Question about Garden
Ignition points What is the points gap for a Suffolk 98G14
2 Suggested Answers
  • 5575 Answers
SOURCE: ignition point gap and spark plug gap inboard outboard omc
.019 for the points and .035 for the plugs
Posted on Jul 10, 2009
I have a 1993 ford Econovan maxi . I have ignition point . What is the gap on the ignition point . Thanks
point gap is .40 to .50 mm ( point 4 to point 5 mm) or .015 to .20"
most point distributors are at the .02 " mark but check and adjust as points to wide will misfire under load or lack power if too close
point gap variations can change ignition timing
Nov 20, 2016 | Ford Cars & Trucks
What is the dwell angle on a 3f engine if point gap is 18 thou
dwell angle is the no of degrees rotation between points closed and points open and for example on a 4 cylinder engine ( 4 lobes =90 degrees the dwell would be around 45 degrees available
there is an adverse relationship between point gap and dwell angle
the closer the points the bigger the dwell and conversely the bigger the gap the smaller the dwell angle
in a distributor the point gap of 18 would have a large dwell angle and that affects ignition timing
in your workshop manual there will be a dwell angle specification and if you set the points at .020 " that will put you close to the dwell angle specification
from there you adjust the gap to obtain the dwell setting
after yo have the dwell set , adjust the ignition timing
there is plenty of information on dwell angle, /point gap if you type in ---dwell angle to point gap relationship--
Aug 16, 2016 | Cars & Trucks
What is the ignition point gap?
In older engines with traditional points-condenser-coil ignition systems the dwell if the ignition was set by the gap between the points. The points act like a switch that opens and closes the circuit of the primary side of the ignition coil.
All later engines use electronic ignition that do not require points.
Mar 28, 2016 | Cars & Trucks
What is gap
Hi, Mike pertaining to engine spark plugs, "GAP" is the distance between the positive and negative electrodes at the base of the plug and is measured in thousands of an inch or mm by using a round pin gap gauge or flat blade feeler gauge. Every engine manufacturer has a specific design-size-heat range- gapped spark plug. Gaps will vary depending on engine brand. Gap is also referred to in engines using a mechanical "POINTS" ignition system instead of electronic ignition (what is the points gap) for more information about your question and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
How to Inspect and Adjust the Spark Plug Gap NGK BOSCH CHAMPION N3 DENSO
http://www.jsesc.com/mfg_docs/ste/Spark_Plug_Application.pdf
Points and Condenser Setup wiring Setting Gap Cleaning Points Setting...
Multi Ground Spark Plugs NGK Spark Plugs Tech Video
Mar 12, 2016 | Motorcycles
Ignition points gap setting for '86 land cruiser fj75
WELL 1986 IGNITION SYSTEM ELECTRONIC THE WAS NO POINTS USED. LAST SET OF POINTS IN TOYOTA WAS 1979 TO 1980 POINTS GAP SETTING WOULD HAVE BEEN 0.018
Dec 07, 2010 | 1986 Toyota Land Cruiser
What is the gap between he condenser and the piont
The point gap on all Briggs and Stratton engines is .020 inch
Mar 16, 2010 | Briggs & Stratton Ignition Kit 2-8 HP...
1981 converted to points, whats the point gap? and and the spark plug type and gap?
Point gap is about .018" if you can get the
timing aligned there. If not, vary the gap
slightly.
Spark plug is NGK BPR5ES-11 with a .022"-.025" gap.
Electronic ignition plug gap is much larger at .040"
Aug 20, 2009 | Harley Davidson FXDWG Dyna Wide Glide...
Ignition point gap and spark plug gap inboard outboard omc
Jul 05, 2009 | Boating
'Get-Jet' Airplane mover
Hi Freddie ignition- to- flyweel gap means flyweel magnet positioned under the ignition coil armature.Remove the flyweel.Check the flyweel key(if it is sheared off install a new one).Remove the ignition coil.Clean the flyweel magnet and the ignition coil armature.Check the ignition coil wires and terminal to have continuity.Remove the breaker points cover,check the condenser and breaker points(they should not to be burned).The ignition breaker point gap and ignition-to-flyweel gap is 0.020" and the spark plug gap is 0.030". regards savumihai71
Nov 01, 2008 | Briggs & Stratton Electrical Supplies
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
