Question about Samsung i9500 Galaxy S4 16GB Unlocked Black Mist
How to unlock a blacklisted galaxy s4
My galaxy s4 doesn't work, I think it is blacklisted because ive tried almost everything to unlock it but it doesn't. I can receive messages but I cant open them. please help
archie4248
  • 80 Answers
SOURCE: I own Samsung Galaxy S
Viewing PXT messages is dependent on the settings of your celphone provider. Contact them for configuration settings which they can send directly to your phone.
Posted on Mar 21, 2011
ashraf achu
  • 274 Answers
SOURCE: Cant make or receive calls as it has been blacklisted
Hi..
Thank you for contacting fixya. We are happy to help you. Please let me know the model number of mobile
Ashraf
Posted on Jun 06, 2014
vansheene
  • 309 Answers
SOURCE: i need my samsung galaxy s4 work in other country, i need free unlock code.
Let's start with the most common Hard Reset methods and go from there:
Note: the different types of methods are numbered, method 1, method 2, method 3, etc.
1. When the phone is powered off, press and hold the Volume Up and the Volume Down keys both at the same time, then press and hold the Power key until a test screen that shows some available options appears, usually takes about 15-20 seconds. When that screen pops up you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights FACTORY RESET then press the Power key to select it.
2. Power the phone off all the way, press and hold the Volume Down key and press than release the Power key, still holding the volume down key for about 10-15 seconds. When you see some additional options pop up on the screen you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights the reset option; it usually says FACTORY RESET, then press the Power key to make the selection.
3. While powered off, press and hold the Home key, while continuing to hold the home key power the device on by pressing the Power key.
Once the Android Recovery screen appears release the Home key, then while on the Android Recovery screen, press the Volume Up and Volume Down keys both at the same time.
If/when you're on the Android System Recovery screen release all the keys, and then use the Volume down key to navigate down to the "wipe date/factory reset" option. Once it's highlighted press the Power key to select it.
Once you see the "Confirm wipe of all user data?" Press the Volume down key to highlight "Yes-delete all user data", then press the Power key to select it.
4. Power the device off, then press and hold the Home key and press and release the Power key (while still holding the Home key).
From the Android Recovery screen, press the Search key.
Tap to select wipe data/factory reset then select Ok (located in the lower left of the screen). Note: if screen is not responsive use the Volume keys to scroll and the Camera key to select.
Select Yes - delete all user data, and then select OK (again lower left).
Select "reboot system now" and press OK.
5. This is becoming a common hard reset method and can be used to factory reset Samsung's more recent Galaxy smartphones such as the Samsung Galaxy S III, the Samsung Galaxy S4, the S5, the Samsung Galaxy Note the Note II and Note 3, etc.
With the device powered off press and hold the Volume Up key the Home key and the Power key all at the same time.
When the phone vibrates (or you see the GALAXY Logo) release the Power key but continue to hold the Volume Up and Home key.
Continue holding the Volume up and Home key until the "Android system recovery" screen appears.
Use the Volume buttons to scroll to and highlight the "wipe data/factory reset" option, and then use the Power key to make the selection.
Once the factory reset is finished you may use the Volume and Power keys to highlight and select the "Reboot system now" option and the hard reset will be complete and your cell phone will be nice and squeaky clean.
6. Here is an alternate reset for a Motorola Atrix still running on the 2.2 Android OS...
While the phones power is off, press and hold the Volume down button and press and release the power button (note: if it doesn't work after all the steps listed try holding down the power button along with the volume down button in this first step).
A "Fastboot" screen should pop up, press the Volume down key to cycle through the choices until you get to "Android Recovery", then press the Volume up key.
Wait for the "triangle!/Android". Once it pops up you'll need to tap on the bottom right corner of the screen (note: it may take a few attempts). A menu should pop up.
Tap on "wipe data/factory reset", and then tap OK. Another confirmation screen will appear. Tap Yes and then OK.
After the data is cleared the "reboot system now" option should appear and is highlighted by Default. Tap OK.
Note: this type of reset is common on the 2.2 (Froyo) before the tech geeks wised up and removed the need to use the touch screen.
7. This reset is for the same phone, the Motorola Atrix, but one that's running on the 2.3 OS.
Power off the phone, press and hold the Volume down button and Power button simultaneously while powering on the unit.
The "Fastboot" screen should pop up. When it does press the Volume down key to cycle through the choices until you get to "Android Recovery", and then press the Volume up key to boot in this mode.
Wait for the "triangle!/Android" screen to pop up. Once it does press both the Volume up and Volume down keys simultaneously. A Recovery Menu should pop up.
Tap on the Volume down key until "wipe data/factory reset" is highlighted, and then tap the Power button. Another Confirmation screen will come up. Tap on the Volume down key until it highlights "Yes" and then tap the Power button to make the selection.
After it's done make sure "reboot system now" is highlighted and then tap the Power button.
In this method you don't have to use the touch screen any more. So let's say your touch screen isn't responding therefore you can't navigate the phone or go into your settings and do a regular factory data reset. Well now on the 2.3 there is hope. Just power off the phone and perform these steps and the reset should go through.
8. Here is a hard reset for a Sharp Android Smartphone.
While the device is off, hold the Sym button (it's located on the keyboard) and the Power button simultaneously.
Once the Android boot screen appears highlight the Wipe data/factory reset option by using the volume buttons. Then use the Return key (on the keyboard) to actually make the selection.
Scroll down to Yes - delete all user data and then press the Power key to confirm.
