Question about Panasonic PT-FW100NT Projector Lamp Replacement
Put new lamp in and it still said replace lamp
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 729 Answers
Should to reset the timer in the Menu-setting- Option-reset the lamp hour
Posted on Dec 26, 2014
Replaced lamp on my Mitsubishi 82 in dlp. after 15 minutes pic started to flicker losing color. was advised to also change lamp ballast, did that but still flickers with new lamp. put old lamp back in tv...
When you put the old lamp back in did the picture look OK? If so why did you replace to begin with? Yes, there are some poorly manufactured lamps out there, where did you obtain the replacement? Was it true OEM?
Dec 04, 2014 | Mitsubishi Wd-82837 82" Inch 3d Full Hd...
Changed 6 lamps y65 none work can they all be bad
Sounds like the circuit that is responsible for sparking and maintaining the voltage to the lamp has gone bad. It's called the Lamp Driver.
Don't waste any more money on lamps. Get a tech to have a look at either repairing or replacing the lamp driver.
Sep 13, 2014 | Toshiba Televison & Video
I have a wd-57833 work good I got the same one from some one put in a new lamp tv work for 5 hr then stop working on sound or picture but the lamp is good i put in in my tv and it works so i put the p
If the lamp is new and good to go then you may have to reset the lamp replacement counter in your setting menu. When that is set back to zero you wont have a problem until it is time for a new lamp again.
Aug 19, 2014 | Mitsubishi WD Televison & Video
TV has new lamp but no color
Tried putting the old lamp back?
Jun 14, 2012 | Sony KDF-37H1000
Said replace lamp, now doesn't turn on
if it was working before lamp replaced "replace lamp" appeared on the screen either lamp somehow not in correctly, new lamp bad, or something happened during lamp installation--have you tried to put the old lamp back?
Apr 08, 2012 | Televison & Video
Can't see picture on my samsung tv...lamp, timer and standby light are blinking on the power button
You need to replace the lamp. Order the correct type and code number (from samsungparts.com or the store where you bought the TV). Before starting the replacement, make sure the TV has been off for at least 30 minutes and unplug the set. Remove the phillips screw that holds the lamp cover and then the lamp cover itself. Remove the two screws that hold the lamp to the housing. Pull the old lamp out by the handle. Put the old lamp in a safe place until you can properly dispose of it.
Handle your new lamp carefully (wear gloves to avoid skin oils on the lamp). Put the new lamp in the housing and close up the TV by reversing the above steps (secure screws, replace lamp cover).
I hope this helps.
Aug 14, 2010 | Samsung DLP HL-P5663W 56" TV
How to replace a bulb for kd rangehood
This is for a smeg KD series, it depens on the model which lights are used.
LIGHTS REPLACEMENT:
Before performing any cleaning and/or
maintenance operation, disconnect the hood
from the mains supply.
According to the model, the hood can be equipped
with different kind of lighting such as incandescent,
halogen and neon lamps.
a) Incandescent lamps: E14 – 40W 230V lamps.
To replace them, remove the transparent fixture
from the control panel, unscrew the lamp and
screw in the new one.
b) Halogen lamps: G4, 20W - 12V lamps . To
replace the lamp, use a screwdriver to remove
the glass-supporting ring. Then remove the old
lamp and insert the new one.
Put the glass back, securing it with the ring.
c) Biax neon lamps: G23 11W lamp. Once the
fixture has been removed, remove the biax lamp
from its seat and support.
Put a new lamp in, performing the same
operations backwards.
d) Neon lamp: 15/18W neon tube. To reach the
neon tube, unscrew the glass framework screws.
Rotate the tube 90 degrees and remove the neon
lamp. Install the new neon tube and put the glass
framework back.
Hope this helps
Apr 13, 2010 | Kitchen Ranges
I've got a replacement lamp for a Samsung HLR 5067. The old lamp is a BP610125A. I was told that the new replacemet lamp is a BP96-00826A. The problem is the new Lamp's housing seems too big for my Hd...
I have the same bulb and was told by Replacement Lamps the same thing. No you can not switch the housings. I tried. The bulb is too large and does not fit in the old housing. It is the wrong lamp all together.
Aug 22, 2008 | Televison & Video
Sony Wega KDF-55WF655 blue ghost problem after replacing lamp
It is a defective light engine and it must be replaced. I hope you have a warranty because Sony will not help you.
Apr 06, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Panasonic PT-FW100NT Projector Lamp Replacement Logo
54 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
