
  • 55 Answers
SOURCE: how to do a manual channel tune on a Samsung 933HD TV
in every remote there is a button that leads u to the digital setup. you have 2 options in it. manual or automatic. go for automatic. rest is done automatically. good luck!
Posted on Nov 01, 2009
tvtek
  • 1284 Answers
SOURCE: No HDMI on the source list, i have a Virgin Media
One of a few things are happening. If you are connected to the TV via the HDMI port and it doesn't become highlighted then either the main board on the TV is at fault, the HDMI output on the media box is not working (try on another TV if possible) or the HDMI cable itself is bad.
Posted on Nov 03, 2009
Testimonial: "cheers i will give it a go, the v+ box is brand new, the cable is a cheap one but its also new, virgin supplied it, the tv is at least 2 years old!"
SOURCE: lg tv interferes with my virgin media box.
I had the same problem so I moved the virgin media box to behind the LG TV. Problem solved as an infra red sent out by the TV on power up doesnt affect the digibox anymore.. ;0)
Posted on Nov 29, 2009
SOURCE: virgin media remote control TV Control Codes Samsung LE37A558
just tried 0079 from another forum and it's worked for me!
Posted on Mar 30, 2010
My TV will not stop switching itself off
Hi, The first thing to do is troubleshoot your TV independent to any other service provider that has a box that probably connects to your TV via a HDMI cable or old version scart.
Simply turn off your TV and turn off the socket that the TV is plugged in for 20 mins. Also turn of any Virgin media boxes.
After 20 mins turn on the TV. Do not worry if you get a message saying no signal detected. Wait and see if the TV stays on with no messages such as auto-standby. If the TV remains on with no problems then turn on your Virgin Media Box. The box will need to initialise ( about 30 seconds ) and then the TV should recognise the HDMI signal and you will see the Virgin TV.
If your TV turns off at any point during this process you have a fault with the TV, If when you turn on the Virgin box and no signal is detected you have either a cable connection problem or a Virgin Box problem, so using your TV REMOTE turn your TV back to ARIEL input to receive the normal television broadcasts via your Ariel that give you the normal freeview television that all modern TV's can receive, if you can get the normal reception contact virgin support who will troubleshoot your problem.
Nov 07, 2017 | Internet Computers & Internet
How do I connect a virgin v box to an old lg model?
The hdmi cable would not be compatible with your old style TV, if the Virgin box has a scart socket then that is your best option!
Nov 07, 2014 | LG Televison & Video
I have a JVC RM-C60 TV. I'm trying to tune it in to my Virgin Media HD box using a standard SCART lead but having no joy. It's completely failing to find the cable channel (or any other for that matter)....
Tuning of the TV not required when using scart lead, just select external input that the scartis connected to, ie AV1,AV2 (EXT1,EXT2) etc. The problem is possibly to do with the Virgin box, it may be set to HDMI out in which case it will not output anything via the scart lead, you would need to connect via an HDMI lead (small socket on the rear of the unit looks a little like a USB socket). Problem is if your TV is a CRT television its unlikely to have this socket. Your Virgin box can be reset to output via the scart but you would need to contact Virgin for this process.
Feb 17, 2011 | JVC Televison & Video
I have a toshiba 19w330db tv and already have a virgin media box and toshiba SD220EB dvd player connected. I am trying to connect a nintendo wii using the AV cable provided and am using the audio L R...
Do I understant this correctly? You are using a composite video cable (A/V y,r,w) and connecting it with the component video input (and then telling the TV to use the YPbPr source). You need a component video cable (3 RCA plugs on each end - red, green and blue) and an audio cable (2 RCA plugs - red and white) for the Wii. It wasn't included with the Wii but it does have the component video ports. Otherwise you would need a SCART to composite connector to work with the input. Alternatively, you could get an HDMI cable and connect that between the Wii and the TV (depnding on the age of the Wii).
If I've read this correctly, you have the media box and dvd player sharing the SCART input (EXT1).
I hope this helps.
Dec 26, 2010 | Toshiba Televison & Video
Hi. Just found this site. I have a Samsung LE32B450C4W TV. I am not technical at all and Virgin Media have installed us a V+ HD box today. However, I have now discovered when I turn the TV off and back on...
You should try this way. Unplug the box and replace by DVD player or others with HDMI output and turn/on off to see the TV keeps changing HDMI sources or not. If it is changed, you have to call service to replace the main board. Else, your TV works well.
Nov 12, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
No HDMI on the source list, i have a Virgin Media V+ Box with a HD cable pugged in and when i look at the source list the HDMI Port is not Highlighted, why is this? Please help
Nov 03, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Cant tune to hd from virgin box
You should not have to tune into HD, you should be connected via a HDMI connector from the Virgin box to theTV, which means you only need to select the HDMI input source & then select your channels fron the Virgin box.
Oct 24, 2009 | Televison & Video
I want to connect a Virgin HD box to my Panasonic TH-42PV500B TV currently connected to a Panasoniv DVD recorder On Scart AV1. How do I switch between Virgin and existing equipment which I would like to...
what you need to do is obtain an HDMI cable for your Virgin HD box. Leave the rest on scart (you can probably even add a another box now that you've freed up one port). Basically just press the button on your TV remote, saying 'Source' and you can flick through all your scart soxkets and HDMI ports. Simples.
Oct 24, 2009 | Panasonic Televison & Video
Connecting a dvd 250gb hard drive recorder to tv and virgin box
Right then, on the back of the virgin box there are 2 scart outlets, connect one scart from the TV scart port to the scart in on the DVD recorder, then connect one scart lead from the scart out on the DVD recorder to the TV.
Find the DVD recorder source channel on the TV and then use the DVD remote control to find the digital input on the DVD recorder, this is usually AUX channel.
Post back if you need any more help
Good luck and thanks for using Fixya!!
Feb 22, 2009 | Televison & Video
Poor signal bush hd set top box
I have a saterllite reciver just bought a bush hd freesat top box i am running my virgin cable tv through my samsung hd television i put my satallite cable in to my bush top box connect the hdmi cable to get the freesat turn my virgin box off source the hdmi cable on tv get the freesat logo but nothing else what am i doing wrong
Aug 31, 2008 | Televison & Video
Televison & Video Logo
22 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