Once it is done select reboot system now and press the Power key to confirm and reboot your handset.
Posted on Jul 04, 2014
rick37616
SOURCE: How to Set up smart watch gv08
Go to https://www.youtube.com/watch?v=I73mo48KO4s
then go to 4:50 on the video. Follow his instructions to get to languages. You will have to do this by how many lines to go down, since like me you probably do not read Chinese. This is how I changed my watch to English.
Posted on Mar 12, 2015
eddietam
  • 284 Answers
SOURCE: samsung galaxy s4 paywave
As of 9/10/2015: Google has been releasing "Android Pay" to select devices.. Google Wallet is being fazed out.
Article:
Google officially rolling out Android Pay starting today Update Grab the...
Download Android Pay from the Google Play App Store here:
Android Pay Android Apps on Google Play
Youtube video:
Android Pay Is Starting To Roll Out To Replace Your Google Wallet App APK...
Youtube video:
How to Get Use Android Pay in Any Country Android Pay REVIEW
Posted on Dec 07, 2015
How do I remove Samsung Galaxy S5 Active imei number from blacklist?
You will need to ask your cellphone provider. Normally blacklisted because it is stolen, or has been moved to another carrier when the previous carrier still owns the phone under an unexpired contract. This is the official line on this
You can check your IMEI number is Blacklisted in AT&T, Verizon, T-Mobile, Telus, Sprint...Blacklist IMEI is lost, stolen or ineligible (Bad, Barred, Blocked, Financed, Under Contract) mobile phone. Always check blacklist before buy, sell or get phone.
http://www.protectyourdata.ca/check-the-status-of-your-device-in-canada/
http://imei-number.com/imei-blacklist/
https://imeidata.net/blacklist/check
Unlock Bad IMEI Phone that Blacklisted Blocked or Stolen
Mar 04, 2016 | Samsung Cell Phones
I've locked myself out & need to unlock it. I have turned on TalkBack & I need to turn it off.
How to Bypass the Samsung Galaxy S4 Lock Screen ...
droidlessons.com/how-to-bypass-the-samsung-galaxy-s4-lock-screen-pas...
Feb 5, 2014 - Did you forget the pattern to unlock your Samsung Galaxy S4smartphone? ... you unlock and bypass the pattern lock screen security even if youhave ... After about 5 incorrectly drawn patterns it will lock you out and tell you to ....It's been more than a month already that I've been trying to find a solution for it.
How to Unlock Android Phone - JoyofAndroid.com
joyofandroid.com/how-to-unlock-android-phone/
Feb 13, 2014 - Do you feel foolish because you locked yourself out of your phone? Learn how to ... I've tried it and every # combination I could think of. Nothing ... I have a question- I accidentally locked my Samsung Galaxy S4. I know my pin ...
What to do if you forgot your Samsung Galaxy S6 lock screen
Dec 14, 2015 | Samsung GALAXY S4
How do I change imei# on galaxy s4 that is blacklisted?
Try this website: http://forum.gsmhosting.com/vbb/f777/galaxy-s4-gt-i9500-repair-imei-null-null-1685562/
Aug 03, 2015 | Samsung GALAXY S4
Unlock blacklisted phone
Blacklisted means tha tit has been stolden. Atttempt to find and return to the rightful owner.
Sep 08, 2014 | Samsung GALAXY S4
Free imei unlock codes
Hello. I couldn't find any reliable and free unlocking source for a Samsung Galaxy S4 from online. Most of the free offers were looking to be scam with many negative reviews. If you want to unlock your device safe, you need to spend something for it. For example, you can visit Unlock-Zone.com and get the accurate unlock code for your Samsung Galaxy S4 at affordable cost. Good luck.
..............UNLOCKING INSTRUCTIONS..............
Method 1:
1 - Switch ON your Samsung Galaxy S4 with a NOT ACCEPTED SIM Card.
2 - Samsung Galaxy S4 will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung Galaxy S4 shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung Galaxy S4.
3 - Compose : #0111*CODE#.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung Galaxy S4 is locked to.
CODE: Its the unique Unlock Code for your Samsung Galaxy S4.
If method 2 does not work, you can try method 2 again but this time without any SIM card on your Samsung Galaxy S4.
SOURCE: MobileUnlockGuide.com
Aug 18, 2014 | Samsung i9500 Galaxy S4 16GB Unlocked...
Remove blacklist off my phone
Go to androidrooter.com. he can fix blacklisted phones
Jul 31, 2014 | HTC One X Android Smartphone Glamour Gray
How to unlock s4 sgh-m919-ud?
Hi. What is the exact model of your Samsung phone? If you want to unlock your Samsung Galaxy S4, you can unlock it safer and easier using unlock code. You can get the accurate unlock code for your Samsung Galaxy S4 from ProUnlocking.com at affordable cost.
Method 1:
Method 2:
Jul 25, 2014 | Samsung Cell Phones
How to unlock samsung galaxy s4 t-mobile
Hi. You can unlock your T-mobile network locked Samsung Galaxy S4 safer and easier using unlock code. You can get the accurate unlock code for your Samsung Galaxy S4 from Unlock-Zone.Com at affordable cost.
Method 1:
Method 2:
Jun 27, 2014 | Cell Phones
Lycamobile simnetwork unlock pin
How do i found my puk code number lycamobile
Feb 16, 2014 | Samsung Galaxy S4 Mini
Samsung i9500 Galaxy S4 16GB Unlocked Black Mist Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
