Question about Freezers
Refrigerator just stopped cooling all of a sudden. neither side is cooling and the freezer side is barely freezing all of food is going to waste help please
  • 111 Answers
Is the compressor running ? if yes feel the cooper tubes around , the tiniest one is suppost to be hot if is not hot u have a leak call a tech . if it is hot open the freezer and take the back cover inside of the freezer if the coil is totaly covered with ice you have a defrost problem , check the timer , bimetal and heater
Posted on Jun 19, 2009
Samsung model rs263tdpn fresh food stops cooling.
Air channels freezing? they might be blocked with foreign matter, clean them out. This might also be as simple as turning down the dial for how much you wish to cool the unit. Running it constantly at full blast is not a good idea.
Oct 08, 2012 | Samsung RS263TDPN 26 cu. ft. side by side...
Freezer drops in temperature and food defrosts; freezer then re-starts and re-freezes food
Hi, The unit is sticking in defrost for too long...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 05, 2011 | GE Freezers
Kelvinator no frost KBNT23AS back plate in the freezing compartment is icing up but the ice trays are not freezing. The lower compartment is not getting cool enough.
heatman101
Apr 05, 2011 | Frigidaire Freezers
Freezer will not cool,i.e.freeze food.Compressor is very hot.
The compressor may be overloading because of a bad relay. The relay is on the side of the compressor. Disconnect power from refrigerator then remove the cover and remove the relay. Then shake the relay and if it rattles it is bad. http://www.appliance-repair-it.com/Refrigerator-repair.html
Sep 18, 2009 | Freezers
1999 Frigidaire Refrigerator
Check rear wall of freezer by feel for frost. Heavy, even frost indicates likely problem in the defrost system. Unplug unit. Defrost heater (in freezer behind rear wall panel), defrost thermostat (same area-must be checked at freezer temperature) or Defrost timer-located lower back outside of unit. Near compressor. Do continuity test on heater and defrost thermostat and if they show continuity (good), replace defrost timer. If not, replace the one that tests bad.
Defrost coils fully. Reassemble.
Please let me know if I have helped with comments and rating.
Refrigerator will work about 7-10 days after being defrosted until thick frost builds up again cutting off air flow to both compartments
Sep 07, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
Refrigerator does not get cold
In your freezer section, there should be a "control" for the freezer temp. I say "control" because the knob is attached to a flap that only controls airflow the the lower section. If the knob is turned to coldest it will block almost all of the air from getting into your fresh food section.
Jun 14, 2009 | Frigidaire Freezers
I have a maytag side by side refrigerator freezer and the lower part of the freezer where the cooling coils are freeze up and won't allow the air to cool the refrigerator side.
Sound as though you need a defrost timer that is located around temp control and light in fridge side.If it is faulty it will not go into a defrost making the freezer ice up and cause alot of trouble.hope i helped thanks:)
May 12, 2009 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Freezer/Refrigerator tempurature swinging wildly
The compressor is overheating and not starting. Could be just the start relay. If this happens again try unplugging it for about an hour then it should work for a while. Heat between doors is normal this is an electric heater designed to keep the doors from sweating. You just noticed it because the refrigerator wasn't cold.
Jun 26, 2008 | Freezers
Freezers Logo
104 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
