Question about Goodman CLJ30AR32 Air Conditioner
Continues running of air and heat when switch
  • taa43 May 11, 2010
    what
    Sergeant:
  • 340 Answers
You need service.
Posted on Jun 19, 2009
I have new blower motor. it dosen't stop running
Could be a bad blower motor resistor,mounted by the blower.
Sep 28, 2016 | 2002 Dodge Ram Pickup 1500
I have a ler4634eqo and it runs but it stopped heating up and drying the clothes. It still blows air just cold air.
check circuit breaker heat is on seperate circuit may run with one circuit then check continuity on element,then limit switches, then timer
Feb 11, 2013 | Whirlpool LER4634J Electric Dryer
My fan runs continually, even when I switch the thermostat to 'off' between the heat and cold setting.
There would be a relay,or transistor malfunction in the unit that controls the fan motor.
Apr 16, 2012 | Heating & Cooling
Engine cooling fan will continually run,
It seems you are low in coolant. The temperature sensor has air to sense instead of liquid and temperature gauge will be low. Try to fill up with coolant but sometimes it's hard to get rid of air from the system. Have you changed the engine thermostat?
Hope it helps
Feb 04, 2018 | 2005 Pontiac Montana SV6
The thermostat works fine for heat, but as soon as I switch it to cool, the air conditioning will kick is but the inside thermostat will not change, causing the air conditioner to run continuously
If the temperature doesn't drop when the air conditioning is running for some time (two hours), the air conditioner is not working. The problem is not in the thermostat.
Gary
Jun 14, 2011 | Honeywell CT500 Digital Heat / Cool Manual...
Indoor fan blowing cold air when on heating
The indoor fan will continue to run. When heat pump goes into defrost the outdoor fan stops, the reversing valve switches and the unit is basically working in the cooling mode. In order for you not to feel a blast of cold air in the winter the electric strip heat also comes on so the indoor fan must run while the strip heaters are on.
Jun 03, 2010 | Heating & Cooling
Furnace blower won't stop running
Usually when the furnace blower motor runs all the time
The limit switch or rollout switch is usually open or bad.
The furnace board is seeing that one of those switches is open, so it brings the blower on to try to get the heat out of the combustion chamber area, so the switch will close. But if the switch is bad and won’t close, the furnace board will keep the blower running continuously.
Jan 04, 2010 | Amana Comfort Zone 12M32PBEH Air...
Runs continuously and will not switch to heat
Pull the cover off the unit with it running in a/c mode than touch the line going into the top of the outdoor coil it should be hot, if it is not than it may have developed a leak and now is very low or out of charge.
Nov 04, 2009 | Dometic Rooftop RV Air Conditioner
Continues to run
yes I would switch it over due to the fact that the balance point reached. Since I'm not there to look at the system monitor the actual temperature inside and if you cannot maintain the setpoint on the thermostat you may have to bring it back on. I've seen recently that there was not enough backup heat to keep the house warm enough during cold spells. Stay warm.
Dec 22, 2008 | Ruud Central System Air Conditioner
Ptac fan keeps blowing
Try setting the fan control to "AUTO" this will cause it to cut out with the compressor.
May 02, 2007 | Amana PTH123B25AJ Heat Pump Air...
Goodman CLJ30AR32 Air Conditioner Logo
48 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
