Question about Kenmore Microwave Ovens
SC-4 code flashing - Kenmore Microwave Ovens
Press 'cancel' for three seconds to lock the screen. Press again and hold three seconds to unlock the screen. It should be back to normal.
Posted on Apr 24, 2014
How to fix E5 code for Samsung Microwave
About 64,200 results (0.62 seconds) Search Results
    Fixing a broken Samsung Microwave - The dreaded 5E ...
    ? 4:30
    https://www.youtube.com/watch?v=_yWSU0kTkTg
    Mar 20, 2013 - Uploaded by Joe Devlin
    When my Samsung Microwave was just over a year old it failed giving me an "5E" or "SE" Error code which ...
    Samsung Microwave SE (5E) Error Fix - YouTube
    ? 9:23
    https://www.youtube.com/watch?v=YubSrHE7WFc
    Dec 7, 2012 - Uploaded by eric hatch
    I had pretty much decided to throw it away since the cost to fix it by a ... Fixing a broken Samsung Microwave ...
    Samsung Microwave SE Error FIX! - YouTube
    ? 1:33
    https://www.youtube.com/watch?v=oPQE2oLTR3o
    Jan 26, 2014 - Uploaded by jjthetechguy
    I am not responsible for any damage done to your microwave*** ***Do at ... Fixing a broken Samsung ...
Jan 27, 2016 | Samsung SMH8165B Microwave Oven
How do i remove the door to fix the latch.
open front grill slid to the left on the r open sc left up and then 2 sc . new .
Feb 01, 2015 | Samsung Microwave Ovens
My kenmore elite microwave is displaying sc-4 and the keypad won't work.
Same thing happened to mine. Still trying to figure it out.
Feb 13, 2014 | Kenmore Microwave Ovens
Getting an "EE" and it
Check this against your code, but iff EE is flashing you may have an internal electrical fault that needs to be checked out by a repair person.
  1. Frigidaire
  2. GE
  3. Panasonic
  4. Sharp
  5. Whirlpool
Sharp commercial grade microwave codes....
EE Mode Reason Action Required EE 1, EE 2 Magnetron failure
Call for service*
EE 3 Both magnetrons failed Call for service. EE 4 R-23GT, R-24GT and R-25JT only
Voltage too high Follow instructions on page 5 of Operation Manual under VOLTAGE SELECT to change from 208V to 230V. If problem is not corrected, call an electrician. EE 5 R-23GT, R-24GT and R-25JT only
Voltage too low Follow instructions on page 5 of Operation Manual under VOLTAGE SELECT to change from 230V to 208V. If problem is not corrected, call an electrician. EE 6, EE10, EE16 Thermistors failure Call for service. EE 7 Exhaust air temperature too high
Check that nothing is blocking air intake openings on oven back or that oven exterior is very hot. Correct. Wait a few minutes and try again. If problem persists, call for service.
EE 8 Circuit failure Call for service. EE 9 Maximum time is exceeded
Check page 11 in the Operation Manual. Touch STOP/CLEAR pad, and reprogram correctly.
EE 0 Fan lock error Call for service. EE17 Magnetron temperature too high
Touch STOP/CLEAR pad. Wait a few minutes and try again. If problem persists, call for service.
* EE 1 and EE 2: Can continue to use oven before service; however, check food carefully as additional cooking time will be needed.
Any time the EE is flashing, the servicer should be called. When EE is not flashing, check the reason and correct. Service is not necessary.
Aug 20, 2011 | Microwave Ovens
I have a Indesit DI 620 dishwasher that wont empty its water and with an error code of no 2 and 4 flashing rapidly, what can this be please ?
You should consult your owners manual for the error code description in the back under "troubleshooting". The obvious problem is that you are not rinsing your dishes enough and the bottom drain is clogged and needs to be cleaned out. The food will clog the hole and back it up.
Oct 09, 2010 | Microwave Ovens
Sylvania Microwave oven SC-11100 We have one of
Had a power outage when the unit was hooked up power came back on now unit is beeping like morris code, how do i clear or reset.
Sep 17, 2010 | Sharp R-353 Microwave Oven
My Kenmore Elite Microwave Model No. 721.64683300 does not seem to be heating well and will shut off and flash an F9 code. What does the F9 code mean
Oct 07, 2009 | Kenmore Microwave Ovens
Flashing dispaly of 4 eights, with no response from keypad
First check all door switches are properly working. If they are ok , the defect may be in the key pad. You need to replace the key pad.
May 26, 2009 | Sharp R-510HW Microwave Oven
Microwave Ovens Logo
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
