Question about Vizio VBR210 Blu-Ray Player
Need firmware update
Cannot find firmware for my specific player help!
How do i connect and update firmware
Normally on any DVD or Blueray player that has a network (RJ45) connector on it you simply need to plug in a network cable that is attached to your router. Then in the menu's there should be a system menu or update menu that you select and then the option for firmware or system update should be visible. You do not state model so I cannot be more specific.
Jul 05, 2015 | Televison & Video
My philips mp3 player shows updating and it got stuck. its neither switching off or being recognised by comp...wat to do now
Hi pimmi31,
Sounds like you could benefit from performing a firmware update on your unit. Instructions are listed below, and you can also visit http://ow.ly/64ye8 for more information like FAQ's, manuals, software, etc.
Hope this helps! Let me know by rating this solution. Thanks!
date your player
Your player is controlled by an internal program called the firmware. Newer versions of the
firmware may have been released after you have purchased your player.
A software program called Philips Device Manager enables you to update the firmware on
your device if a new firmware is available on your PC. Install Philips Device Manager from the supplied CD or download the latest version from www.philips.com/support (see above link for product specific page).
5.1 Manually verify whether your firmware is up
to date
1 Connect your player to the computer.
2 Launch Philips Device Manager from Start > Programs > Philips Digital Audio
Player > SA31XX > Philips SA31XX Device Manager.
3 Make sure you are connected to the internet.
4 Click Update.
> Philips SA31XX Device Manager will check whether a new firmware is available on the
Internet and install it on your player.
5 When Update completed appears on the screen, click OK and disconnect the player.
> A message Updating firmware will be displayed.
The player will automatically restart after the firmware has been completely updated. Your player
is now ready for use again.
Aug 16, 2011 | Philips GoGear SA3125/37 MP3 Player
Sansa/Sandisk m240/1.GB Firmware information. I would like to be able to download firmware software for this device. If not a link for the older version of the firmware. Or maybe some suggestions for...
good day sir hope that this will help you to your problem....
What is a firmware, and what does a Sansa Firmware Updater do? Firmware defined
Firmware is the software code that powers your Sansa player. SanDisk actively and periodically updates the capabilities, functionality, and reliability of your Sansa player through this firmware. For optimal experience with your Sansa player, SanDisk recommends that you update your firmware with each new release.Firmware updates are free.
The Sansa Firmware Updater is an application designed to deliver the latest firmware, software support, User Manuals right to your desktop.
Download Sansa Firmware Updater.
Sansa players supported by the Sansa Firmware Updater:
- Sansa c200 series
- Sansa Clip / Clip+
- Sansa e200 series
- Sansa Express
- Sansa Fuze
- Sansa Fuze+
- Sansa View
Supported OS:
Windows 7, Windows Vista, Windows XP, Windows 2000 SP4
NOT supported:
Mac & Linux
NOTE: Administrative access is needed on your PC to run the Sansa Firmware Updater.
if this help you please rate me sir thanks you...
Jun 05, 2011 | Computers & Internet
I was listening to music with my mp3 sandisk dansa 3260 (4 GB) and it just stopped playing music and turned of and when i turned it on again the screen kept going black and white black and white ......
HI, When an mp3 player malfunctions,is usually caused by VIRUS that has affected the functions of the mp3 player..To fix the problem,you might to First rest the mp3 player and after resetting the mp3 player and it stills malfunctions, youmight need to update the firmware of the mp3player...
To reset the mp3player :
Instructions
Reset via command
Push the "Power" switch downward into the "Hold" position.
Press and hold the "Menu" and "Record" buttons at the same time until the device resets.
Push the "Power" switch upward all the way to turn it back on.
Reset via switch
Grab a steady hold around the device.
Push the "Power" upward and hold it there until it powers off.
Power the device back on by releasing the power switch and then pushing it upward again.
Force reset via power-cutting
Unscrew the screws on the back of the device (or simply push the lid off if it is a model without screws.)
Take out the batteries from the slot and wait until the screen goes black.
Insert the batteries the same way they were mounted and attached the lid again.
Push the power switch upward to turn on the device.
Tips & Warnings
A good idea to stop Sansa devices from freezing is to always make sure that the player's firmware version is up-to-date. Download the firmware updater software from the Sansa website (see link in Resources).
