Question about Samsung DV448AGE Gas Dryer
How to get into samsung dv45h6300gw - Samsung DV448AGE Gas Dryer
Theres a stripe line if I use my samsung SL30 digital camera in a bright place but in dark place the camera sa good and thers no stripe line.
Is the "Stripe line" appearing when you use an arftificial (LED or Fluorescent) light source?
They flicker and can cause a line or interference pattern on the camera.
Apr 07, 2016 | Samsung SL30 Digital Camera
Tip
How to Directly Recover Data from Samsung Devices without Backups.
Accidentally lost data from Samsung device? No available backups? Don't get too tensed. Why not get help from a Samsung Data Recovery tool to do the job?
About Jihosoft Samsung Data Recovery
It is specially designed for Samsung users to recover deleted files on Samsung phones and tablets. You can easily get back the lost data from Samsung phone memory as well as SD card in a few clicks. It can recover photos, audio files, contacts, text Messages, call history, WhatsApp Chat, Messages attachments, and other files from Samsung devices. Samsung Data Recovery supports various Samsung devices, including Samsung Galaxy S6, S6 edge, S5, S4, S3, S3 mini, S5 mini, Note 2, Note 3, Note 4, Samsung galaxy tablets etc.
Steps to Recover Data from Samsung
1.Get the Samsung Recovery program
2.Connect your Samsung Galaxy to computer
3.Run Samsung Data Recovery
4.Select specified file types you need to recover
5.Enable USB Debugging on Samsung(Optional)
6.Scan Data from Samsung Device
7.Preview and recover data from Samsung
Note: Stop using your phone/tablet once you noticed the data lost. You should know that the lost data probably be overwritten by any new content, which could case the lost data unrecoverable. Best Samsung Data Recovery Software
on Jun 16, 2015 | Samsung Cell Phones
Find password
http://www.routerpasswords.com/
samsung router passwords
a complete list of usernames and passwords for samsung routers.
find your samsung router password
finding your samsung router's user name and password is as easy as 1,2,3.
  1. find your samsung router model number
    look in the left column of the samsung router password list below to find your samsung router model number.
  2. find your samsung router username
    look one column to the right of your router model number to see your samsung router's user name.
  3. find your samsung router password
    you know the drill. look another column to the right to find your samsung router's password.
great! you've found the password and username for your samsung router! what next?
login to your samsung router using the router password
try logging into your samsung router using the username and password.
don't know how to login to your samsung router?
you can login to a samsung router in three easy steps:
  1. find your samsung router ip address
  2. enter your samsung router ip address into an internet browser's address bar
  3. submit your samsung router username and password when prompted by your router
for more information on how to login to your samsung router please see our free guides.
still can't login to your samsung router even when using the username and password for your router? samsung router password list
samsung model default username default password n620 n/a (none) magiclan swl-3500rg 2.15 public public modem/router aht-e300 admin password sch-lc11 admin admin smt-g7400 admin admin
Jan 29, 2014 | Belkin F5D8236-4 Router
Forgot my password for samsung e 390
Hello Dear,
Type the code * 2767 * 3855 # and the phonewill reset to the factory settings. Other interestingcodes for Samsung phones: * # 0228 # BatteryInformation
* # 0673 # Test MP3
* # 0782 # Date and Time
* # 0842 # VibrationTest
* # 1111 # SoftwareVersion FTA
* # 1234 # Softwareversion (short)
* # 1235789 # StateControl of Integrity
Hardware Version * #2222 # FTA
* # 232337 # BluetoothBroadcast Address View
* # 32489 # State ofCiphering
* # 742695 # Softwareversion, Hardware Version, Date of Last Calibration Radiofrequency
(Equivalent to * # 8999* 8376263 #)
* # 8999 * 8376263 #Software version, Hardware Version, Date of Last Calibration Radiofrequency
(Equivalent to 742 695* # #) * # 1546792 * #Admin settings (WARNING: not to experiment!)
