Question about Pioneer PDP-4280HD 42 in. Plasma Television
Reset trap switch
How to reset trap switch
How Do I Enable or Disable Traps of a Module?
In V100R005 and later versions:
Run the snmp-agent trap enable feature-name feature-name trap-name trap-name command in the system view to enable a trap of a specified module.
Run the undo snmp-agent trap enable feature-name feature-name trap-name trap-name command in the system view to disable a trap of a specified module.
For example, to enable the hwethernetarpipconflictevent trap of the Address Resolution Protocol (ARP) module, run the following commands:
<HUAWEI> system-view [HUAWEI]<strong> snmp-agent trap enable feature-name arp trap-name hwethernetarpipconflictevent </strong> For example, to disable the hwethernetarpipconflictevent trap of the Address Resolution Protocol (ARP) module, run the following commands:
<HUAWEI><strong> system-view </strong> [HUAWEI]<strong> undo snmp-agent trap enable feature-name arp trap-name hwethernetarpipconflictevent </strong> S2300 Switch Thunder link com
Nov 10, 2016 | Computers & Internet
Can i use a universal remote to reset trap switch on pioneer pro 1150hd 50in. tv
To get into service mode you need the genuine remote control, A universal one will not work.
Mar 06, 2012 | Pioneer Televison & Video
Where is the reset button?
depending on the make/model,it will be the thermal fuse,some are resettable where others are a one time fuse and need replacing
Feb 12, 2012 | Dryers
Will not drain...but is turning....i tried to reset by pushing the red button and did nothing...i took the L wrench and turned it from the bottom and still nothing...sink is full of water too..what can i...
1) If disposal will not drain: Clean the tubular drain under sink.
Remove 2 nuts on p-trap, and trap falls loose, then remove tailpiece on side of disposal, hand rag over opening to direct water downward, turn on water, turn on disposal and see if disposal empties, clean p-trap, and then reassemble tubular drain.
2) If disposal will not drain and will not run: Clean tubular drain, check for power to disposal.
If disposal is getting power and will not run, and reset button is not tripped out, and cutter disk rotates freely, then disposal is bad.
I wrote ez disposal replacement steps that include tips for tubular drain.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Aug 21, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Garbage disposal quit and both sinks are clogged , disposal won't work at all , is it a clog in the trap or is it the disposal
Clog is probably the trap.
Bail out as much water as possible, get some towels, and put bucket under trap and tubular pipes.
Remove two nuts off P-trap or S-Trap and drop trap down, and sinks will drain.
After clog is cleared, check disposal.
Check reset button on disposal.
If disposal is stuck, use wood boomstick to wedge open the cutter disk, or use allen wrench in slot on bottom of disposal.
If disposal will not work, check circuit breaker.
There are no repair parts for disposals.
For additional information about replacing disposal and permanently fixing tubular pipes:
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on plumbing or any do-it-yourself project.
Fixya is always less expensive than a service call
Feb 20, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have a BFG1H4040T3NOV Whirlpool gas water heater and cannot locate the reset button. Can you tell me where it is located? Thanks,
The reset button is right in the middle of the thermal switch. It is that white thing on the right side. The 'button' is the size of a pencil lead in between the two terminals. Make sure your combustion chamber and flame trap are clean or they cause excessive combustion chamber temperature causing this switch to trip which shuts off the burner and pilot.
Jan 05, 2011 | Kitchen Ranges
Garbage disposal work and the reset button doesnt reset. There is no jam. Turned off power and checked for electricity--ok. Noticed that plastic was in the disposal when cleaning out. This is a 1/3 hp...
Disposals go bad.
If reset is popped out and won't reset when power switch is turned OFF, then that says reset button is bad.
Reset button cannot be replaced on disposal, so disposal is no good.
Your question said you checked following things, but it doesn't hurt to review.
If reset keeps tripping, then disposal has internal short.
Check for power at switch to see if switch is bad.
Check for power at disposal where wires connect.
Put wood broom handle in disposal and see if cutter disk rotates freely.
Use vacuum cleaner to remove unwanted debris from disposal.
I wrote tips for replacing disposal:
When I worked apartment maintenance, we replaced disposal with same brand disposal.
That way we didn't have to change out sink basket or change pipes.
How to: Disconnect p-trap and tailpiece going into disposal.
Rotate connector disk clockwise that holds disposal to sink basket.
Before installing new disposal.
Attach electric wire to new disposal.
Attach dishwasher tube to new disposal. Knock out plug inside dishwasher opening.
Push new disposal up into place, and attach to old sink basket with new connector disk.
Use new connector washer.
Re-assemble tubular pipe.
If this is your home, you want new sink basket that comes with new disposal because it looks shiny and new.
Buy a tub of plumbers putty also.
Remove old sink basket and clean opening.
Put finger-size roll of plumbers putty around sink opening, and then push new strainer basket into plumbers putty.
Tighten basket from below, wipe away excess putty around sink opening.
Install new disposal as described above.
Tips for tubular pipes:
When taking apart tubular pipes, start at p-trap and take apart as few pieces as needed to do job.
On image above, loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Any tubular drain pipe that gets moved while working under sink needs to be disassembled, cleaned and re-assembled.
Metal pipes have rubber washer >> always use new rubber washers.
Plastic pipes have plastic washers > plastic washers can be cleaned and re-used.
Plastic washers have flat side that goes toward nut, tapered side away from nut.
When reassembling tubular pipe, we use rectorseal on washers and joints.
Apply good amount on washer just before pushing washer in place and attaching nut.
Rectorseal will ensure tubular drain pipes won't leak.
Add a comment
Dec 13, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Goodman furnace burner ignites then shuts off in about 10 seconds
if you have replaced the flame sensor and it will not stay lit, the draft safety switch may be opening. It works on positive and negative pressure created by the inducer fan motor.You may have a restriction in your heat exchanger or if is a high efficiency furnace, it may not have the drain tube installed properly with a trap. The trap works just like the trap under your sink and if water isnt in the trap, the pressures can be effected enough to open the draft switch(some call it an air pressure switch)
Jan 07, 2010 | Heating & Cooling
I can hear the timer run but the push button switch will not start the dryer
Check your home's fuse panel or reset the breaker (even if it looks like it's not tripped).
Check the door switch and make sure there is a click when you press it. If your model has a light inside, make sure it turns off when you press the door switch.
Check the belt to make sure it's not broken. Either turn the drum by hand from the inside, you should feel resistance from the motor or lift the cabinet top by removing the 2 screws under the lint trap (in the lint trap is on top) and pry the top forward and up.
If these don't work, can you provide the model number. I may be able to help you better.
Feb 18, 2009 | Dryers
Plasma tv
you have tript the trap switch. there is one in he panel and one in the media reciever.you have to enter the technicians code followed by pressing the mute button 4 times then the display button. this should reset the trap switch.i presume you have put the cover back on. if not you must tie down the trap switch which you will see facing up
Oct 02, 2007 | Televison & Video
Pioneer PDP-4280HD 42 in. Plasma Television Logo
60 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