To update :
Updating the firmware of your Sansa MP3 player is easy, and it will correct problems with the original software, and even add new features. Follow the instructions below to bring your device up to date. If you have any questions about the process, please consult the Sandisk website and support forums for more specific information. Links to these sites are provided at the end of this article.
things you'll need:
* A Sansa MP3 Player
* A Computer with an Internet Connection
instruction:
Automatic
Verify that the player is fully charged.
Verify the the player is unplugged from your computer.
Go to the Sandisk support site, linked below, select your player, and download the Sansa Firmware Updater software. Follow the instructions for installing it on your computer. If you need them, you may also download user manuals for your or watch how-to videos on updating the firmware.
Put the player in MSC mode. Go to the settings menu, select the USB submenu, and then select MSC. Some players with early firmwares do not have the USB options in the menu. If this is the case with your device, then there is another way to force it into MSC mode: Put the device in "hold" mode by sliding the hold switch until orange is visible. Next, press and hold the left (rewind) button until the screen changes. Go to the next step.
Plug your Sansa player into your computer and wait. The Firmware updater should launch automatically. Follow the prompts to update your player. Be certain not to unplug your player until the updater is finished. The software will tell you when it is safe to disconnect.
Tips & Warnings
If the above does not work for any reason, there is another way to update the firmware, by manually installing the necessary files. Consult the official support forum for specific instructions for your device. See the link below.
Be sure not to unplug your device while it is being updated. This could permanently ruin it.
Hope it helped...
May 16, 2011 | SanDisk Sansa e260 MP3 Player
Will not play blu ray discs but will play ordinary dvd's
You need the firmware update. You need to download it from here...
http://www.sharpusa.com/CustomerSupport/ProductDownloads/SoftwareDownloads.aspx
and save it to a usb flash drive that is between 1-2 gigs in storage with no other files saved on to it. insert the flash drive into your blu ray player and select " software update" from the settings menu.
Jan 02, 2010 | Sharp BDHP20U Blu-Ray Player
Rolling back firmware
Cardinal Rule ....1
NEVER update any FIRMWARE.....
Cardinal Rule ...2
if in doubt refer to rule 1
You CANNOT rollback firmwares once loaded, Firmwares are programs written within a CHIP inside the hardware.
You can rollback Drivers and update them also, but Firmwares are not of the same nature.
for example if you have a MP3 player that has a specific Firmware, the firmware is specifically programed to run that hardware(MP3 player), once you change the firmware the hardware will not be able to recognize the firmware and viceversa.
Dec 06, 2009 | Computers & Internet
I hate blurays, pain to update onto usb plug
Okay you need to visit the sharp website download the update onto a usb flash drive and then plug it into the unit this will update the firmware inside if you have any questions further call sharp on specifics of the firmware update. You will find that you whille have to do this every so often as blue ray disk are being compermised rapidly in order to provent piracy that function needed to be intact. Thanks for visiting fixya.com please do leave postive feedback for your free answer today!
Nov 10, 2009 | Sharp AQUOS Blu-ray Disc Player
Can the firmware on a in dash kenwood dvd be change
Visit www.kenwoodusa.com for latest firmware updates. Some of the updates are specific to map software (Garmin for KNA-G510) or bluetooth (Parrot for KCA-BT200) only.
Aug 10, 2008 | Kenwood DNX7100 Car Video Player
Firmware upgrade not working
Are you absolutely sure that you loaded the firmware for your correct model #? Try downloading the auto-updater software and see if it will take the upgrade on the next go around.
If not, that player is fried - update during firmware upgrade is no good. Call rCA to see if you are still in warranty.
Usually the "50MB of space needed to operate error" is easy to fix, but also most other manufacturers have a specific FAQ on their website that tells you how to fix it. RCA did not have anything like that for this model. also, most other manf. have a recovery tool of some kind - absent on this model.
Jun 28, 2008 | RCA OPAL M4001 MP3 Player
NEED HELP WITH MP3 PLAYER
You need to update the firmware of your mp3 player, try to look for firmware upgrades for your specific brand or model...
Dec 09, 2007 | Audio Players & Recorders
Vizio VBR210 Blu-Ray Player Logo
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
