Question about Duplo Office Equipment & Supplies
Runs for about 5 seconds with a loud noise, then turns off.
2 Suggested Answers
  • 311 Answers
SOURCE: The refrigerator keeps making a loud buzzing
Sounds like your starting components are bad on the compressor. If the freezer section begins to loose temp then this is probably the case. They will try to start the compressor and then it will kick off on its overload. However this will usually occur every 10-15 mins when they are completely toasted. Your compressor may be starting up part of the time and not starting the rest. Either way you will probably need new starting components on the compressor. You could also check to make sure your condenser fan motor is running (in the back of the ref behind the access panel) because this could cause the compressor to overheat but usually wont cause a buzzing noise.
Hope this helps _MJ_
Posted on Feb 07, 2010
Mod: kuds30ixss6 - Making a loud noise
You are going to have to remove the spray bars and the filter at the top of the pump housing to see if something is stuck in the pump
Jan 06, 2014 | KitchenAid Dishwashers
2007 dodge ram fuse problem
my 2008 dodge ram is displaying no fuse underneath the spedometer. it makes a clicking noise about 5 times and turns over fine. runs normal/drives normal. it delays when turning off (i turn the key off and it takes about 5 seconds to turn off) remote entry does not work.
Feb 12, 2010 | 2007 Dodge Ram Truck
Washer runs until rinse cycle, then starts making
pull problem code from machine. give knob a turn to wake machine-wait 5 seconds-then hold down start and cancel buttons at the same time. Your problem code will come up.
Nov 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Loud Intermittent Buzzing Noise Jeep Cherokee Sport 2.8 CRD 2005
I would need to hear this noise to help, sorry, but you need a shop to look into this.
Feb 07, 2018 | 2001 Jeep Cherokee
1999 Honda Accord ac makes loud noise on med or high
So does mine,when you set the temperature you want the automatic temp control runs at high speed to either reduce or increase temp but should reach temp required within about 5 minutes.
Aug 14, 2009 | 1999 Honda Accord
Kenmore 970 C81062 10 Electric Dyer WILL NOT
It sounds like the drum may be stuck. Turn the dryer on with the door open, just keep the button pushed. Then try to turn the drum by hand, and see if it will start to turn.
Jun 04, 2009 | Dryers
Loud screeching noise coming from car after stops.
the screeching noise is most likely caused by a slipping belt or pully. transmission probably needs fluid and filter changed.
Jun 02, 2009 | 1990 Ford Tempo
98 gs300 loud screeching noise that last for about 5-10 seconds
The only four rotating items under the hood are
engine
power steering pump
A/C compressor
and smog emission pump.
==== I would check the fluid level on the power steering first. Check for pink fluid leak on the ground,
==== Check the A/C system with the wheel turn to one side and APPLY ALL LOADS.
Example: high beam on,A/C max,radio on and deforster on.
This will give you system a stress test.
All eyes on the pully and locate to part that generate the loud screeching noise.
My bet is on the power steering pump.
Please post more info on the comment window.
I will follow up on it.
Feb 12, 2009 | 1998 Lexus Gs 400
KV-32FS120 makes a loud noise and green tint when turned on
Loud noise is possibly made by Degausing Coil to demagnetize picture tube and its normal.
Green tint shows picture tube is bit weak in electron emission due to its age and takes time to present good white balance result (good colors)
Sep 11, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
13 people viewed this question
Top Duplo Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Duplo Office Equipment and Supply Expert? Answer questions, earn points and help others
