Question about Whirlpool Duet GHW9150P Front Load Washer
It says F 21 and shuts off!! help us
Help
  • Joe Povoas May 11, 2010
    model# please
  • 15,935 Answers
Remove torx 3 screws from front panel
Put notched-out bucked under the white tubed filter
Loosen filter & let water pour out (approx. 4 gallons of water),
Clean out filter.
You'll probably find pencils, panties, coins, etc. blocking the water flow.
Look at the motor assembly on the right side next to the filter to be sure there is nothing there in the pump impeller (socks, panties etc.)
Reassemble both; make sure to line up notches on the white filter. Reassemble panel, plug in and try a load.
You should be all set!
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Jun 19, 2009
21 horsepwer enine smoked and then stopped running
Check the oil is it low...some engines have a low oil shut down...and will not start or run when too low Good luck
Aug 04, 2015 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Fraser Johnston Furnace - Not heating
Check the furnace filter to make sure its not dirty . Dity airvfilters can cause the furnace to overheat and shut off on a high temperature limit switch when the switchs cools down it resets but the furnace has to be shut off to reset the control board. Hope this helps.
Jan 23, 2014 | Heating & Cooling
Working on a N1321-ASME unit installed in a Taco Bell. Getting error code 21. Unit gas pressure is at 8.5wc and manifold pressure spikes to 2 when it come on but unable to see what it remains at because...
I recently had a similar problem with my N-132M-ASME heater. The unit would come on, then shut down and flash Error Code 21. According to the owners manual, that code indicates the unit is not getting enough air. I tried vacuuming the unit, blowing it our with air and checking to be sure the exhaust lines were clear. Nothing helped. A service technician came out and recommended I descale the unit and clean the burner. I did this but the problem did not go away. He also suggested I replace the Burner Sensor. It's not an expensive part, around $20. I ordered the part and have not had a problem since I installed it. Hope this helps.
Jul 09, 2011 | Noritz Commerical Tankless Water Heater...
New yard man 21''-- mulching -- too much grass comes out left front wheel area and covers engine when cutting -- help...
Maybe try removing that blade and checking it/sharpening it. You could also install a new blade or a 21" mulching blade that is designed a little different, giving a different cutting process and results. When the grass comes out by the left front wheel, have you shut the mower down and checked for any kind of grass build up under the deck?
Sep 15, 2010 | Garden
My GE microwave will only run for 21 seconds and then it shuts off. Even if I try to heat something by running it for 21 seconds multiple times, it doesn't get anything warm.
I've heard of this is Panasonic microwaves but not in GEs.
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, as well your symptoms "only run for 21 seconds and then it shuts off".
For those readers with a a Panasonic that stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Nov 27, 2009 | GE Profile 1.5 Cu. Ft. Mid-Size Microwave...
Whirlpool Duet GHW9150P Front Load Washer Logo
78 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