(* # * 73561 # OperatorCode, where applicable)
(* # 2456987 * # MasterKey) # * # 123580 TestMode main menu (not to experiment!, Equivalent to * # 9998 * 324 #)
* # 9998 * 324 # TestMode main menu (not to experiment!, Equivalent to * # 123580 #)
* # 0002 * 28346 # ItemMenu Handset Volume (sub-menu of the Test Mode Menu)
* # 0011 # NetworkConnection Status
(Same as in Test Mode,which not only returns to the main menu of the Test Mode)
* # 7412359 # Test MenuRadiofrequency
* # 9999 * 0 # NetworkMonitor
(Same as in Test Mode,which not only returns to the main menu of the Test Mode) * # 7465625 # setthe Phone List of Blocks # 7465625 * 27 *code # Remove the "PC Lock"
# 7465625 * 638 * Code# Remove the "Network Lock"
# 7465625 * 685 * Code# Remove the "Multi Lock"
# 7465625 * 746 * Code# Remove the "SIM Lock"
# 7465625 * 77 * code #Removes the "SP Lock"
# 7465625 * 782 * Code# Remove the "Subset Lock"
# 7465625 * 228 #Disable "Activa Lock"
# 7465625 * 2827 #Disable "Auto CP Lock"
# 7465625 * 28638 #Disable "Auto Network Lock"
# 7465625 * 28685 #Disable "Auto Multi Lock"
# 7465625 * 28746 #Disable "Auto SIM Lock"
# 7465625 * 2877 #Disable "Auto SP Lock"
# 7465625 * 28782 #Disable "Auto Subset Lock" Malicious code:
* 2767 * 3855 #Reset Full Phone (back as "just bought") * 7465625 * 27 *code # Set the "PC Lock"
* 7465625 * 638 * Code# Set the "Network Lock"
* 7465625 * 685 * Code# Set the "Multi Lock"
* 7465625 * 746 * Code# Set the "SIM Lock"
* 7465625 * 77 * code #Set the "SP Lock"
* 7465625 * 782 * Code# Set the "Subset Lock"
* 7465625 * 228 #Enable "Activa Lock" to restart the phone
* 7465625 * 2827 #Activate "Auto CP Lock" to restart the phone
* 7465625 * 28638 #Turn on "Auto Network Lock" to restart the phone
* 7465625 * 28685 #Turn on "Auto Multi Lock" to restart the phone
* 7465625 * 28746 #Turn on "Auto SIM Lock" to restart the phone
* 7465625 * 2877 #Activate "Auto SP Lock" to restart the phone
* 7465625 * 28782 #Turn on "Auto Subset Lock" to restart the phone These codes areworth a bit more for all Samsung phones, in particular: Samsung E390,Samsung Ultra Video F500, Samsung F510, Samsung F520, Samsung F700, Samsung SGHi520, Samsung i600, Samsung i620, Samsung L760, Samsung P910, Samsung P920,Samsung P940, Samsung SCHB100, Samsung SGH F600, Samsung SGH i550, Samsung SGHJ750, Samsung SGH I600, SGH i607 Samsung Blackjack, Samsung SGH P930, SamsungSGH Z630, Samsung Ultra Edition 12.1 (U700), Samsung Z100, Samsung Z105u,Samsung Z107V, Samsung Z110, Samsung Z130, Samsung Z140, Samsung Z140V, SamsungZ150, Samsung Z170, Samsung Z220, Samsung Z230, Samsung Z300, Samsung Z310, SamsungZ320, Samsung Z330, Samsung Z350, Samsung Z360, Samsung Z370, Samsung Z400,Samsung Z500, Samsung Z510, Samsung Z520, Samsung Z540, Samsung Z550 , SamsungZ560, Samsung Z600, Samsung Z610, Samsung Z620, Samsung Z650i, Samsung Z700,Samsung Z710, Samsung Z720, Samsung ZV10, Samsung ZV30, Samsung ZV40, SamsungZV50, Samsung ZV60, Samsung ZX10, Samsung ZX20. WARNING: Someof these codes may cause blockage or malfunction of the cell, therefore, it isunderstood that you use them at your own risk.
Dec 04, 2011 | Samsung SGH-E390 Cellular Phone
Samsung TL205 Battery Charger http://www.samsung-battery-charger.com/Battery-Charger/Samsung-TL205-Battery-Charger.html Samsung ST50 Digital Camera Battery...
What a battery of information you have accumulated - you must be a bright spark. Please put a plug in it now.
Jun 27, 2017 | Samsung Cameras
The top red bar light is flashing. What does this mean?
you have to reset your printer or add chip while refilling toner. info@nakshatraworld.com
Jun 09, 2010 | Samsung ML 2525 BW laser Printer
Sidekick lx '07
SAMSUNG PRODUCT
Samsung S5600v Blade ..........$300
Samsung I8000 Omnia II ........$275
Samsung E1390 .....................$280
Samsung E1160 .....................$275
Samsung E1130B ...................$285
Samsung S8000 Jet ................$230
Samsung i8910 Omnia HD ......$210
Samsung E1360.....................$250
Samsung E1210.....................$240
Samsung i8510 INNOV8...........$230
Samsung i900 Omnia..............$240
Samsung i7110.......................$220
Samsung Armani.................... $220
Samsung M8800 PIXON............$240
Samsung J800 Luxe.................$235
Samsung L700........................$230
Samsung S9502 DUOS.............$240
SIDEKICKS PRODUCT
Sidekick LX 2009 .......... $170
Sidekick 2008 ............. $150
Sidekick LX ................. $110
Juicy Couture Sidekick II ........ $120
Mister Cartoon Sidekick .......... $130
Juicy couture Sidekick III ........ $130
Sidekick D - Wade ................. $130
Contact: Mr. Randy Barnett
Email: isell.seitz@gmail.com
Email: isellfast198@yahoo.com
Chat with me on MSN: i-sell@hotmail.com
Nov 09, 2009 | T-Mobile Sidekick
Samsung DV448AGE Gas Dryer Logo
24 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
