Question about KitchenAid KSRV22FV Side by Side Refrigerator
Leveling new Kitchenaid Fridge
The fridge is hooked up but the floor is not level. I looked in the manual and I looked at the machine and I can not see a logical way to level it.
If you know where to look I would appriciate it.
Thank you!
Ian
    President:
  • 1,136 Answers
Hi, Remove the front kick plate and locate the adjustment screws in front corners. Usually 3/8" or 5/16" head bolts.
Realize, there is only so much adjustment. You might have to level the back side with thin boards or shims.
I hope this helps. Please let me know if I can assist you further.
Vic
Posted on Jun 19, 2009
How do I level my domestic kelvinator fridge . the floor seems to be level . I recently relocated to Cairns
the front feet under the door opening are adjustable screws. You may have to use a shifter to get them to move as they mat be rusted . adjust so the fridge slopes slightly to the rear. This keeps any moisture on the back wall to drain out the hole and the door will close if left open
Mar 03, 2015 | Kelvinator 12 cu. ft. / 340 liter Chest...
How do you install the fridge evenly in the alcove?
#1 is floor level?
#2 does it wobble?
#3 check owners manual-LEVELING THE UNIT there should be adjustable 'feet' that screw into the bottom frame of the unit.some have adjustable wheels at the front.remove the vent panel under the door and look under with a flashlight to see what you have.
Jan 22, 2013 | Fisher Refrigerators
The fridge door will not stay closed. I changed the gasket, tightened the door screws, cleaned the contact area and it still pops open.
After all the good ideas you've already tried, the next things on your list could be:
(a) level the floor under the fridge - they often sag under the heavy weight of a loaded fridge due to moisture/rot.
(b) level the fridge itself - using the leveling legs. If the fridge continues to have a problem with
the door poping open, try raising up the front of the fridge above level.
(c) unload the door pockets - making the doors lighter may help solve the problem.
Aug 17, 2011 | Refrigerators
Fridge is leaning back, how do you level it? it is model afi2538aes
Check first if it is due to the body of the fridge being distorted or just the leveling of the floor. For the floor, others would purchase a separate base for the unit where its feet can be adjusted. Others would have themselves fabricate one. But it is imperative to find the cause first.
Oct 31, 2009 | Amana 22.6 cu. ft. Side-By-Side...
KitchenAid refrigerator(leveling screw problem)
Realized after studying the parts list (on kitchenaid.com) for the model that the screw I couldn't get back in is BROKEN . Repairman coming tomorrow. Maybe that is why the thing sits so low ...
Aug 19, 2009 | KitchenAid KBLA20ERSS Stainless Steel...
Door not closing properly
Hi: The Kitchenaid refs. us a gravity close along with the magnets in the door seals. Magnets getting weak seals getting old and what you told me you checked can cause this. The easy fix is to raise the front of the fridge by lowering the front wheels. Pull the grill off the front and find the leveling screws (usually labeled.) Raise the front of the fridge until the doors swing shut with a gentle push. Before you replace the grill make sure the fridge dosn't rock side to side as you want it even. This is what they call leveling a fridge. Not cabinet level. Just sturdy. Hope I helped, Jeff
May 31, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Fridge door is lower then freezer door
The #1 cause for this problem: The floor beneath the fridge is uneven, causing the refrigerator "box" to be out of square. Adjust the levelers on the fridge bottom to compensate for the uneven floor. That should do it.
May 19, 2009 | KitchenAid Superba Architect KSCS25INSS...
Front leveling wheel broken-Can't move Fridge
go to good hardware shop of fridge retailer and there you will get small trolleys that you put the fridge on and then it rolls to where you want it
they come in a pack of 2 and fit under existing feet and rollers
Jun 06, 2017 | Refrigerators
Adjusting the hight to make it level
Try various pieces and thicknesses of plywood under the corners of the fridge to aid in leveling. I have this same issue as I have an old house and am awaiting the arrival of a new fridge. The major issue is the corner isn't square nor is the floor level. Its a doozy of wood mosaic let me tell you @@
Apr 17, 2008 | Refrigerators
I need help to level my kitchenaid fridge, and the owner manaul does not show this.
leveling refrigs, can be abit tricky, depending on level of floor especially, for the most part only the front 2 legs/wheels are going to be adjustable, the rears if need be will have to be chocked with wood shims . as a repairman for nearly 20years, i rarely "level" refrigs, , for the reason of who knows if the cabinets are level, or how level the floor is, i in turn make the refrig appear level and make sure its stable when the doors are opened and closed. not essential for level (shloud be close butno need to be perfect, id much rather a refrig tht looks good and doenst shake when door is closed, rathe then tryin to get it perfectly level and then seeing a 2 inch gap at top of cabint and flush against the bottom.
Apr 03, 2008 | Refrigerators
KitchenAid KSRV22FV Side by Side Refrigerator Logo
1,483 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
