Question about Cook's Essentials Juicers
It need the trash container - Cook's Essentials Juicers
How do you take the top off to clean the bottom container after use?
The manual for your Jack LaLanne Power Juicer can be found here:
http://www.powerjuicer.com/power-juicer-manuals.php
The manual contains illustrated assembly and disassembly instuctions
You may also find the How To videos to be helpful:
http://www.powerjuicer.com/power-juicer-how-to-videos.php
Aug 01, 2011 | Jack Lalanne Power Juicer 250 Watts
How do I open it to clean up
Go to this website: http://www.powerjuicer.com/power-juicer-manuals.php
Select your model to open the Operating Manual which contains illustrated assembly and disassembly instructions.
You will also find a number of useful links on the right hand menu as well as a selection of How To videos that may be helpful.
Mar 07, 2011 | Jack Lalanne Power Juicer (Stainless...
I have the beaumark juice extractor BM-473 it worked then i washed the removable parts now it wont work
the first solution is half right ... there are 2 hidden switches on the machine which are activated by shafts on the pulp container and on the top lid .if either is not on then machine will not work. possibly broke plunger on the pulp container ....or broken clip that holds the container in place
Jan 04, 2011 | Champion G5NG853S Household Juice...
How do you take apart a jack lalanne juicer to clean it
Suggest you review the series of How To videos on the Jack LaLanne website:
You will also be able to find your Operating Manual which contains illustrated Assembly and Disassembly Instructions
Jun 22, 2010 | Jack Lalanne Power Juicer 250 Watts
I can't take apart my new indulgence by mistral juicer for initial clean. I was able to take off the clear top and pusher and the pulp container, but can't get the filter out or spout.
i have a mistral mss25 air conditiioner and i need to clean the filters is the only the 2 large square filters or is there another somewhere which needs cleaning?
Jun 27, 2009 | Juicers
I cannot remove the blade and screen from my Jack Lalanne juicer......saw mention of the cresent tool which I did not get.........can anyone help?..........SW
Wear leather gloves or double rubber gloves. Hold on right on top of the sharp blades and turn it. You can also bend a 1/8 th inch diameter thick wire, galvanized or anything metal and insert both ends on the holes on the blades and turn it. Make sure you don't slip your hands on the sharp blades.
Jan 28, 2009 | Jack Lalanne Power Juicer 250 Watts
No way to send the fruits & vegetables through:/
1-800-233-9054, or online at foxinternational.com if you are in the U.S.A. I am pretty certain they will have it. I lost mine--& use a long carrot to push whatever through. If some of the carrot gets juiced--no problem. It is good for you, & tasted great!
Oct 21, 2007 | Juicelady JL500 Juice Extractor
Just stopped working
I am sorry I might not be able to explain in English very well, but I hope it will help somebody.
In my case, the pulp container was a problem.
when you take out the container, do you see the little(very very small )hole that if you push with something like toothpic it makes sound like "click, click"? I guess when we put the pulp container back, the container is supposed to push the safety button ( bottom area), but I think the part of the container that push the button was broken, and it didn't start,so I just put something small inside the hole before I put the container back to the juicer, so it covers the missing part.
Their customer service doesn't help at all, I waited 1h to talk to somebody, and he couldn't help me. so please check that part.
Sep 04, 2007 | Jack Lalanne Power Juicer (Stainless...
Juicers Logo
Top Cook's Essentials Juicers Experts
Tom Chichester
David Payne
David Payne
Are you a Cook's Essentials Juicer Expert? Answer questions, earn points and help others
